Software Application Development PS I2C ZedBoard
  • Subscribers 365 subscribers
  • Views 1736 views
PS I2C ZedBoard
I am trying to get the I2C 0 Peripheral to work on the ZedBoard. I have set up I2C 0 to connect the MIO10 and MIO11 pins to the PMOD header. I then built the linux kernel using the linux-xlnx git source. When in linux any command that is used on the i2c times out.
The following are console outputs:
zynq> i2cdetect -l 0
i2c-0   i2c             XILINX I2C at e0004000            I2C adapter
zynq> i2cdetect 0
Error: Can't use SMBus Quick Write command on this bus
zynq> i2cdetect -r 0
WARNING! This program can confuse your I2C bus, cause data loss and worse!
I will probe file /dev/i2c-0 using read byte commands.
I will probe address range 0x03-0x77.
Continue? [Y/n] y
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:          xi2cps e0004000.ps7-i2c: timeout waiting on completion
-- xi2cps e0004000.ps7-i2c: timeout waiting on completion
...there is more but i cut it off
    I modified the zynq-zed.dts file in the linux-xlnx/arch/arm/boot/dts folder to contain the following under ps7_axi_interconnect_0: amba@0 {
    ps7_i2c_0: ps7-i2c@e0004000 {
    tttbus-id = <0>;
    tttclocks = <&clkc 38>;
    tttcompatible = "xlnx,ps7-i2c-1.00.a";
    tttinterrupt-parent = <&ps7_scugic_0>;
    tttinterrupts = <0 25 4>;
    tttreg = <0xe0004000 0x1000>;
    ttti2c-clk = <400000>;
    ttt#address-cells = <1>;
    ttt#size-cells = <0>;
    ttt
    ttteeprom@50 {
    ttttcompatible = "at,24c08";
    ttttreg = <0x50>;
    ttt};
    ttt
    tt} ;
    The kernel config file is as follows
    # Automatically generated file; DO NOT EDIT.
    # Linux/arm 3.12.0 Kernel Configuration
    CONFIG_ARM=y
    CONFIG_MIGHT_HAVE_PCI=y
    CONFIG_SYS_SUPPORTS_APM_EMULATION=y
    CONFIG_HAVE_PROC_CPU=y
    CONFIG_NO_IOPORT=y
    CONFIG_STACKTRACE_SUPPORT=y
    CONFIG_LOCKDEP_SUPPORT=y
    CONFIG_TRACE_IRQFLAGS_SUPPORT=y
    CONFIG_RWSEM_GENERIC_SPINLOCK=y
    CONFIG_ARCH_HAS_CPUFREQ=y
    CONFIG_GENERIC_HWEIGHT=y
    CONFIG_GENERIC_CALIBRATE_DELAY=y
    CONFIG_NEED_DMA_MAP_STATE=y
    CONFIG_VECTORS_BASE=0xffff0000
    CONFIG_ARM_PATCH_PHYS_VIRT=y
    CONFIG_GENERIC_BUG=y
    CONFIG_DEFCONFIG_LIST="/lib/modules/$UNAME_RELEASE/.config"
    CONFIG_IRQ_WORK=y
    CONFIG_BUILDTIME_EXTABLE_SORT=y
    # General setup
    CONFIG_INIT_ENV_ARG_LIMIT=32
    CONFIG_CROSS_COMPILE=""
    # CONFIG_COMPILE_TEST is not set
    CONFIG_LOCALVERSION="-xilinx"
    CONFIG_LOCALVERSION_AUTO=y
    CONFIG_HAVE_KERNEL_GZIP=y
    CONFIG_HAVE_KERNEL_LZMA=y
    CONFIG_HAVE_KERNEL_XZ=y
    CONFIG_HAVE_KERNEL_LZO=y
    CONFIG_HAVE_KERNEL_LZ4=y
    CONFIG_KERNEL_GZIP=y
    # CONFIG_KERNEL_LZMA is not set
    # CONFIG_KERNEL_XZ is not set
    # CONFIG_KERNEL_LZO is not set
    # CONFIG_KERNEL_LZ4 is not set
    CONFIG_DEFAULT_HOSTNAME="(none)"
    CONFIG_SWAP=y
    CONFIG_SYSVIPC=y
    CONFIG_SYSVIPC_SYSCTL=y
    # CONFIG_POSIX_MQUEUE is not set
    # CONFIG_FHANDLE is not set
    # CONFIG_AUDIT is not set
    # IRQ subsystem
    CONFIG_GENERIC_IRQ_PROBE=y
    CONFIG_GENERIC_IRQ_SHOW=y
    CONFIG_HARDIRQS_SW_RESEND=y
    CONFIG_GENERIC_IRQ_CHIP=y
    CONFIG_IRQ_DOMAIN=y
    CONFIG_IRQ_DOMAIN_DEBUG=y
    CONFIG_IRQ_FORCED_THREADING=y
    CONFIG_SPARSE_IRQ=y
    CONFIG_KTIME_SCALAR=y
    CONFIG_GENERIC_CLOCKEVENTS=y
    CONFIG_GENERIC_CLOCKEVENTS_BUILD=y
    CONFIG_ARCH_HAS_TICK_BROADCAST=y
    CONFIG_GENERIC_CLOCKEVENTS_BROADCAST=y
    # Timers subsystem
    CONFIG_TICK_ONESHOT=y
    CONFIG_NO_HZ_COMMON=y
    # CONFIG_HZ_PERIODIC is not set
    CONFIG_NO_HZ_IDLE=y
    CONFIG_NO_HZ=y
    CONFIG_HIGH_RES_TIMERS=y
    # CPU/Task time and stats accounting
    CONFIG_TICK_CPU_ACCOUNTING=y
    # CONFIG_IRQ_TIME_ACCOUNTING is not set
    # CONFIG_BSD_PROCESS_ACCT is not set
    # CONFIG_TASKSTATS is not set
    # RCU Subsystem
    CONFIG_TREE_PREEMPT_RCU=y
    CONFIG_PREEMPT_RCU=y
    CONFIG_RCU_STALL_COMMON=y
    # CONFIG_RCU_USER_QS is not set
    CONFIG_RCU_FANOUT=32
    CONFIG_RCU_FANOUT_LEAF=16
    # CONFIG_RCU_FANOUT_EXACT is not set
    # CONFIG_RCU_FAST_NO_HZ is not set
    # CONFIG_TREE_RCU_TRACE is not set
    # CONFIG_RCU_BOOST is not set
    # CONFIG_RCU_NOCB_CPU is not set
    CONFIG_IKCONFIG=y
    CONFIG_IKCONFIG_PROC=y
    CONFIG_LOG_BUF_SHIFT=14
    CONFIG_GENERIC_SCHED_CLOCK=y
    # CONFIG_CGROUPS is not set
    # CONFIG_CHECKPOINT_RESTORE is not set
    # CONFIG_NAMESPACES is not set
    # CONFIG_UIDGID_STRICT_TYPE_CHECKS is not set
    # CONFIG_SCHED_AUTOGROUP is not set
    CONFIG_SYSFS_DEPRECATED=y
    CONFIG_SYSFS_DEPRECATED_V2=y
    # CONFIG_RELAY is not set
    CONFIG_BLK_DEV_INITRD=y
    CONFIG_INITRAMFS_SOURCE=""
    CONFIG_RD_GZIP=y
    # CONFIG_RD_BZIP2 is not set
    # CONFIG_RD_LZMA is not set
    # CONFIG_RD_XZ is not set
    # CONFIG_RD_LZO is not set
    # CONFIG_RD_LZ4 is not set
    CONFIG_CC_OPTIMIZE_FOR_SIZE=y
    CONFIG_SYSCTL=y
    CONFIG_ANON_INODES=y
    CONFIG_HAVE_UID16=y
    CONFIG_EXPERT=y
    CONFIG_UID16=y
    CONFIG_SYSCTL_SYSCALL=y
    CONFIG_KALLSYMS=y
    # CONFIG_KALLSYMS_ALL is not set
    CONFIG_PRINTK=y
    CONFIG_BUG=y
    CONFIG_ELF_CORE=y
    CONFIG_BASE_FULL=y
    CONFIG_FUTEX=y
    CONFIG_EPOLL=y
    CONFIG_SIGNALFD=y
