Software Application Development GPIO MIOs from linux kernel
  • Subscribers 365 subscribers
  • Views 1108 views
oscargomezf
oscargomezf over 10 years ago
I would like to know how to access to GPIOs MIO from Linux kernel.
I'm not completely sure how to do that.
I can see in my picoZed in the /sys/class/gpio the folder gpiochip0 and inside this folder the file ngpio with a value of 64. But I not completely sure if this is the MIO GPIOs, because the MIO are 54 GPIOS:
MIO0 pins 0 to 15 -> connected to a 3.3Volts bank
MIO1 pins 16 to 53 -> connected to 1.8 Volts bank
Am I right or wrong?
Best regards.
  • jafoste4
    0 jafoste4 over 10 years ago
    Hello Oscargomezf,
    Try looking at our PetaLinux for Zynq Speedway we offer. It doesn't specifically target PicoZed, but you should be able to take some of the information there and apply it to what you are trying to do.
    http://zedboard.org/course/petalinux-zynq%C2%AE-7000-all-programmable-soc
    --Josh
  • oscargomezf
    0 oscargomezf over 10 years ago
    I was reading the /proc/device-tree/amba/gpio@e000a000 with a width of 64 bits. And I've tried to configure de PS_MIO51 as an input to check the PS_PB button in the PicoZed FMC Carrier V2:
    $ echo 51 > export
    $ echo in > 51/direction
    $ cat 51/value
    And when I pressed that button I've got and 1 and when the button is released I've got a 0, So it's working fine. But If I only have 54 GPIOS (From 0 to 53) Whats happen with the GPIOS from 54 to 63? I think It has to be a width of width instead of 54 because it has to be a power of 2 and If you try to access to the pins from 54 to 63 nothing happens, but I'm not completely sure.
    Best regards.
  • oscargomezf
    0 oscargomezf over 10 years ago in reply to oscargomezf
    Sorry, I made a typographic error, and I don't know how to modify this post:
    $ cd /sys/class/gpio
    $ echo 51 > export
    $ echo in > gpio51/direction
    $ cat gpio51/value
  • tylerduterrau
    0 tylerduterrau over 8 years ago
    thanks for this this is very use ful for me i wana like this
