Software Application Development Zynq 7000 Flashing Using Xilinx SDK
  • Subscribers 363 subscribers
  • Views 552 views
Hello All,
I am trying to program flash memory with the following:
1) System.bit file that has the hardware
2) bootloop.elf - FSBL (frist stage boot loop) created in SDK nothing was changed
3) helloword.elf created in the SDK
I am trying to figure out where to find the offset in the bootloop (FSBL) for the application. What address does the boot loop start reading from I don't know where that is in the code.
Please help.
    You can use the "Create Boot Image" utility in the SDK under 'Xilinx Tools' to create the boot image and the "Program Flash" utility, again in the SDK under 'Xilinx Tools' to write the image to the QSPI Flash..
    You don't mention which Zynq board you are using but Tutorial 04 for the MicroZed board found here details how to step through the process:
    http://www.zedboard.org/design/1519/10
    -Gary