    CONFIG_TIMERFD=y
    CONFIG_EVENTFD=y
    CONFIG_SHMEM=y
    CONFIG_AIO=y
    CONFIG_PCI_QUIRKS=y
    CONFIG_EMBEDDED=y
    CONFIG_HAVE_PERF_EVENTS=y
    CONFIG_PERF_USE_VMALLOC=y
    # Kernel Performance Events And Counters
    CONFIG_PERF_EVENTS=y
    # CONFIG_DEBUG_PERF_USE_VMALLOC is not set
    CONFIG_VM_EVENT_COUNTERS=y
    CONFIG_COMPAT_BRK=y
    CONFIG_SLAB=y
    # CONFIG_SLUB is not set
    # CONFIG_SLOB is not set
    # CONFIG_PROFILING is not set
    CONFIG_HAVE_OPROFILE=y
    # CONFIG_KPROBES is not set
    # CONFIG_JUMP_LABEL is not set
    # CONFIG_HAVE_64BIT_ALIGNED_ACCESS is not set
    CONFIG_HAVE_KPROBES=y
    CONFIG_HAVE_KRETPROBES=y
    CONFIG_HAVE_ARCH_TRACEHOOK=y
    CONFIG_HAVE_DMA_ATTRS=y
    CONFIG_HAVE_DMA_CONTIGUOUS=y
    CONFIG_USE_GENERIC_SMP_HELPERS=y
    CONFIG_GENERIC_SMP_IDLE_THREAD=y
    CONFIG_GENERIC_IDLE_POLL_SETUP=y
    CONFIG_HAVE_REGS_AND_STACK_ACCESS_API=y
    CONFIG_HAVE_CLK=y
    CONFIG_HAVE_DMA_API_DEBUG=y
    CONFIG_HAVE_HW_BREAKPOINT=y
    CONFIG_HAVE_ARCH_JUMP_LABEL=y
    CONFIG_ARCH_WANT_IPC_PARSE_VERSION=y
    CONFIG_HAVE_ARCH_SECCOMP_FILTER=y
    CONFIG_HAVE_CONTEXT_TRACKING=y
    CONFIG_HAVE_IRQ_TIME_ACCOUNTING=y
    CONFIG_HAVE_MOD_ARCH_SPECIFIC=y
    CONFIG_MODULES_USE_ELF_REL=y
    CONFIG_CLONE_BACKWARDS=y
    CONFIG_OLD_SIGSUSPEND3=y
    CONFIG_OLD_SIGACTION=y
    # GCOV-based kernel profiling
    # CONFIG_GCOV_KERNEL is not set
    CONFIG_HAVE_GENERIC_DMA_COHERENT=y
    CONFIG_SLABINFO=y
    CONFIG_RT_MUTEXES=y
    CONFIG_BASE_SMALL=0
    CONFIG_MODULES=y
    # CONFIG_MODULE_FORCE_LOAD is not set
    CONFIG_MODULE_UNLOAD=y
    CONFIG_MODULE_FORCE_UNLOAD=y
    CONFIG_MODVERSIONS=y
    # CONFIG_MODULE_SRCVERSION_ALL is not set
    # CONFIG_MODULE_SIG is not set
    CONFIG_STOP_MACHINE=y
    CONFIG_BLOCK=y
    CONFIG_LBDAF=y
    # CONFIG_BLK_DEV_BSG is not set
    # CONFIG_BLK_DEV_BSGLIB is not set
    # CONFIG_BLK_DEV_INTEGRITY is not set
    # CONFIG_BLK_CMDLINE_PARSER is not set
    # Partition Types
    # CONFIG_PARTITION_ADVANCED is not set
    CONFIG_MSDOS_PARTITION=y
    CONFIG_EFI_PARTITION=y
    # IO Schedulers
    CONFIG_IOSCHED_NOOP=y
    CONFIG_IOSCHED_DEADLINE=y
    CONFIG_IOSCHED_CFQ=y
    # CONFIG_DEFAULT_DEADLINE is not set
    CONFIG_DEFAULT_CFQ=y
    # CONFIG_DEFAULT_NOOP is not set
    CONFIG_DEFAULT_IOSCHED="cfq"
    CONFIG_UNINLINE_SPIN_UNLOCK=y
    CONFIG_MUTEX_SPIN_ON_OWNER=y
    CONFIG_FREEZER=y
    # System Type
    CONFIG_MMU=y
    CONFIG_ARCH_MULTIPLATFORM=y
    # CONFIG_ARCH_INTEGRATOR is not set
    # CONFIG_ARCH_REALVIEW is not set
    # CONFIG_ARCH_VERSATILE is not set
    # CONFIG_ARCH_AT91 is not set
    # CONFIG_ARCH_CLPS711X is not set
    # CONFIG_ARCH_GEMINI is not set
    # CONFIG_ARCH_EBSA110 is not set
    # CONFIG_ARCH_EP93XX is not set
    # CONFIG_ARCH_FOOTBRIDGE is not set
    # CONFIG_ARCH_NETX is not set
    # CONFIG_ARCH_IOP13XX is not set
    # CONFIG_ARCH_IOP32X is not set
    # CONFIG_ARCH_IOP33X is not set
    # CONFIG_ARCH_IXP4XX is not set
    # CONFIG_ARCH_DOVE is not set
    # CONFIG_ARCH_KIRKWOOD is not set
    # CONFIG_ARCH_MV78XX0 is not set
    # CONFIG_ARCH_ORION5X is not set
    # CONFIG_ARCH_MMP is not set
    # CONFIG_ARCH_KS8695 is not set
    # CONFIG_ARCH_W90X900 is not set
    # CONFIG_ARCH_LPC32XX is not set
    # CONFIG_ARCH_PXA is not set
    # CONFIG_ARCH_MSM is not set
    # CONFIG_ARCH_SHMOBILE is not set
    # CONFIG_ARCH_RPC is not set
    # CONFIG_ARCH_SA1100 is not set
    # CONFIG_ARCH_S3C24XX is not set
    # CONFIG_ARCH_S3C64XX is not set
    # CONFIG_ARCH_S5P64X0 is not set
    # CONFIG_ARCH_S5PC100 is not set
    # CONFIG_ARCH_S5PV210 is not set
    # CONFIG_ARCH_EXYNOS is not set
    # CONFIG_ARCH_SHARK is not set
    # CONFIG_ARCH_DAVINCI is not set
    # CONFIG_ARCH_OMAP1 is not set
    # Multiple platform selection
    # CPU Core family selection
    # CONFIG_ARCH_MULTI_V6 is not set
    CONFIG_ARCH_MULTI_V7=y
    CONFIG_ARCH_MULTI_V6_V7=y
    # CONFIG_ARCH_MULTI_CPU_AUTO is not set
    # CONFIG_ARCH_MVEBU is not set
    # CONFIG_ARCH_BCM is not set
    # CONFIG_GPIO_PCA953X is not set
    # CONFIG_KEYBOARD_GPIO_POLLED is not set
    # CONFIG_ARCH_HIGHBANK is not set
    # CONFIG_ARCH_KEYSTONE is not set
    # CONFIG_ARCH_MXC is not set
    # CONFIG_ARCH_OMAP3 is not set
    # CONFIG_ARCH_OMAP4 is not set
    # CONFIG_SOC_OMAP5 is not set
    # CONFIG_SOC_AM33XX is not set
    # CONFIG_SOC_AM43XX is not set
    # CONFIG_ARCH_ROCKCHIP is not set
    # CONFIG_ARCH_SOCFPGA is not set
    # CONFIG_PLAT_SPEAR is not set
    # CONFIG_ARCH_STI is not set
    # CONFIG_ARCH_SHMOBILE_MULTI is not set
    # CONFIG_ARCH_SUNXI is not set
    # CONFIG_ARCH_SIRF is not set
    # CONFIG_ARCH_TEGRA is not set
    # CONFIG_ARCH_U8500 is not set
    CONFIG_ARCH_VEXPRESS=y
    # Versatile Express platform type
    CONFIG_ARCH_VEXPRESS_CORTEX_A5_A9_ERRATA=y
    # CONFIG_ARCH_VEXPRESS_CA9X4 is not set
    CONFIG_PLAT_VERSATILE_CLCD=y
    CONFIG_PLAT_VERSATILE_SCHED_CLOCK=y
    # CONFIG_ARCH_VIRT is not set
    # CONFIG_ARCH_WM8850 is not set
    CONFIG_ARCH_ZYNQ=y
    # Xilinx Specific Options
    CONFIG_XILINX_L1_PREFETCH=y
    CONFIG_XILINX_L2_PREFETCH=y
    CONFIG_XILINX_AXIPCIE=y
    CONFIG_PLAT_VERSATILE=y
