PicoZed Hardware Design PicoZed SDR 2x2SOM Schem Rev E and BOM Rev C
  • Subscribers 358 subscribers
  • Views 687 views
Support,
When will the Rev E BOM that reflects the Rev E Schematic (Nov 4 2016) become available?  I am seeing some significant differences between PicoZed SDR Z7035-AD9361 BOM RevC and  PicoZedSDR_z7035-ad9361_RevE_schem_02_038702e_top.
Craig
  • mbrown
    0 mbrown over 9 years ago
    Rev E BOM was just added to the docs page. Also, please PCN17001 on the same page.
    0 e14 Contributor over 9 years ago
    Support,
    I am designing a circuit board to interface to the PicoZed SDR FMC Carrier Card AES-PZSDRCC-FMC-G and I cannot find anywhere in the documentation or mechanical drawings any information regarding the size and spacing of the two mounting holes on both sides of of the FMC connector.  I am assuming I can get that information from the Altium file but I was hoping there might be a short blurb about the hole sizes and relative spacing to the FMC connector.  Would you mind providing that information?
    Craig
  • mbrown
    Hi Craig,
    It's a VITA57 compliant FMC interface, so the spacing is all standardized. However the spec must be purchased.
    This post for MicroZed may help you get what you're after -- http://picozed.org/content/dimensions-custom-board-area-microzed-fmc-carrier-card
    /Matt
