MiniZed Hardware Design MiniZed board
  • Subscribers 358 subscribers
  • Views 563 views
MiniZed board
johnmorgan13
johnmorgan13 over 7 years ago
I have the minized board but every time I'm using it the FPGA IC is warming up. I have just a Hello World programmed.
This is normal or there's a problem?
If it's a problem how can I fix it?
I have to put a heatsink or a FAN?
Thanks & Regards,
John TV
  • jafoste4
    jafoste4 over 7 years ago
    Hi John,
    It is normal for it to heat up a bit. If your using it in a standard ambient room temperature I would say you don't need to add a heat sink on and can just use it as is.
    -Josh