    CONFIG_ARM_TIMER_SP804=y
    # Processor Type
    CONFIG_CPU_V7=y
    CONFIG_CPU_32v6K=y
    CONFIG_CPU_32v7=y
    CONFIG_CPU_ABRT_EV7=y
    CONFIG_CPU_PABRT_V7=y
    CONFIG_CPU_CACHE_V7=y
    CONFIG_CPU_CACHE_VIPT=y
    CONFIG_CPU_COPY_V6=y
    CONFIG_CPU_TLB_V7=y
    CONFIG_CPU_HAS_ASID=y
    CONFIG_CPU_CP15=y
    CONFIG_CPU_CP15_MMU=y
    # Processor Features
    # CONFIG_ARM_LPAE is not set
    # CONFIG_ARCH_PHYS_ADDR_T_64BIT is not set
    CONFIG_ARM_THUMB=y
    # CONFIG_ARM_THUMBEE is not set
    CONFIG_ARM_VIRT_EXT=y
    CONFIG_SWP_EMULATE=y
    # CONFIG_CPU_ICACHE_DISABLE is not set
    # CONFIG_CPU_DCACHE_DISABLE is not set
    # CONFIG_CPU_BPREDICT_DISABLE is not set
    CONFIG_KUSER_HELPERS=y
    CONFIG_OUTER_CACHE=y
    CONFIG_OUTER_CACHE_SYNC=y
    CONFIG_MIGHT_HAVE_CACHE_L2X0=y
    CONFIG_CACHE_L2X0=y
    CONFIG_CACHE_PL310=y
    CONFIG_ARM_L1_CACHE_SHIFT_6=y
    CONFIG_ARM_L1_CACHE_SHIFT=6
    CONFIG_ARM_DMA_MEM_BUFFERABLE=y
    CONFIG_ARM_NR_BANKS=8
    CONFIG_MULTI_IRQ_HANDLER=y
    # CONFIG_ARM_ERRATA_430973 is not set
    CONFIG_PL310_ERRATA_588369=y
    # CONFIG_ARM_ERRATA_643719 is not set
    CONFIG_ARM_ERRATA_720789=y
    CONFIG_PL310_ERRATA_727915=y
    CONFIG_PL310_ERRATA_753970=y
    CONFIG_ARM_ERRATA_754322=y
    CONFIG_ARM_ERRATA_754327=y
    CONFIG_ARM_ERRATA_764369=y
    CONFIG_PL310_ERRATA_769419=y
    CONFIG_ARM_ERRATA_775420=y
    # CONFIG_ARM_ERRATA_798181 is not set
    # CONFIG_ARM_ERRATA_773022 is not set
    CONFIG_ICST=y
    # Bus support
    CONFIG_ARM_AMBA=y
    CONFIG_PCI=y
    CONFIG_PCI_SYSCALL=y
    CONFIG_PCI_MSI=y
    # CONFIG_PCI_DEBUG is not set
    # CONFIG_PCI_REALLOC_ENABLE_AUTO is not set
    # CONFIG_PCI_STUB is not set
    # CONFIG_PCI_IOV is not set
    # CONFIG_PCI_PRI is not set
    # CONFIG_PCI_PASID is not set
    # PCI host controller drivers
    # CONFIG_PCIEPORTBUS is not set
    # CONFIG_PCCARD is not set
    # Kernel Features
    CONFIG_HAVE_SMP=y
    CONFIG_SMP=y
    CONFIG_SMP_ON_UP=y
    CONFIG_ARM_CPU_TOPOLOGY=y
    CONFIG_SCHED_MC=y
    CONFIG_SCHED_SMT=y
    CONFIG_HAVE_ARM_SCU=y
    # CONFIG_HAVE_ARM_ARCH_TIMER is not set
    CONFIG_HAVE_ARM_TWD=y
    # CONFIG_MCPM is not set
    CONFIG_VMSPLIT_3G=y
    # CONFIG_VMSPLIT_2G is not set
    # CONFIG_VMSPLIT_1G is not set
    CONFIG_PAGE_OFFSET=0xC0000000
    CONFIG_NR_CPUS=4
    CONFIG_HOTPLUG_CPU=y
    # CONFIG_ARM_PSCI is not set
    CONFIG_ARCH_NR_GPIO=1024
    # CONFIG_PREEMPT_NONE is not set
    # CONFIG_PREEMPT_VOLUNTARY is not set
    CONFIG_PREEMPT=y
    CONFIG_PREEMPT_COUNT=y
    CONFIG_HZ_FIXED=0
    CONFIG_HZ_100=y
    # CONFIG_HZ_200 is not set
    # CONFIG_HZ_250 is not set
    # CONFIG_HZ_300 is not set
    # CONFIG_HZ_500 is not set
    # CONFIG_HZ_1000 is not set
    CONFIG_HZ=100
    CONFIG_SCHED_HRTICK=y
    # CONFIG_THUMB2_KERNEL is not set
    CONFIG_AEABI=y
    # CONFIG_OABI_COMPAT is not set
    # CONFIG_ARCH_SPARSEMEM_DEFAULT is not set
    # CONFIG_ARCH_SELECT_MEMORY_MODEL is not set
    CONFIG_HAVE_ARCH_PFN_VALID=y
    CONFIG_HIGHMEM=y
    # CONFIG_HIGHPTE is not set
    CONFIG_HW_PERF_EVENTS=y
    CONFIG_ARCH_WANT_GENERAL_HUGETLB=y
    CONFIG_FLATMEM=y
    CONFIG_FLAT_NODE_MEM_MAP=y
    CONFIG_HAVE_MEMBLOCK=y
    CONFIG_MEMORY_ISOLATION=y
    # CONFIG_HAVE_BOOTMEM_INFO_NODE is not set
    CONFIG_PAGEFLAGS_EXTENDED=y
    CONFIG_SPLIT_PTLOCK_CPUS=4
    # CONFIG_COMPACTION is not set
    CONFIG_MIGRATION=y
    # CONFIG_PHYS_ADDR_T_64BIT is not set
    CONFIG_ZONE_DMA_FLAG=0
    CONFIG_BOUNCE=y
    # CONFIG_KSM is not set
    CONFIG_DEFAULT_MMAP_MIN_ADDR=4096
    CONFIG_CROSS_MEMORY_ATTACH=y
    # CONFIG_CLEANCACHE is not set
    # CONFIG_FRONTSWAP is not set
    CONFIG_CMA=y
    # CONFIG_CMA_DEBUG is not set
    # CONFIG_ZBUD is not set
    CONFIG_FORCE_MAX_ZONEORDER=11
    CONFIG_ALIGNMENT_TRAP=y
    # CONFIG_UACCESS_WITH_MEMCPY is not set
    # CONFIG_SECCOMP is not set
    # CONFIG_CC_STACKPROTECTOR is not set
    # CONFIG_XEN is not set
    # Boot options
    CONFIG_USE_OF=y
    CONFIG_ATAGS=y
    # CONFIG_DEPRECATED_PARAM_STRUCT is not set
    CONFIG_ZBOOT_ROM_TEXT=0x0
    CONFIG_ZBOOT_ROM_BSS=0x0
    # CONFIG_ARM_APPENDED_DTB is not set
    CONFIG_CMDLINE="console=ttyPS0,115200n8 root=/dev/ram rw initrd=0x00800000,16M earlyprintk mtdparts=physmap-flash.0:512K(nor-fsbl),512K(nor-u-boot),5M(nor-linux),9M(nor-user),1M(nor-scratch),-(nor-rootfs)"
    CONFIG_CMDLINE_FROM_BOOTLOADER=y
    # CONFIG_CMDLINE_EXTEND is not set
    # CONFIG_CMDLINE_FORCE is not set
    # CONFIG_KEXEC is not set
    # CONFIG_CRASH_DUMP is not set
    CONFIG_AUTO_ZRELADDR=y
    # CPU Power Management
    # CPU Frequency scaling
    CONFIG_CPU_FREQ=y
    CONFIG_CPU_FREQ_TABLE=y
    CONFIG_CPU_FREQ_GOV_COMMON=y
    CONFIG_CPU_FREQ_STAT=y
    CONFIG_CPU_FREQ_STAT_DETAILS=y
    # CONFIG_CPU_FREQ_DEFAULT_GOV_PERFORMANCE is not set
    # CONFIG_CPU_FREQ_DEFAULT_GOV_POWERSAVE is not set
    CONFIG_CPU_FREQ_DEFAULT_GOV_USERSPACE=y
    # CONFIG_CPU_FREQ_DEFAULT_GOV_ONDEMAND is not set
    # CONFIG_CPU_FREQ_DEFAULT_GOV_CONSERVATIVE is not set
    CONFIG_CPU_FREQ_GOV_PERFORMANCE=y
    CONFIG_CPU_FREQ_GOV_POWERSAVE=y
    CONFIG_CPU_FREQ_GOV_USERSPACE=y
    CONFIG_CPU_FREQ_GOV_ONDEMAND=y
    CONFIG_CPU_FREQ_GOV_CONSERVATIVE=y
