Software Application Development PS-RST in SDK
  • Subscribers 364 subscribers
  • Views 470 views
PS-RST in SDK
I'm trying to restart the arm processor when I debug my software in SDK, but it doesn't work, and a error message shown.
I search for answer in www.xilinx.com, the answer I got below can't solve the problem because restart the arm processor may take several minutes.
http://www.xilinx.com/support/answers/37619.htm
After went through the schematic, I found that the PS-RST is connect to the JTAG programming chip through the buffer. That means the reset signal is support by hardware. So anyone here know how to restart the arm processor in SDK?
That would be a great help for me.
Zhou Peng
  • zedhed
    0 zedhed over 14 years ago
    Hi y595906642,
    I think you are correct that this is supported by the hardware signals that are present but I am not sure if this is currently supported by the tools or the onboard USB-JTAG.  The only plans I know of for this hardware reset would be through the use of the ARM DS-5 tools using DSTREAM.
    We will soon be coming out with an adapter for the 20-pin ARM JTAG cable which should make ZedBoard compatible with ARM tools for software development/debug.
    As for restarting the ARM processor from SDK, you could open a WebCase and see if there is a workaround for this in the existing tools.
    http://www.xilinx.com/support/clearexpress/websupport.htm
    -Kevin
    Zhou Peng,
    Did you open a web-case?  Were you able to get any feed back from Xilinx?  If not, I can do so and see what I can find.
  • zedhed
    0 zedhed over 13 years ago
    Hi Zhou Peng,
    I know this topic is a little old, but I wanted to append a URL for the adapter board mentioned above.
    http://www.em.avnet.com/zeddebugadapter
    It is useful for customers looking to attach their 20-pin debug cable such as DSTREAM to either ZedBoard or MicroZed.
    -Kevin
