PicoZed Hardware Design Z7030 Getting Started problem
  • Subscribers 357 subscribers
  • Views 706 views
I have the following behaviour with my Z7030
D1 green (ok)
D19 green (ok)
D14 green (ok)
D6 off (not ok)
D21 off (not of)
PC user leds 1,2 red
PG user led red
Nay ideas what's going wrong?
regards
Kai
  • bhfletcher
    0 bhfletcher over 10 years ago
    That is not much information. Is this out of the box? Is it plugged into a PicoZed FMC Carrier? Are you booting from QSPI, SD Card, or JTAG? What are you doing?
    If this is out of the box, have you already read this?
    http://zedboard.org/content/done-led-fails-light-picozed-7015-and-7030-out-box
    Bryan
    0 e14 Contributor over 10 years ago in reply to bhfletcher
    Hi Bryan,
    it`s plugged into a PicoZed FMC Carrier and I'am booting from QSPI. What I don't understand are the red LEDs and why I don't have a USB connection (no amber LED).
    Kai
  • drozwood90
    0 drozwood90 over 10 years ago
    Kai,
    Which USB are you plugged into?  Are you trying to use the OTG port, or the terminal access?
  • bhfletcher
    0 bhfletcher over 10 years ago in reply to e14 Contributor
    The only time the USB-UART Link LED lights is when you actually have a link, meaning the cable has to be plugged into J6 and the PC, the driver installed on the PC, and a utility (like TeraTerm) running that is connected to the link.
    The PS and PL user LEDs will turn on, even when not driven, depending on how the unused I/Os and pre-configuration pull-up settings are set. As soon as you put these into your design and control them, then they will turn on and off at your choosing.
    Bryan