    # ARM CPU frequency scaling drivers
    # CONFIG_ARM_BIG_LITTLE_CPUFREQ is not set
    # CONFIG_ARM_KIRKWOOD_CPUFREQ is not set
    CONFIG_ARM_ZYNQ_CPUFREQ=y
    # CPU Idle
    # CONFIG_CPU_IDLE is not set
    # CONFIG_ARCH_NEEDS_CPU_IDLE_COUPLED is not set
    # Floating point emulation
    # At least one emulation must be selected
    CONFIG_VFP=y
    CONFIG_VFPv3=y
    CONFIG_NEON=y
    # CONFIG_KERNEL_MODE_NEON is not set
    # Userspace binary formats
    CONFIG_BINFMT_ELF=y
    CONFIG_ARCH_BINFMT_ELF_RANDOMIZE_PIE=y
    # CONFIG_CORE_DUMP_DEFAULT_ELF_HEADERS is not set
    CONFIG_BINFMT_SCRIPT=y
    # CONFIG_HAVE_AOUT is not set
    # CONFIG_BINFMT_MISC is not set
    CONFIG_COREDUMP=y
    # Power management options
    CONFIG_SUSPEND=y
    CONFIG_SUSPEND_FREEZER=y
    CONFIG_PM_SLEEP=y
    CONFIG_PM_SLEEP_SMP=y
    # CONFIG_PM_AUTOSLEEP is not set
    # CONFIG_PM_WAKELOCKS is not set
    CONFIG_PM_RUNTIME=y
    CONFIG_PM=y
    # CONFIG_PM_DEBUG is not set
    # CONFIG_APM_EMULATION is not set
    CONFIG_ARCH_HAS_OPP=y
    CONFIG_PM_OPP=y
    CONFIG_PM_CLK=y
    # CONFIG_WQ_POWER_EFFICIENT_DEFAULT is not set
    CONFIG_CPU_PM=y
    CONFIG_ARCH_SUSPEND_POSSIBLE=y
    CONFIG_ARM_CPU_SUSPEND=y
    CONFIG_NET=y
    # Networking options
    CONFIG_PACKET=y
    # CONFIG_PACKET_DIAG is not set
    CONFIG_UNIX=y
    # CONFIG_UNIX_DIAG is not set
    CONFIG_XFRM=y
    # CONFIG_XFRM_USER is not set
    # CONFIG_XFRM_SUB_POLICY is not set
    # CONFIG_XFRM_MIGRATE is not set
    # CONFIG_XFRM_STATISTICS is not set
    # CONFIG_NET_KEY is not set
    CONFIG_INET=y
    CONFIG_IP_MULTICAST=y
    # CONFIG_IP_ADVANCED_ROUTER is not set
    CONFIG_IP_PNP=y
    CONFIG_IP_PNP_DHCP=y
    CONFIG_IP_PNP_BOOTP=y
    CONFIG_IP_PNP_RARP=y
    CONFIG_NET_IPIP=m
    # CONFIG_NET_IPGRE_DEMUX is not set
    CONFIG_NET_IP_TUNNEL=m
    # CONFIG_IP_MROUTE is not set
    # CONFIG_SYN_COOKIES is not set
    # CONFIG_NET_IPVTI is not set
    # CONFIG_INET_AH is not set
    # CONFIG_INET_ESP is not set
    # CONFIG_INET_IPCOMP is not set
    # CONFIG_INET_XFRM_TUNNEL is not set
    CONFIG_INET_TUNNEL=m
    CONFIG_INET_XFRM_MODE_TRANSPORT=y
    CONFIG_INET_XFRM_MODE_TUNNEL=y
    CONFIG_INET_XFRM_MODE_BEET=y
    CONFIG_INET_LRO=y
    CONFIG_INET_DIAG=y
    CONFIG_INET_TCP_DIAG=y
    # CONFIG_INET_UDP_DIAG is not set
    # CONFIG_TCP_CONG_ADVANCED is not set
    CONFIG_TCP_CONG_CUBIC=y
    CONFIG_DEFAULT_TCP_CONG="cubic"
    # CONFIG_TCP_MD5SIG is not set
    CONFIG_IPV6=m
    # CONFIG_IPV6_PRIVACY is not set
    # CONFIG_IPV6_ROUTER_PREF is not set
    # CONFIG_IPV6_OPTIMISTIC_DAD is not set
    # CONFIG_INET6_AH is not set
    # CONFIG_INET6_ESP is not set
    # CONFIG_INET6_IPCOMP is not set
    # CONFIG_IPV6_MIP6 is not set
    # CONFIG_INET6_XFRM_TUNNEL is not set
    # CONFIG_INET6_TUNNEL is not set
    CONFIG_INET6_XFRM_MODE_TRANSPORT=m
    CONFIG_INET6_XFRM_MODE_TUNNEL=m
    CONFIG_INET6_XFRM_MODE_BEET=m
    # CONFIG_INET6_XFRM_MODE_ROUTEOPTIMIZATION is not set
    CONFIG_IPV6_SIT=m
    # CONFIG_IPV6_SIT_6RD is not set
    CONFIG_IPV6_NDISC_NODETYPE=y
    # CONFIG_IPV6_TUNNEL is not set
    # CONFIG_IPV6_GRE is not set
    # CONFIG_IPV6_MULTIPLE_TABLES is not set
    # CONFIG_IPV6_MROUTE is not set
    # CONFIG_NETWORK_SECMARK is not set
    # CONFIG_NETWORK_PHY_TIMESTAMPING is not set
    # CONFIG_NETFILTER is not set
    # CONFIG_IP_DCCP is not set
    # CONFIG_IP_SCTP is not set
    # CONFIG_RDS is not set
    # CONFIG_TIPC is not set
    # CONFIG_ATM is not set
    # CONFIG_L2TP is not set
    # CONFIG_BRIDGE is not set
    CONFIG_HAVE_NET_DSA=y
    CONFIG_VLAN_8021Q=m
    # CONFIG_VLAN_8021Q_GVRP is not set
    # CONFIG_VLAN_8021Q_MVRP is not set
    # CONFIG_DECNET is not set
    # CONFIG_LLC2 is not set
    # CONFIG_IPX is not set
    # CONFIG_ATALK is not set
    # CONFIG_X25 is not set
    # CONFIG_LAPB is not set
    # CONFIG_PHONET is not set
    # CONFIG_IEEE802154 is not set
    # CONFIG_NET_SCHED is not set
    # CONFIG_DCB is not set
    # CONFIG_BATMAN_ADV is not set
    # CONFIG_OPENVSWITCH is not set
    # CONFIG_VSOCKETS is not set
    # CONFIG_NETLINK_MMAP is not set
    # CONFIG_NETLINK_DIAG is not set
    # CONFIG_NET_MPLS_GSO is not set
    CONFIG_RPS=y
    CONFIG_RFS_ACCEL=y
    CONFIG_XPS=y
    CONFIG_NET_RX_BUSY_POLL=y
    CONFIG_BQL=y
    # CONFIG_BPF_JIT is not set
    CONFIG_NET_FLOW_LIMIT=y
    # Network testing
    # CONFIG_NET_PKTGEN is not set
    # CONFIG_HAMRADIO is not set
    # CONFIG_CAN is not set
    # CONFIG_IRDA is not set
    # CONFIG_BT is not set
    # CONFIG_AF_RXRPC is not set
    CONFIG_WIRELESS=y
    # CONFIG_CFG80211 is not set
    # CONFIG_LIB80211 is not set
    # CFG80211 needs to be enabled for MAC80211
    # CONFIG_WIMAX is not set
    # CONFIG_RFKILL is not set
    # CONFIG_NET_9P is not set
    # CONFIG_CAIF is not set
    # CONFIG_CEPH_LIB is not set
    # CONFIG_NFC is not set
    CONFIG_HAVE_BPF_JIT=y
    # Device Drivers
    # Generic Driver Options
    CONFIG_UEVENT_HELPER_PATH="/sbin/hotplug"
    CONFIG_DEVTMPFS=y
    CONFIG_DEVTMPFS_MOUNT=y
    CONFIG_STANDALONE=y
    CONFIG_PREVENT_FIRMWARE_BUILD=y
    CONFIG_FW_LOADER=y
    CONFIG_FIRMWARE_IN_KERNEL=y
    CONFIG_EXTRA_FIRMWARE=""
