PicoZed Hardware Design Picozed with Vitis Debugging
  • Subscribers 356 subscribers
  • Views 940 views
  • picozed
cthomas43
cthomas43 over 5 years ago
I am using a PicoZed with petalinux 2020.2 and Vitis 2020.2. I have been trying to debug over Vitis using tcf via ethernet connection. I have set up my local pc to a local IP and set up the picozed upon boot to a different IP on the same subnet. I am able to establish a connection over "target connections" via Linux Agent but when starting the debugger session, it doesnt launch.
What possible things could I check as I have tried using the out-of-the-box SD images, resetting the Vitis environment.
Thanks!
