Software Application Development ZedBoard : can't use the PL under Xillinux ?
  • Replies 8 replies
  • Subscribers 366 subscribers
  • Views 1106 views
100gma
100gma over 12 years ago
hello,
i run Xillinux on Zedboard, but i can't found any documentation to use the PL for my application
so i contact the company, which create  Xillinux, check my discussion with support team of Xillinux:
hello
please can you create a forum on your website
many people, use Xillinux ( like me  ), what a space to communicate and share experience and problem
second thing,  i can't found, if Xillybus, make possible to run program into PL ( ZedBoard )
thank you
A forum for Xillinux has not been set up to allow the discussions being held in zedboard.org. As for your second question, loading the PL from Xillinux is not possible as is. Even though an interface exists, it's probably very difficult to program the PL part and remain with Linux running properly.
Best regards,
   Eli
hello
thank you for response
i didn't mean, program the PL, just how can i acces to PL ( i saw that Xillybus IP), can make this
in other mean, there is any possibility to run a program on PL, ( but the blue led is run, so PL is work )
thank you
am waiting for your suggestion and recommendation
thank you
    Please refer to the documentation at Xillybus' site for more information about what solutions the company offers for communication between the PL and PS (i.e. Xillybus and Xillybus Lite):
    http://xillybus.com/doc
    You may also find interest in the tutorials section,
    http://xillybus.com/tutorials
    in particular this item (which deals with coprocessing):
    http://xillybus.com/tutorials/vivado-hls-c-fpga-howto-1
    Other techniques are offered by Xilinx -- but I'll leave it to others to supply you with pointers.
    And please, copy-pasting emails sent in private into a public forum is a somewhat offensive act, even when their content is neutral. Unless this was the intention, I suggest refraining from that.
       Eli
  • 100gma
    0 100gma over 12 years ago in reply to e14 Contributor
    hello Eli,
    thank you for your response, i come here and also i past the email chat ( without names or email address, so i respect the private condition uses, i don't think it's an " offensive act ") and others reason, is th clear what i meet as a problem so people here can understand what i want and when i until to solve it, because, i can't found a solution for my application, i tried to read all documentation, also the support team of Xillinux, they don't respond in short time, sometime, i still more than one week without response.
    thank you for your recommendation, i will reback to documentation on Xillybus.
    as you said that you leave some point to other support team, i post an other subject on Xilinx forum : http://forums.xilinx.com/t5/Embedded-Linux/ZedBoard-can-t-use-the-PL-under-Xillinux/td-p/457040
    thank you and have a nice day
  • 100gma
    0 100gma over 12 years ago in reply to 100gma
    hello,
    i readed all tutorial " FPGA coprocessing: "( all part )
    maybe i will found a solution to integrate this layer or driver( Xillybus IP )into my application
    but i still have question about send and receive data through the FIFO  of xillybus IP :( ( can i send another traitement ?
    thank you
    Nice to see that you've seen some progress. I suggest experimenting with Xillybus to learn it: Let your own logic interact with the FIFOs connected to the Xillybus IP core, and see what happens on the computer's side.
       Eli
  • 100gma
    hello
    i think Xillybus is the best solution for my case ( application), so i think it's possible to run a communication between PS and PL, i read all documentation ( tutorial ), now i try to found ,how can adapt the driver for my needs.
    because i need to work on Xillinux as linux Os also, because i need a graphic platform to see the result of my application, i think it still 20 % to complete my project ;)
    if i need some help, i will post here ( just to shared knowledgment, but if i need a specific information i will contact you by email.
    have a nice day
    I am working on a project on ZEDBOARD.
    I was following the tutorial given on your website for : http://xillybus.com/tutorials/vivado-hls-c-fpga-howto-1.
    I was able to boot up the xillinux on board and I also passed the loop back test as given in section 3.3 of this manual : http://xillybus.com/downloads/doc/xillybus_getting_started_linux.pdf.
    I then modified my verilog files as per the tutrial and generated a bit file in ISE by integrating all files from HLS with the previous files. Now when I try to run the HLS demo program I am unable to get the expected output.
    Even after modifying the verilog code when I try the loop back test for both 8 bit and 32 bit , I am able to successfully complete it . But when I run the HLS demo code I get the same number which I have sent in my C program and no addition or sin calculation takes place. I believe data is not being sent from PS to PL.
    I would be really great full if you could please help me in this regard and suggest what are the steps I am missing in my implementation.
    Thank you.
  • 100mihai
    0 100mihai over 9 years ago in reply to 100gma
    Hi GMA,
       Did you manage to program PL through Xillinux rtos ?
  • jafoste4
    0 jafoste4 over 9 years ago in reply to 100mihai
    Hello Mihai,
    You may recieve better support asking Xillybus directly
    http://xillybus.com/contact
    --Josh