    CONFIG_FW_LOADER_USER_HELPER=y
    # CONFIG_DEBUG_DRIVER is not set
    # CONFIG_DEBUG_DEVRES is not set
    # CONFIG_SYS_HYPERVISOR is not set
    # CONFIG_GENERIC_CPU_DEVICES is not set
    CONFIG_REGMAP=y
    CONFIG_REGMAP_I2C=y
    # CONFIG_DMA_SHARED_BUFFER is not set
    # CONFIG_DMA_CMA is not set
    # Bus devices
    # CONFIG_ARM_CCI is not set
    CONFIG_CONNECTOR=y
    CONFIG_PROC_EVENTS=y
    CONFIG_MTD=y
    # CONFIG_MTD_TESTS is not set
    # CONFIG_MTD_REDBOOT_PARTS is not set
    CONFIG_MTD_CMDLINE_PARTS=y
    # CONFIG_MTD_AFS_PARTS is not set
    CONFIG_MTD_OF_PARTS=y
    # CONFIG_MTD_AR7_PARTS is not set
    # User Modules And Translation Layers
    CONFIG_MTD_BLKDEVS=y
    CONFIG_MTD_BLOCK=y
    # CONFIG_FTL is not set
    # CONFIG_NFTL is not set
    # CONFIG_INFTL is not set
    # CONFIG_RFD_FTL is not set
    # CONFIG_SSFDC is not set
    # CONFIG_SM_FTL is not set
    # CONFIG_MTD_OOPS is not set
    # CONFIG_MTD_SWAP is not set
    # RAM/ROM/Flash chip drivers
    CONFIG_MTD_CFI=y
    # CONFIG_MTD_JEDECPROBE is not set
    CONFIG_MTD_GEN_PROBE=y
    # CONFIG_MTD_CFI_ADV_OPTIONS is not set
    CONFIG_MTD_MAP_BANK_WIDTH_1=y
    CONFIG_MTD_MAP_BANK_WIDTH_2=y
    CONFIG_MTD_MAP_BANK_WIDTH_4=y
    # CONFIG_MTD_MAP_BANK_WIDTH_8 is not set
    # CONFIG_MTD_MAP_BANK_WIDTH_16 is not set
    # CONFIG_MTD_MAP_BANK_WIDTH_32 is not set
    CONFIG_MTD_CFI_I1=y
    CONFIG_MTD_CFI_I2=y
    # CONFIG_MTD_CFI_I4 is not set
    # CONFIG_MTD_CFI_I8 is not set
    # CONFIG_MTD_CFI_INTELEXT is not set
    CONFIG_MTD_CFI_AMDSTD=y
    # CONFIG_MTD_CFI_STAA is not set
    CONFIG_MTD_CFI_UTIL=y
    # CONFIG_MTD_RAM is not set
    # CONFIG_MTD_ROM is not set
    # CONFIG_MTD_ABSENT is not set
    # Mapping drivers for chip access
    # CONFIG_MTD_COMPLEX_MAPPINGS is not set
    CONFIG_MTD_PHYSMAP=y
    # CONFIG_MTD_PHYSMAP_COMPAT is not set
    CONFIG_MTD_PHYSMAP_OF=y
    # CONFIG_MTD_INTEL_VR_NOR is not set
    # CONFIG_MTD_PLATRAM is not set
    # Self-contained MTD device drivers
    # CONFIG_MTD_PMC551 is not set
    # CONFIG_MTD_DATAFLASH is not set
    CONFIG_MTD_M25P80=y
    # CONFIG_M25PXX_USE_FAST_READ is not set
    # CONFIG_MTD_SST25L is not set
    # CONFIG_MTD_SLRAM is not set
    # CONFIG_MTD_PHRAM is not set
    # CONFIG_MTD_MTDRAM is not set
    # CONFIG_MTD_BLOCK2MTD is not set
    # Disk-On-Chip Device Drivers
    # CONFIG_MTD_DOCG3 is not set
    CONFIG_MTD_NAND_ECC=y
    # CONFIG_MTD_NAND_ECC_SMC is not set
    CONFIG_MTD_NAND=y
    # CONFIG_MTD_NAND_ECC_BCH is not set
    # CONFIG_MTD_SM_COMMON is not set
    # CONFIG_MTD_NAND_DENALI is not set
    # CONFIG_MTD_NAND_GPIO is not set
    CONFIG_MTD_NAND_IDS=y
    # CONFIG_MTD_NAND_RICOH is not set
    # CONFIG_MTD_NAND_DISKONCHIP is not set
    # CONFIG_MTD_NAND_DOCG4 is not set
    # CONFIG_MTD_NAND_CAFE is not set
    # CONFIG_MTD_NAND_NANDSIM is not set
    # CONFIG_MTD_NAND_PLATFORM is not set
    CONFIG_MTD_NAND_ZYNQ=y
    # CONFIG_MTD_ONENAND is not set
    # LPDDR flash memory drivers
    # CONFIG_MTD_LPDDR is not set
    # CONFIG_MTD_UBI is not set
    CONFIG_DTC=y
    CONFIG_OF=y
    # Device Tree and Open Firmware support
    CONFIG_PROC_DEVICETREE=y
    # CONFIG_OF_SELFTEST is not set
    CONFIG_OF_FLATTREE=y
    CONFIG_OF_EARLY_FLATTREE=y
    CONFIG_OF_ADDRESS=y
    CONFIG_OF_IRQ=y
    CONFIG_OF_NET=y
    CONFIG_OF_MDIO=y
    CONFIG_OF_PCI=y
    CONFIG_OF_PCI_IRQ=y
    CONFIG_OF_MTD=y
    # CONFIG_PARPORT is not set
    CONFIG_BLK_DEV=y
    # CONFIG_BLK_DEV_PCIESSD_MTIP32XX is not set
    # CONFIG_BLK_CPQ_CISS_DA is not set
    # CONFIG_BLK_DEV_DAC960 is not set
    # CONFIG_BLK_DEV_UMEM is not set
    # CONFIG_BLK_DEV_COW_COMMON is not set
    CONFIG_BLK_DEV_LOOP=y
    CONFIG_BLK_DEV_LOOP_MIN_COUNT=8
    # CONFIG_BLK_DEV_CRYPTOLOOP is not set
    # CONFIG_BLK_DEV_DRBD is not set
    # CONFIG_BLK_DEV_NBD is not set
    # CONFIG_BLK_DEV_NVME is not set
    # CONFIG_BLK_DEV_SX8 is not set
    CONFIG_BLK_DEV_RAM=y
    CONFIG_BLK_DEV_RAM_COUNT=16
    CONFIG_BLK_DEV_RAM_SIZE=16384
    # CONFIG_BLK_DEV_XIP is not set
    # CONFIG_CDROM_PKTCDVD is not set
    # CONFIG_ATA_OVER_ETH is not set
    # CONFIG_MG_DISK is not set
    # CONFIG_VIRTIO_BLK is not set
    # CONFIG_BLK_DEV_RBD is not set
    # CONFIG_BLK_DEV_RSXX is not set
    # Misc devices
    # CONFIG_SENSORS_LIS3LV02D is not set
    # CONFIG_AD525X_DPOT is not set
    # CONFIG_ATMEL_PWM is not set
    # CONFIG_DUMMY_IRQ is not set
    # CONFIG_PHANTOM is not set
    # CONFIG_SGI_IOC4 is not set
    # CONFIG_TIFM_CORE is not set
    # CONFIG_ICS932S401 is not set
    # CONFIG_ATMEL_SSC is not set
    # CONFIG_ENCLOSURE_SERVICES is not set
    # CONFIG_HP_ILO is not set
    # CONFIG_APDS9802ALS is not set
    # CONFIG_ISL29003 is not set
    # CONFIG_ISL29020 is not set
    # CONFIG_SENSORS_TSL2550 is not set
    # CONFIG_SENSORS_BH1780 is not set
    # CONFIG_SENSORS_BH1770 is not set
    # CONFIG_SENSORS_APDS990X is not set
    # CONFIG_HMC6352 is not set
    # CONFIG_DS1682 is not set
    # CONFIG_TI_DAC7512 is not set
    # CONFIG_ARM_CHARLCD is not set
    # CONFIG_BMP085_I2C is not set
    # CONFIG_BMP085_SPI is not set
    # CONFIG_PCH_PHUB is not set
    # CONFIG_USB_SWITCH_FSA9480 is not set
    # CONFIG_SI570 is not set
    # CONFIG_LATTICE_ECP3_CONFIG is not set
    CONFIG_SRAM=y
    # CONFIG_C2PORT is not set
    # EEPROM support
    CONFIG_EEPROM_AT24=y
    CONFIG_EEPROM_AT25=y
    # CONFIG_EEPROM_LEGACY is not set
    # CONFIG_EEPROM_MAX6875 is not set
    # CONFIG_EEPROM_93CX6 is not set
    # CONFIG_EEPROM_93XX46 is not set
    # CONFIG_CB710_CORE is not set
    # Texas Instruments shared transport line discipline
    # CONFIG_TI_ST is not set
    # CONFIG_SENSORS_LIS3_SPI is not set
    # CONFIG_SENSORS_LIS3_I2C is not set
    # Altera FPGA firmware download module
    # CONFIG_ALTERA_STAPL is not set
    CONFIG_HAVE_IDE=y
    # CONFIG_IDE is not set
    # SCSI device support
    CONFIG_SCSI_MOD=y
    # CONFIG_RAID_ATTRS is not set
    CONFIG_SCSI=y
    CONFIG_SCSI_DMA=y
    # CONFIG_SCSI_TGT is not set
    # CONFIG_SCSI_NETLINK is not set
    CONFIG_SCSI_PROC_FS=y
    # SCSI support type (disk, tape, CD-ROM)
    CONFIG_BLK_DEV_SD=y
    # CONFIG_CHR_DEV_ST is not set
    # CONFIG_CHR_DEV_OSST is not set
    # CONFIG_BLK_DEV_SR is not set
    CONFIG_CHR_DEV_SG=y
    # CONFIG_CHR_DEV_SCH is not set
    CONFIG_SCSI_MULTI_LUN=y
    # CONFIG_SCSI_CONSTANTS is not set
    # CONFIG_SCSI_LOGGING is not set
    # CONFIG_SCSI_SCAN_ASYNC is not set
    # SCSI Transports
    # CONFIG_SCSI_SPI_ATTRS is not set
    # CONFIG_SCSI_FC_ATTRS is not set
    # CONFIG_SCSI_ISCSI_ATTRS is not set
    # CONFIG_SCSI_SAS_ATTRS is not set
    # CONFIG_SCSI_SAS_LIBSAS is not set
    # CONFIG_SCSI_SRP_ATTRS is not set
