Software Application Development Linux: Generating a Device Tree (DTS) file on Zynq-7000
  • Subscribers 363 subscribers
  • Views 1057 views
I just managed to automatically create a DTS file for Zynq-7020 using libgen, using the device-tree package.
I describe how to do it here:
http://billauer.co.il/blog/?p=2970
But then I noted that Xilinx' relevant Wiki page says this flow isn't supported. So is the Wiki page outdated, or did I just create a DTS file worth nothing?
The said wiki page is: http://wiki.xilinx.com/zynq-linux#toc14
I would, of course, love to try it out myself, but my Zedboard hasn't arrived yet... (hint, hint).
Cheers,
   Eli
    I'll answer this myself: As the post says now, the DTS file isn't usable.
    Hi eli,
    To create DTS file for ZedBoard, the ZC702 default devicetree file can be used as a template with following changes:
    1. change Memory size to 512mb.
    2. remove i2c node
    3. modify the ethernet phy as ZC702 and ZedBoard use different phy.
    Make sure the FSBL is also rebuilt for ZedBoard.
    0 e14 Contributor over 14 years ago in reply to e14 Contributor
    How to modify?
    How to modify?
    I have posted an example ethernet phy configuration here:
    http://zynqlab.blogspot.com.au/2012/08/zedboard-ethernet-device-tree.html
    I can't open the web, what problem?
