PicoZed Hardware Design Schematic Error?
  • Subscribers 358 subscribers
  • Views 642 views
Schematic Error?
Bertl
Bertl over 12 years ago
The Picozed 7015/30 rev. B2 schematics (9/4/2014) shows (on page 10) that the GTX Power block has MGTAVTT decoupled and connected via a 220R ferrite bead to MGTAVCC and similar, MGTAVCC is connected to MGTAVTT.
I think the labels got swapped there.
In any case, I'd appreciate a clarification on this issue.
Thanks in advance,
Herbert
    You are correct, so there will be an updated 'B3' schematic posted.
    Thanks for pointing out the error to us!
    -Gary
  • Bertl
    0 Bertl over 12 years ago
    You're welcome!
    Thanks for the quick reply, appreciated!
    Best,
    Herbert
    What will be the correction to the schematic?  Do I still connect 1.0V to the connector pins labelled MGTAVCC and 1.2V to the connector pins labelled MGTAVTT?  Or are you going to rewire the connector?
    The PicoZed 7015/7030 Rev B schematic has been updated and posted on the PicoZed Documents page. The updated schematic has a 9/18/14 date.
    -Gary