    CONFIG_SCSI_LOWLEVEL=y
    # CONFIG_ISCSI_TCP is not set
    # CONFIG_ISCSI_BOOT_SYSFS is not set
    # CONFIG_SCSI_CXGB3_ISCSI is not set
    # CONFIG_SCSI_CXGB4_ISCSI is not set
    # CONFIG_SCSI_BNX2_ISCSI is not set
    # CONFIG_SCSI_BNX2X_FCOE is not set
    # CONFIG_BE2ISCSI is not set
    # CONFIG_BLK_DEV_3W_XXXX_RAID is not set
    # CONFIG_SCSI_HPSA is not set
    # CONFIG_SCSI_3W_9XXX is not set
    # CONFIG_SCSI_3W_SAS is not set
    # CONFIG_SCSI_ACARD is not set
    # CONFIG_SCSI_AACRAID is not set
    # CONFIG_SCSI_AIC7XXX is not set
    # CONFIG_SCSI_AIC7XXX_OLD is not set
    # CONFIG_SCSI_AIC79XX is not set
    # CONFIG_SCSI_AIC94XX is not set
    # CONFIG_SCSI_MVSAS is not set
    # CONFIG_SCSI_MVUMI is not set
    # CONFIG_SCSI_ARCMSR is not set
    # CONFIG_SCSI_ESAS2R is not set
    # CONFIG_MEGARAID_NEWGEN is not set
    # CONFIG_MEGARAID_LEGACY is not set
    # CONFIG_MEGARAID_SAS is not set
    # CONFIG_SCSI_MPT2SAS is not set
    # CONFIG_SCSI_MPT3SAS is not set
    # CONFIG_SCSI_UFSHCD is not set
    # CONFIG_SCSI_HPTIOP is not set
    # CONFIG_LIBFC is not set
    # CONFIG_LIBFCOE is not set
    # CONFIG_FCOE is not set
    # CONFIG_SCSI_DMX3191D is not set
    # CONFIG_SCSI_FUTURE_DOMAIN is not set
    # CONFIG_SCSI_IPS is not set
    # CONFIG_SCSI_INITIO is not set
    # CONFIG_SCSI_INIA100 is not set
    # CONFIG_SCSI_STEX is not set
    # CONFIG_SCSI_SYM53C8XX_2 is not set
    # CONFIG_SCSI_QLOGIC_1280 is not set
    # CONFIG_SCSI_QLA_FC is not set
    # CONFIG_SCSI_QLA_ISCSI is not set
    # CONFIG_SCSI_LPFC is not set
    # CONFIG_SCSI_DC395x is not set
    # CONFIG_SCSI_DC390T is not set
    # CONFIG_SCSI_NSP32 is not set
    # CONFIG_SCSI_DEBUG is not set
    # CONFIG_SCSI_PMCRAID is not set
    # CONFIG_SCSI_PM8001 is not set
    # CONFIG_SCSI_SRP is not set
    # CONFIG_SCSI_BFA_FC is not set
    # CONFIG_SCSI_VIRTIO is not set
    # CONFIG_SCSI_CHELSIO_FCOE is not set
    # CONFIG_SCSI_DH is not set
    # CONFIG_SCSI_OSD_INITIATOR is not set
    CONFIG_HAVE_PATA_PLATFORM=y
    # CONFIG_ATA is not set
    # CONFIG_MD is not set
    # CONFIG_TARGET_CORE is not set
    # CONFIG_FUSION is not set
    # IEEE 1394 (FireWire) support
    # CONFIG_FIREWIRE is not set
    # CONFIG_FIREWIRE_NOSY is not set
    # CONFIG_I2O is not set
    CONFIG_NETDEVICES=y
    CONFIG_MII=y
    CONFIG_NET_CORE=y
    # CONFIG_BONDING is not set
    # CONFIG_DUMMY is not set
    # CONFIG_EQUALIZER is not set
    # CONFIG_NET_FC is not set
    # CONFIG_NET_TEAM is not set
    # CONFIG_MACVLAN is not set
    # CONFIG_VXLAN is not set
    # CONFIG_NETCONSOLE is not set
    # CONFIG_NETPOLL is not set
    # CONFIG_NET_POLL_CONTROLLER is not set
    # CONFIG_TUN is not set
    # CONFIG_VETH is not set
    # CONFIG_VIRTIO_NET is not set
    # CONFIG_NLMON is not set
    # CONFIG_ARCNET is not set
    # CAIF transport drivers
    # Distributed Switch Architecture drivers
    # CONFIG_NET_DSA_MV88E6XXX is not set
    # CONFIG_NET_DSA_MV88E6060 is not set
    # CONFIG_NET_DSA_MV88E6XXX_NEED_PPU is not set
    # CONFIG_NET_DSA_MV88E6131 is not set
    # CONFIG_NET_DSA_MV88E6123_61_65 is not set
    CONFIG_ETHERNET=y
    # CONFIG_NET_VENDOR_3COM is not set
    # CONFIG_NET_VENDOR_ADAPTEC is not set
    # CONFIG_NET_VENDOR_ALTEON is not set
    # CONFIG_NET_VENDOR_AMD is not set
    CONFIG_NET_VENDOR_ARC=y
    # CONFIG_ARC_EMAC is not set
    # CONFIG_NET_VENDOR_ATHEROS is not set
    CONFIG_NET_CADENCE=y
    # CONFIG_ARM_AT91_ETHER is not set
    CONFIG_MACB=y
    CONFIG_NET_VENDOR_BROADCOM=y
    # CONFIG_B44 is not set
    # CONFIG_BNX2 is not set
    # CONFIG_CNIC is not set
    CONFIG_TIGON3=y
    # CONFIG_BNX2X is not set
    # CONFIG_NET_VENDOR_BROCADE is not set
    # CONFIG_NET_CALXEDA_XGMAC is not set
    # CONFIG_NET_VENDOR_CHELSIO is not set
    # CONFIG_NET_VENDOR_CIRRUS is not set
    # CONFIG_NET_VENDOR_CISCO is not set
    # CONFIG_DM9000 is not set
    # CONFIG_DNET is not set
    # CONFIG_NET_VENDOR_DEC is not set
    # CONFIG_NET_VENDOR_DLINK is not set
    # CONFIG_NET_VENDOR_EMULEX is not set
    # CONFIG_NET_VENDOR_EXAR is not set
    # CONFIG_NET_VENDOR_FARADAY is not set
    # CONFIG_NET_VENDOR_HP is not set
    CONFIG_NET_VENDOR_INTEL=y
    # CONFIG_E100 is not set
    # CONFIG_E1000 is not set
    CONFIG_E1000E=y
    # CONFIG_IGB is not set
    # CONFIG_IGBVF is not set
    # CONFIG_IXGB is not set
    # CONFIG_IXGBE is not set
    # CONFIG_IXGBEVF is not set
    # CONFIG_I40E is not set
    CONFIG_NET_VENDOR_I825XX=y
    # CONFIG_IP1000 is not set
    # CONFIG_JME is not set
    # CONFIG_NET_VENDOR_MARVELL is not set
    # CONFIG_NET_VENDOR_MELLANOX is not set
    # CONFIG_NET_VENDOR_MICREL is not set
    # CONFIG_NET_VENDOR_MICROCHIP is not set
    # CONFIG_NET_VENDOR_MYRI is not set
    # CONFIG_FEALNX is not set
    # CONFIG_NET_VENDOR_NATSEMI is not set
    # CONFIG_NET_VENDOR_NVIDIA is not set
    # CONFIG_NET_VENDOR_OKI is not set
    # CONFIG_ETHOC is not set
    # CONFIG_NET_PACKET_ENGINE is not set
    # CONFIG_NET_VENDOR_QLOGIC is not set
    CONFIG_NET_VENDOR_REALTEK=y
    # CONFIG_8139CP is not set
    # CONFIG_8139TOO is not set
    CONFIG_R8169=y
    # CONFIG_SH_ETH is not set
    # CONFIG_NET_VENDOR_RDC is not set
    # CONFIG_NET_VENDOR_SEEQ is not set
    # CONFIG_NET_VENDOR_SILAN is not set
    # CONFIG_NET_VENDOR_SIS is not set
    # CONFIG_SFC is not set
    # CONFIG_NET_VENDOR_SMSC is not set
    # CONFIG_NET_VENDOR_STMICRO is not set
    # CONFIG_NET_VENDOR_SUN is not set
    # CONFIG_NET_VENDOR_TEHUTI is not set
    # CONFIG_NET_VENDOR_TI is not set
    # CONFIG_NET_VENDOR_VIA is not set
    # CONFIG_NET_VENDOR_WIZNET is not set
    CONFIG_NET_VENDOR_XILINX=y
    CONFIG_XILINX_EMACLITE=y
    CONFIG_XILINX_AXI_EMAC=y
    CONFIG_XILINX_PS_EMAC=y
    # CONFIG_XILINX_PS_EMAC_HWTSTAMP is not set
    # CONFIG_FDDI is not set
    # CONFIG_HIPPI is not set
    CONFIG_PHYLIB=y
    # MII PHY device drivers
    # CONFIG_AT803X_PHY is not set
    # CONFIG_AMD_PHY is not set
    CONFIG_MARVELL_PHY=y
    # CONFIG_DAVICOM_PHY is not set
    # CONFIG_QSEMI_PHY is not set
    # CONFIG_LXT_PHY is not set
    # CONFIG_CICADA_PHY is not set
    CONFIG_VITESSE_PHY=y
    # CONFIG_SMSC_PHY is not set
    # CONFIG_BROADCOM_PHY is not set
    # CONFIG_BCM87XX_PHY is not set
    # CONFIG_ICPLUS_PHY is not set
    # CONFIG_REALTEK_PHY is not set
    # CONFIG_NATIONAL_PHY is not set
    # CONFIG_STE10XP is not set
    # CONFIG_LSI_ET1011C_PHY is not set
    # CONFIG_MICREL_PHY is not set
    # CONFIG_FIXED_PHY is not set
    CONFIG_MDIO_BITBANG=y
    # CONFIG_MDIO_GPIO is not set
    # CONFIG_MDIO_BUS_MUX_GPIO is not set
    # CONFIG_MDIO_BUS_MUX_MMIOREG is not set
    # CONFIG_MICREL_KS8995MA is not set
