PicoZed Hardware Design Wrong pins in Design Guide
  • Subscribers 357 subscribers
  • Views 743 views
I believe there are some errors in the Design Guide (Rev 1.5). In table 5 on page 9, the 7030 FPGA pins are not mapped correctly to the JX3 pins according to the schematics (Rev B). Table 17 on page 26 seems to have it correct.
For instance, PS_MIO40_501 is connected to FPGA pin E9 and to JX3-43 according to the schematics and to Table 17. Table 5 shows it connected to JX3-39.
    Thanks for letting us know about the errors in the Design Guide! We will get those corrected for the next revision of the Guide.
    Please be aware that we will be changing the design of the 7015/7030 PicoZed board to make the 'clock capable' signals on the JX1 and JX2 signals compatible with the 7010/7020 PicoZed and the MicroZed boards.
    Once the documents are complete we will post new 'Rev C' PicoZed 7015/7030 documents.
    -Gary
    Thanks for letting me know about the update. I am in the process of designing my own carrier card, but now I might have to wait for the update. When do you anticipate having the changes documented? Also, when will the new boards be available?
    We are currently reviewing the changes. We expect to have the updated Rev C documents for the 7015/7030 PicoZed posted by Mid December. At this point it looks like it will be changing signal assignments to JX1 and JX2 to match the 7010/7020 PicoZed and the MicroZed SOMs.
    I will post an update on when boards will be available as soon as possible.
    -Gary
    Is there an error in Table 17, JX3 Connections, JX3-100? The doc shows connected to FPGA Y17 but the Rev C (PicoZed 7015/7030) schematic shows W16.
    Thanks for the heads up on the error in the PicoZed Design Guide document. The schematic is correct.
    We will correct the Design Guide.
    -Gary
