Software Application Development ZedBoard 1Gbps Ethernet
  • Subscribers 364 subscribers
  • Views 864 views
Hi ,
How to configure Zed Board for 1Gbps Ethernet speed . using XAPP1026 application procedure , i am getting 350 Mbps speed with iperf Test. I followed same procedure given in this application note.
Can any body help for this issue.
Thanking you in advance.
  • zedhed
    0 zedhed over 10 years ago
    Hi Anil,
    When determining the data throughput over Ethernet, you have to consider a number of things including, but not limited to, the data path from the processor to the Ethernet MAC, the overhead of the protocol that is used, and the latency induced by any operating system which can include a number of data buffer transfers before it reaches the Ethernet hardware.  Also, another important thing to consider is the latency induced by the host that you are testing against.
    That being said, take a look at this project here which is a demo design from ExpressLogic showing the fastest throughput results that I have seen on ZedBoard:
    http://microzed.org/content/zedboard-threadx-rtosnetx-ethernet-performance-demo-design
    Using that example, you may be able to discover ways to get better performance numbers across the network interface.
    -Kevin
    0 e14 Contributor over 10 years ago in reply to zedhed
    Thank you Kevin.
    I am unable to download that example even after filling form.
  • zedhed
    0 zedhed over 10 years ago in reply to e14 Contributor
    Hi Anil,
    I have contacted express logic to verify that the download link is correct.  I will post back here when I find out more.
    -Kevin
  • zedhed
    Hi Anil,
    I received an email from ExpressLogic after completing the request form you mentioned.  Within the email is a download link along with an access password.
    If you did not receive an email after completing the form, you can try contacting ExpressLogic directly at the following email to request the demo download for ZedBoard:
    info@expresslogic.com
    -Kevin