    # CONFIG_PPP is not set
    # CONFIG_SLIP is not set
    # USB Network Adapters
    # CONFIG_USB_CATC is not set
    # CONFIG_USB_KAWETH is not set
    # CONFIG_USB_PEGASUS is not set
    # CONFIG_USB_RTL8150 is not set
    # CONFIG_USB_RTL8152 is not set
    # CONFIG_USB_USBNET is not set
    # CONFIG_USB_IPHETH is not set
    CONFIG_WLAN=y
    # CONFIG_ATMEL is not set
    # CONFIG_PRISM54 is not set
    # CONFIG_USB_ZD1201 is not set
    # CONFIG_HOSTAP is not set
    # CONFIG_WL_TI is not set
    # Enable WiMAX (Networking options) to see the WiMAX drivers
    # CONFIG_WAN is not set
    # CONFIG_VMXNET3 is not set
    # CONFIG_ISDN is not set
    # Input device support
    CONFIG_INPUT=y
    # CONFIG_INPUT_FF_MEMLESS is not set
    # CONFIG_INPUT_POLLDEV is not set
    CONFIG_INPUT_SPARSEKMAP=y
    # CONFIG_INPUT_MATRIXKMAP is not set
    # Userland interfaces
    CONFIG_INPUT_MOUSEDEV=y
    CONFIG_INPUT_MOUSEDEV_PSAUX=y
    CONFIG_INPUT_MOUSEDEV_SCREEN_X=1024
    CONFIG_INPUT_MOUSEDEV_SCREEN_Y=768
    # CONFIG_INPUT_JOYDEV is not set
    CONFIG_INPUT_EVDEV=y
    # CONFIG_INPUT_EVBUG is not set
    # Input Device Drivers
    CONFIG_INPUT_KEYBOARD=y
    # CONFIG_KEYBOARD_ADP5588 is not set
    # CONFIG_KEYBOARD_ADP5589 is not set
    CONFIG_KEYBOARD_ATKBD=y
    # CONFIG_KEYBOARD_QT1070 is not set
    # CONFIG_KEYBOARD_QT2160 is not set
    # CONFIG_KEYBOARD_LKKBD is not set
    # CONFIG_KEYBOARD_GPIO is not set
    # CONFIG_KEYBOARD_TCA6416 is not set
    # CONFIG_KEYBOARD_TCA8418 is not set
    # CONFIG_KEYBOARD_MATRIX is not set
    # CONFIG_KEYBOARD_LM8333 is not set
    # CONFIG_KEYBOARD_MAX7359 is not set
    # CONFIG_KEYBOARD_MCS is not set
    # CONFIG_KEYBOARD_MPR121 is not set
    # CONFIG_KEYBOARD_NEWTON is not set
    # CONFIG_KEYBOARD_OPENCORES is not set
    # CONFIG_KEYBOARD_SAMSUNG is not set
    # CONFIG_KEYBOARD_STOWAWAY is not set
    # CONFIG_KEYBOARD_SUNKBD is not set
    # CONFIG_KEYBOARD_XTKBD is not set
    CONFIG_INPUT_MOUSE=y
    CONFIG_MOUSE_PS2=y
    CONFIG_MOUSE_PS2_ALPS=y
    CONFIG_MOUSE_PS2_LOGIPS2PP=y
    CONFIG_MOUSE_PS2_SYNAPTICS=y
    CONFIG_MOUSE_PS2_CYPRESS=y
    CONFIG_MOUSE_PS2_TRACKPOINT=y
    # CONFIG_MOUSE_PS2_ELANTECH is not set
    # CONFIG_MOUSE_PS2_SENTELIC is not set
    # CONFIG_MOUSE_PS2_TOUCHKIT is not set
    # CONFIG_MOUSE_SERIAL is not set
    # CONFIG_MOUSE_APPLETOUCH is not set
    # CONFIG_MOUSE_BCM5974 is not set
    # CONFIG_MOUSE_CYAPA is not set
    # CONFIG_MOUSE_VSXXXAA is not set
    # CONFIG_MOUSE_GPIO is not set
    # CONFIG_MOUSE_SYNAPTICS_I2C is not set
    # CONFIG_MOUSE_SYNAPTICS_USB is not set
    # CONFIG_INPUT_JOYSTICK is not set
    # CONFIG_INPUT_TABLET is not set
    # CONFIG_INPUT_TOUCHSCREEN is not set
    # CONFIG_INPUT_MISC is not set
    # Hardware I/O ports
    CONFIG_SERIO=y
    CONFIG_SERIO_SERPORT=y
    # CONFIG_SERIO_AMBAKMI is not set
    # CONFIG_SERIO_PCIPS2 is not set
    CONFIG_SERIO_LIBPS2=y
    # CONFIG_SERIO_RAW is not set
    # CONFIG_SERIO_ALTERA_PS2 is not set
    # CONFIG_SERIO_PS2MULT is not set
    # CONFIG_SERIO_ARC_PS2 is not set
    # CONFIG_SERIO_APBPS2 is not set
    # CONFIG_SERIO_OLPC_APSP is not set
    # CONFIG_GAMEPORT is not set
    # Character devices
    CONFIG_TTY=y
    CONFIG_VT=y
    CONFIG_CONSOLE_TRANSLATIONS=y
    CONFIG_VT_CONSOLE=y
    CONFIG_VT_CONSOLE_SLEEP=y
    CONFIG_HW_CONSOLE=y
    CONFIG_VT_HW_CONSOLE_BINDING=y
    CONFIG_UNIX98_PTYS=y
    # CONFIG_DEVPTS_MULTIPLE_INSTANCES is not set
    # CONFIG_LEGACY_PTYS is not set
    # CONFIG_SERIAL_NONSTANDARD is not set
    # CONFIG_NOZOMI is not set
    # CONFIG_N_GSM is not set
    # CONFIG_TRACE_SINK is not set
    # CONFIG_DEVKMEM is not set
    # Serial drivers
    # CONFIG_SERIAL_8250 is not set
    # Non-8250 serial port support
    # CONFIG_SERIAL_AMBA_PL010 is not set
    # CONFIG_SERIAL_AMBA_PL011 is not set
    # CONFIG_SERIAL_MAX3100 is not set
    # CONFIG_SERIAL_MAX310X is not set
    # CONFIG_SERIAL_MFD_HSU is not set
    # CONFIG_SERIAL_UARTLITE is not set
    CONFIG_SERIAL_CORE=y
    CONFIG_SERIAL_CORE_CONSOLE=y
    # CONFIG_SERIAL_JSM is not set
    # CONFIG_SERIAL_SCCNXP is not set
    # CONFIG_SERIAL_TIMBERDALE is not set
    # CONFIG_SERIAL_ALTERA_JTAGUART is not set
    # CONFIG_SERIAL_ALTERA_UART is not set
    # CONFIG_SERIAL_IFX6X60 is not set
    # CONFIG_SERIAL_PCH_UART is not set
    CONFIG_SERIAL_XILINX_PS_UART=y
    CONFIG_SERIAL_XILINX_PS_UART_CONSOLE=y
    # CONFIG_SERIAL_ARC is not set
    # CONFIG_SERIAL_RP2 is not set
    # CONFIG_SERIAL_FSL_LPUART is not set
    # CONFIG_SERIAL_ST_ASC is not set
    # CONFIG_TTY_PRINTK is not set
    # CONFIG_HVC_DCC is not set
    # CONFIG_VIRTIO_CONSOLE is not set
    # CONFIG_IPMI_HANDLER is not set
    # CONFIG_HW_RANDOM is not set
    CONFIG_XILINX_DEVCFG=y
    # CONFIG_R3964 is not set
    # CONFIG_APPLICOM is not set
    # CONFIG_RAW_DRIVER is not set
    # CONFIG_TCG_TPM is not set
    CONFIG_DEVPORT=y
    CONFIG_I2C=y
    CONFIG_I2C_BOARDINFO=y
    CONFIG_I2C_COMPAT=y
    CONFIG_I2C_CHARDEV=y
    CONFIG_I2C_MUX=y
    # Multiplexer I2C Chip support
    # CONFIG_I2C_ARB_GPIO_CHALLENGE is not set
    # CONFIG_I2C_MUX_GPIO is not set
    # CONFIG_I2C_MUX_PCA9541 is not set
    CONFIG_I2C_MUX_PCA954x=y
    CONFIG_I2C_HELPER_AUTO=y
    # I2C Hardware Bus support
    # PC SMBus host controller drivers
    # CONFIG_I2C_ALI1535 is not set
    # CONFIG_I2C_ALI1563 is not set
    # CONFIG_I2C_ALI15X3 is not set
    # CONFIG_I2C_AMD756 is not set
    # CONFIG_I2C_AMD8111 is not set
    # CONFIG_I2C_I801 is not set
    # CONFIG_I2C_ISCH is not set
    # CONFIG_I2C_PIIX4 is not set
    # CONFIG_I2C_NFORCE2 is not set
    # CONFIG_I2C_SIS5595 is not set
    # CONFIG_I2C_SIS630 is not set
    # CONFIG_I2C_SIS96X is not set
    # CONFIG_I2C_VIA is not set
    # CONFIG_I2C_VIAPRO is not set
    # I2C system bus drivers (mostly embedded / system-on-chip)
    # CONFIG_I2C_CBUS_GPIO is not set
    # CONFIG_I2C_DESIGNWARE_PLATFORM is not set
    # CONFIG_I2C_DESIGNWARE_PCI is not set
    # CONFIG_I2C_EG20T is not set
    # CONFIG_I2C_GPIO is not set
    # CONFIG_I2C_NOMADIK is not set
    # CONFIG_I2C_OCORES is not set
    # CONFIG_I2C_PCA_PLATFORM is not set
    # CONFIG_I2C_PXA_PCI is not set
    # CONFIG_I2C_SIMTEC is not set
    # CONFIG_I2C_VERSATILE is not set
    CONFIG_I2C_ZYNQ=y
    # CONFIG_I2C_XILINX is not set
    # External I2C/SMBus adapter drivers
    # CONFIG_I2C_DIOLAN_U2C is not set
    # CONFIG_I2C_PARPORT_LIGHT is not set
    # CONFIG_I2C_TAOS_EVM is not set
    # CONFIG_I2C_TINY_USB is not set
    # Other I2C/SMBus bus drivers
    # CONFIG_I2C_STUB is not set
    # CONFIG_I2C_DEBUG_CORE is not set
    # CONFIG_I2C_DEBUG_ALGO is not set
    # CONFIG_I2C_DEBUG_BUS is not set
    CONFIG_SPI=y
