PicoZed Hardware Design UART Connection
  • Replies 11 replies
  • Subscribers 359 subscribers
  • Views 1692 views
UART Connection
zrmireya
zrmireya over 11 years ago
Hi
Please, I need some help. I am working with Vivado 2014.4, I am trying to run Hello World application, but I  get not no connection to TeraTerminal neither Terminal1 using SDK.  I got this error
Connection canceled due to ownership request from org.eclipse.debug.internal.cor
e.LaunchConfiguration.
In Vivado, I selected only UART1 peripheral.  When I tried to use the Preset option I got error ( I used  the ps7.tcl from Picozed.org for Vivado 2014.4)  -- Not a Valid Preset
The PL and PS aparently are programmed. Led FPGA DONE turns BLUE, but PS USER LED is always red.
The driver for UART is installed, I detect COM3 in my PC, but no data serial in the Terminal.  I am using 115200 baud rate.
  • zrmireya
    0 zrmireya over 11 years ago
    I forgot to mention, I am working with xc7z030sbg485-1.
  • bhfletcher
    Did you already go through the exercise to install the CP2104 drivers?
    Bryan
  • zedhed
    0 zedhed over 11 years ago
    Hi mireya_z_r,
    Also, it might not hurt to verify that SDK is being run with permissions to open the UART.  Perhaps on some machines where user access is restricted, the permissions to access the UART device are insufficient.
    Also, a lot of us simply use an external terminal like Tera Term since it has some advanced features (like scripted input) and this might work better for you as well.  If you go that route, you will want to make sure that when you launch your application with a Debug/Run configuration that the "Connect STDIO to Console" option is disabled.
    http://forums.xilinx.com/t5/New-Users-Forum/Error-opening-JTAG-UART-localhost-1/td-p/479980
    -Kevin
  • zrmireya
    0 zrmireya over 11 years ago in reply to zedhed
    Hi Kevin
    Thank you for your reply. I tried all your suggest before.  Iu00B4m using  Zedboard for testing applications and all works perfectly. I use Teraterm and disable "Connect STDIO to Console" option (Zedboard works always), Z030 doesnu00B4t.
    Also I was working in Ubuntu, and I have the same problems.  Z030 never transmits information to the console (I am using gtkterm).  Zedboard works.
    Do you have any other sidea where it might be my error.
  • zrmireya
    Hi Bryan
    Yes, I installed the drivers. I am sure this is working, because I am working with a Zedboard and everything is fine.
  • zedhed
    Hi mireya_z_r,
    I see now where you mentioned that you are using the xc7z030sbg485-1 device?  Is this a Zynq device that you have on a custom board or are you using a PicoZed 7030 module instead?
    -Kevin
  • zrmireya
    Hi Kevin
    I found out what I was doing wrong.
    Thanks for the help
  • zedhed
    Hi mireya_z_r,
    I am glad that you found what was wrong.  Is this resolved now?
    If so, would you please post a description of your solution for other community members?
    -Kevin
    0 e14 Contributor over 10 years ago in reply to zrmireya
    I also met the same problem with you ,
    can you tell me that how you solve the question
    thx alot
    thx alot
