Software Application Development Zedboard Tools and Techniques SDK error
  • Subscribers 363 subscribers
  • Views 612 views
XMD% connect arm hw
JTAG chain configuration
Device   ID Code        IR Length    Part Name
1       4ba00477           4        Cortex-A9
2       03727093           6        XC7Z020
Enabling extended memory access checks for Zynq.
Writes to reserved memory are not permitted and reads return 0.
To disable this feature, run "debugconfig -memory_access_check disable".
CortexA9 Processor Configuration
Version.............................0x00000003
User ID.............................0x00000000
No of PC Breakpoints................6
No of Addr/Data Watchpoints.........4
Connected to "arm" target. id = 64
Starting GDB server for "arm" target (id = 64) at TCP port no 1234
XMD% source D:/planahead/uboot/uboot.sdk/SDK/SDK_Export/hw/ps7_init.tcl
XMD% D:/planahead/uboot/stub.tcl
couldn't execute "D:planaheadubootstub.tcl": no such file or directory
XMD% source D:/planahead/uboot/stub.tcl
Connected to "arm" target. id = 65
Starting GDB server for "arm" target (id = 65) at TCP port no 1235
RUNNING> XMD% target 64
System(0 ) - Hardware System on FPGA(Device 1) Targets:
tTarget(64) - Cortex-A9(1) Hardware Debug Target*
tTarget(65) - Cortex-A9(2) Hardware Debug Target
tTarget(352) - Cortex-A9 CoreSight Debug Target
XMD% dow D:/planahead/uboot/u-boot.elf
Processor started. Type "stop" to stop processor
Downloading Program -- D:/planahead/uboot/u-boot.elf
tsection, .text: 0x04000000-0x04020c0b
tsection, .rodata: 0x04020c0c-0x0402740d
tsection, .hash: 0x04027410-0x0402744f
tsection, .data: 0x04027450-0x04027fcb
tsection, .got.plt: 0x04027fcc-0x04027fd7
tsection, .u_boot_cmd: 0x04027fd8-0x04028487
tsection, .rel.dyn: 0x04028488-0x0402cd1f
tsection, .dynsym: 0x0402cd20-0x0402cdcf
tsection, .bss: 0x04028488-0x0406b167
Download Progress.ERROR: Failed to download ELF file
tCannot access DDR: the controller is held in reset
XMD% debugconfig -memory_access_check disable
XMD% con
RUNNING> XMD% stop
Processor stopped
XMD%
XMD% dow -data D:/planahead/uboot/zImage.elf
Usage:  dow [<-data>] <filename> [<addr>]
XMD% dow -data D:/planahead/uboot/zImage.elf 0x8000
ERROR: Cannot OPEN File
t - D:/planahead/uboot/zImage.elf
User Interrupt, Processor Stopped at 0xfffffe1c
  • bhfletcher
    0 bhfletcher over 13 years ago
    Did you make sure to match the CTT version with your own tools' version?
    Bryan
    0 e14 Contributor over 13 years ago in reply to bhfletcher
    It took me a few days, I checked with the corresponding tool version, but I obtained the same result. I will try different Pc configuration. I have no explaneation about this error. I can not go trhu the tutorial because the dow command gives me error.
    Witning for help.
    Kind regards,
    Jozsef
    The problem is: I did not lunch the ps7_init command to initialize the Ps section.
    replace '/' by '//'
    source D://planahead//uboot//uboot.sdk//SDK//SDK_Export//hw//ps7_init.tcl
