MiniZed Hardware Design MiniZed board
  • Subscribers 357 subscribers
  • Views 438 views
MiniZed board
dragos.dascalu
dragos.dascalu over 8 years ago
I have the minized board but every time I'm using it the FPGA IC is warming up. I have just a Hello World programmed.
This is normal or there's a problem?
If it's a problem how can I fix it?
I have to put a heatsink or a FAN?
  • drozwood90
    0 drozwood90 over 8 years ago
    The chip will get warmer than room temperature, as with just about any electronics.  The amount of temperature depends on your design.  How much power is estimated for your design?  Can you validate that by measuring it?
    Do you have any idea to what temperature the chip is getting to?
    If your design thermals require a heatsink, that is really up to your design and your packaging.  You will need to calculate the theta-j value from the power estimates within Vivado.
    --Dan
