PicoZed Hardware Design How to use PL ***
  • Subscribers 358 subscribers
  • Views 767 views
How to use PL ***
vda
vda over 9 years ago
I works on Picozed 7020 Carrier Card V1
my  VHDL code:
 library IEEE;
 use IEEE.STD_LOGIC_1164.ALL;
 use IEEE.numeric_std.all;
 entity led is
    Port (
           clk : in  std_logic;
           switch : in  std_logic;
           led : out std_logic
 end led;
 architecture behav of led is
 begin
led <= clk;
 end behav;
CONTRAINTS:
  #OUTPUTS
  set_property PACKAGE_PIN Y9  [get_ports {led}]
  set_property PACKAGE_PIN V5  [get_ports {switch}]
  set_property IOSTANDARD LVCMOS33 [get_ports {led}]
  set_property IOSTANDARD LVCMOS33 [get_ports {switch}]
I want to see my clock on my output, but i don't know the access of PL clock. Could you give a solution pls ?
Thank u
Dass
  • jafoste4
    0 jafoste4 over 9 years ago
    Hello Dass,
    You can source clock from the PS to the PL in the Zynq Processor. Please refer to this post http://zedboard.org/content/ps-clock-pl
    --Josh
  • vda
    0 vda over 9 years ago
    Hello Josh,
    i already used the FCLK_CLK0. I putted this CLK on input but when program my FPGA, no result.
    I just want to see the FCLK_CLK0 on a output. Do you have a solution for that ?
    Dass.
  • jafoste4
    Hello Dass,
    Please take a look at these posts :
    https://forums.xilinx.com/t5/Zynq-All-Programmable-SoC/How-to-use-the-clock-gererated-from-PS-in-the-PL/td-p/540211
    https://forums.xilinx.com/t5/Embedded-Linux/enable-PL-clock-outputs/td-p/645886
    https://forums.xilinx.com/t5/Zynq-All-Programmable-SoC/Using-on-PL-a-Clock-generated-by-PS-on-MicroZed-Board-with-Zynq/td-p/423143
    http://picozed.org/content/generate-clock-pl-output-fmc-connector
    --Josh
