PicoZed Hardware Design PicoZed 7020 Package flight times
  • Subscribers 358 subscribers
  • Views 973 views
Hello all,
Is it possible to get a copy of the picozed 7020 package flight times - specifically for the DDR3 interface nets?
Thanks!
  • bhfletcher
    0 bhfletcher over 10 years ago
    Xilinx makes it possible for you to generate these for yourself. See UG899:
    Package Trace Length
    Instead of giving trace length data, Vivado Design Suite provides trace delay data, which is
    the most accurate way to estimate package delay.
    1. Open a design in Vivado, either RTL, netlist or implemented.
    2. Select Export > I/O Ports > CSV to see the min and max package delays for each pin.
    The min/max trace delays are also displayed in the Package Pins window for every
    package pin within two separate columns.
    Alternatively, you can select File > Export I/O ports for a CSV type spreadsheet that
    includes delays.
    3. The following TCL commands can be used is there is no project:
    link_design -part <part_number>
    write_csv <file_name>
    For Example:
    link_design -part xc7k410tffg900-2
    write_csv flight_time
    I have also created a TCL script that will do this as well.
      set part_name "xc7z020-clg400"
      create_project ExportPKG -part $part_name
      create_bd_design "design_1"
      generate_target all [get_files  ./ExportPKG.srcs/sources_1/bd/design_1/design_1.bd]
      make_wrapper -files [get_files ./ExportPKG.srcs/sources_1/bd/design_1/design_1.bd] -top
      add_files -norecurse ./ExportPKG.srcs/sources_1/bd/design_1/hdl/design_1_wrapper.v
      update_compile_order -fileset sources_1
      update_compile_order -fileset sim_1
      launch_runs synth_1
      wait_on_run synth_1
      open_run synth_1 -name netlist_1
      write_csv ./${part_name}.csv
    I am not able to attach a file here, but if you still need it, reply and I will post online somewhere.
    Bryan
    0 e14 Contributor over 9 years ago
    Many thanks!
    Sadly, I don't have access to Vivado - I am in the process of laying out a PCB - but your answer is a big help and I will pass it on :)
    If you could upload your figures for the picozed, it would be a big help and a great sanity check for any figures we generate.
    Tom
  • jafoste4
    0 jafoste4 over 9 years ago
    Hi Tom,
    I generated the trace delay data for you. Please follow the link.
    https://avnet.egnyte.com/dl/EUOyl5dJFp
    Thx,
    Josh
    Josh,
    Your figures match the ones we have generated exactly.
    Thank you and Bryan for your efforts!
    Tom
