PicoZed Hardware Design Program picozed's QSPI flash through Ethernet
  • Subscribers 356 subscribers
  • Views 1353 views
  • picozed
ytian6870
ytian6870 over 6 years ago
I have a design that boots from QSPI on picozed board. The flash boot image consists of first stage boot loader (FSBL.elf),  FPGA (.bit) file and a standalone SDK application  (.elf) file (with TCP/IP Ethernet communication, no linux). I can program the QSPI from SDK via JTAG.  The picozed board will be installed in close box at a remote location.  I want to know if there is a document or a design that guide me to upgrade the QSPI image file via the Ethernet port.  This way, we can remote upgrade the firmware. I can image this might be a common user case.  From my understanding, the QSPI driver is available from SDK.  I need to know the Flash memory allocation of three files. If there is already a such design example, it will be great.
Thanks in advance for the help.
Larry
  • bhfletcher
    0 bhfletcher over 6 years ago
    This might have some useful information:
    https://www.xilinx.com/support/documentation/application_notes/xapp1224-secure-system-update.pdf
    Bryan
