Software Application Development Read .txt (matrices) from SD to DDR - Zedboard
  • Subscribers 364 subscribers
  • Views 1652 views
jmales
jmales over 11 years ago
I'm converting a C algorithm into VHDL with Vivado HLS, and after exporting the RTL into Vivado and completing the design I'm using Xilinx SDK to right in the ARM9 PS.
Problem:
The algorithm is meant to normalize matrices that are kept on .txt files. My thought originally was to copy the .txt files to an SD card, mount it in the Zedboard and read the .txt files from it, copying the information to the DDRs. Problem is...I have no idea on how to do that. And here I was thinking that it was going to be a straightforward step -_-
I searched a lot of stuff, read a lot of threads and other than booting from an SD card I found nothing on this subject.
Please help me.
Note: I can already read/write to DDR with AXI DMA block. What I don't know is how to read a file from the PS that is on the SD card.
  • zedhed
    0 zedhed over 11 years ago
    Hi jmales,
    Reading and writing to the SD card without an operating system handling things for you can be tricky business.  However, others appear to be doing this using the xilffs library.
    http://zedboard.org/content/standalone-sd-card-sdio
    -Kevin
  • jmales
    0 jmales over 11 years ago
    So what do you suggest? What I learned and did with the Xilinx tools is aplicable only for the stanalone right? So if I put Linux running into the PS how am I able to connect with the IP blocks I made on the Vivado HLS?
    I'm really confused about this, give me some guidelines if possible mate
  • zedhed
    Hi jmales,
    Hmmm, that is a good point, writing the Linux drivers to access an HLS core is doable but not trivial.  If you only need to read data from the SD card, then the XilFFS library should work for your standalone application.
    Take a look at the LibXil FFS library documentation here:
    http://www.xilinx.com/support/documentation/sw_manuals/xilinx2014_4/oslib_rm.pdf
    You should also be able to find some example code in the XilinxSDK2014.4dataembeddedswlibsw_servicesxilffs_v2_2 folder on your Vivado + SDK development machine.  I tried this example code on my ZedBoard and it seems to be running just fine!
    -Kevin
  • jmales
    Yes man, that's what I was looking for. Also, combined with this: http://elm-chan.org/fsw/ff/00index_e.html
    I think I will be able to read .txt files from the SD card.
    Thank you