    # CONFIG_SPI_DEBUG is not set
    CONFIG_SPI_MASTER=y
    # SPI Master Controller Drivers
    # CONFIG_SPI_ALTERA is not set
    CONFIG_SPI_BITBANG=y
    # CONFIG_SPI_GPIO is not set
    # CONFIG_SPI_FSL_SPI is not set
    # CONFIG_SPI_FSL_DSPI is not set
    # CONFIG_SPI_OC_TINY is not set
    # CONFIG_SPI_PL022 is not set
    # CONFIG_SPI_PXA2XX is not set
    # CONFIG_SPI_PXA2XX_PCI is not set
    # CONFIG_SPI_SC18IS602 is not set
    # CONFIG_SPI_TOPCLIFF_PCH is not set
    # CONFIG_SPI_XCOMM is not set
    CONFIG_SPI_XILINX=y
    CONFIG_SPI_ZYNQ_QSPI=y
    # CONFIG_SPI_ZYNQ_QSPI_DUAL_STACKED is not set
    CONFIG_SPI_ZYNQ=y
    # CONFIG_SPI_DESIGNWARE is not set
    # SPI Protocol Masters
    # CONFIG_SPI_SPIDEV is not set
    # CONFIG_SPI_TLE62X0 is not set
    # CONFIG_HSI is not set
    # PPS support
    CONFIG_PPS=y
    # CONFIG_PPS_DEBUG is not set
    # PPS clients support
    # CONFIG_PPS_CLIENT_KTIMER is not set
    # CONFIG_PPS_CLIENT_LDISC is not set
    # CONFIG_PPS_CLIENT_GPIO is not set
    # PPS generators support
    # PTP clock support
    CONFIG_PTP_1588_CLOCK=y
    # Enable PHYLIB and NETWORK_PHY_TIMESTAMPING to see the additional clocks.
    CONFIG_ARCH_REQUIRE_GPIOLIB=y
    CONFIG_GPIO_DEVRES=y
    CONFIG_GPIOLIB=y
    CONFIG_OF_GPIO=y
    # CONFIG_DEBUG_GPIO is not set
    CONFIG_GPIO_SYSFS=y
    # Memory mapped GPIO drivers:
    # CONFIG_GPIO_GENERIC_PLATFORM is not set
    # CONFIG_GPIO_EM is not set
    # CONFIG_GPIO_PL061 is not set
    # CONFIG_GPIO_RCAR is not set
    # CONFIG_GPIO_TS5500 is not set
    CONFIG_GPIO_XILINX=y
    CONFIG_GPIO_ZYNQ=y
    # CONFIG_GPIO_VX855 is not set
    # CONFIG_GPIO_GRGPIO is not set
    # I2C GPIO expanders:
    # CONFIG_GPIO_MAX7300 is not set
    # CONFIG_GPIO_MAX732X is not set
    # CONFIG_GPIO_PCF857X is not set
    # CONFIG_GPIO_SX150X is not set
    # CONFIG_GPIO_ADP5588 is not set
    # CONFIG_GPIO_ADNP is not set
    # PCI GPIO expanders:
    # CONFIG_GPIO_BT8XX is not set
    # CONFIG_GPIO_AMD8111 is not set
    # CONFIG_GPIO_ML_IOH is not set
    # CONFIG_GPIO_RDC321X is not set
    # SPI GPIO expanders:
    # CONFIG_GPIO_MAX7301 is not set
    # CONFIG_GPIO_MCP23S08 is not set
    # CONFIG_GPIO_MC33880 is not set
    # CONFIG_GPIO_74X164 is not set
    # AC97 GPIO expanders:
    # LPC GPIO expanders:
    # MODULbus GPIO expanders:
    # USB GPIO expanders:
    # CONFIG_W1 is not set
    CONFIG_POWER_SUPPLY=y
    # CONFIG_POWER_SUPPLY_DEBUG is not set
    # CONFIG_PDA_POWER is not set
    # CONFIG_TEST_POWER is not set
    # CONFIG_BATTERY_DS2780 is not set
    # CONFIG_BATTERY_DS2781 is not set
    # CONFIG_BATTERY_DS2782 is not set
    # CONFIG_BATTERY_SBS is not set
    # CONFIG_BATTERY_BQ27x00 is not set
    # CONFIG_BATTERY_MAX17040 is not set
    # CONFIG_BATTERY_MAX17042 is not set
    # CONFIG_CHARGER_ISP1704 is not set
    # CONFIG_CHARGER_MAX8903 is not set
    # CONFIG_CHARGER_LP8727 is not set
    # CONFIG_CHARGER_GPIO is not set
    # CONFIG_CHARGER_BQ2415X is not set
    # CONFIG_CHARGER_BQ24190 is not set
    # CONFIG_CHARGER_SMB347 is not set
    CONFIG_POWER_RESET=y
    # CONFIG_POWER_RESET_GPIO is not set
    # CONFIG_POWER_RESET_RESTART is not set
    CONFIG_POWER_RESET_VEXPRESS=y
    # CONFIG_POWER_AVS is not set
    CONFIG_HWMON=y
    # CONFIG_HWMON_VID is not set
    # CONFIG_HWMON_DEBUG_CHIP is not set
    # Native drivers
    # CONFIG_SENSORS_AD7314 is not set
    # CONFIG_SENSORS_AD7414 is not set
    # CONFIG_SENSORS_AD7418 is not set
    # CONFIG_SENSORS_ADCXX is not set
    # CONFIG_SENSORS_ADM1021 is not set
    # CONFIG_SENSORS_ADM1025 is not set
    # CONFIG_SENSORS_ADM1026 is not set
    # CONFIG_SENSORS_ADM1029 is not set
    # CONFIG_SENSORS_ADM1031 is not set
    # CONFIG_SENSORS_ADM9240 is not set
    # CONFIG_SENSORS_ADT7310 is not set
    # CONFIG_SENSORS_ADT7410 is not set
    # CONFIG_SENSORS_ADT7411 is not set
    # CONFIG_SENSORS_ADT7462 is not set
    # CONFIG_SENSORS_ADT7470 is not set
    # CONFIG_SENSORS_ADT7475 is not set
    # CONFIG_SENSORS_ASC7621 is not set
    # CONFIG_SENSORS_ATXP1 is not set
    # CONFIG_SENSORS_DS620 is not set
    # CONFIG_SENSORS_DS1621 is not set
    # CONFIG_SENSORS_I5K_AMB is not set
    # CONFIG_SENSORS_F71805F is not set
    # CONFIG_SENSORS_F71882FG is not set
    # CONFIG_SENSORS_F75375S is not set
    # CONFIG_SENSORS_G760A is not set
    # CONFIG_SENSORS_G762 is not set
    # CONFIG_SENSORS_GL518SM is not set
    # CONFIG_SENSORS_GL520SM is not set
    # CONFIG_SENSORS_GPIO_FAN is not set
    # CONFIG_SENSORS_HIH6130 is not set
    # CONFIG_SENSORS_HTU21 is not set
    # CONFIG_SENSORS_IT87 is not set
    # CONFIG_SENSORS_JC42 is not set
    # CONFIG_SENSORS_LINEAGE is not set
    # CONFIG_SENSORS_LM63 is not set
    # CONFIG_SENSORS_LM70 is not set
    # CONFIG_SENSORS_LM73 is not set
    # CONFIG_SENSORS_LM75 is not set
    # CONFIG_SENSORS_LM77 is not set
    # CONFIG_SENSORS_LM78 is not set
    # CONFIG_SENSORS_LM80 is not set
    # CONFIG_SENSORS_LM83 is not set
    # CONFIG_SENSORS_LM85 is not set
    # CONFIG_SENSORS_LM87 is not set
    # CONFIG_SENSORS_LM90 is not set
    # CONFIG_SENSORS_LM92 is not set
    # CONFIG_SENSORS_LM93 is not set
    # CONFIG_SENSORS_LTC4151 is not set
    # CONFIG_SENSORS_LTC4215 is not set
    # CONFIG_SENSORS_LTC4245 is not set
    # CONFIG_SENSORS_LTC4261 is not set
    # CONFIG_SENSORS_LM95234 is not set
    # CONFIG_SENSORS_LM95241 is not set
    # CONFIG_SENSORS_LM95245 is not set
    # CONFIG_SENSORS_MAX1111 is not set
    # CONFIG_SENSORS_MAX16065 is not set
    # CONFIG_SENSORS_MAX1619 is not set
    # CONFIG_SENSORS_MAX1668 is not set
    # CONFIG_SENSORS_MAX197 is not set
    # CONFIG_SENSORS_MAX6639 is not set
    # CONFIG_SENSORS_MAX6642 is not set
    # CONFIG_SENSORS_MAX6650 is not set
    # CONFIG_SENSORS_MAX6697 is not set
    # CONFIG_SENSORS_MCP3021 is not set
    # CONFIG_SENSORS_NCT6775 is not set
    # CONFIG_SENSORS_PC87360 is not set
    # CONFIG_SENSORS_PC87427 is not set
    # CONFIG_SENSORS_PCF8591 is not set
    # CONFIG_PMBUS is not set
    # CONFIG_SENSORS_SHT15 is not set
    # CONFIG_SENSORS_SHT21 is not set
    # CONFIG_SENSORS_SIS5595 is not set
    # CONFIG_SENSORS_SMM665 is not set
    # CONFIG_SENSORS_DME1737 is not set
    # CONFIG_SENSORS_EMC1403 is not set
    # CONFIG_SENSORS_EMC2103 is not set
    # CONFIG_SENSORS_EMC6W201 is not set
    # CONFIG_SENSORS_SMSC47M1 is not set
    # CONFIG_SENSORS_SMSC47M192 is not set
    # CONFIG_SENSORS_SMSC47B397 is not set
    # CONFIG_SENSORS_SCH56XX_COMMON is not set
    # CONFIG_SENSORS_SCH5627 is not set
    # CONFIG_SENSORS_SCH5636 is not set
    # CONFIG_SENSORS_ADS1015 is not set
    # CONFIG_SENSORS_ADS7828 is not set
    # CONFIG_SENSORS_ADS7871 is not set
    # CONFIG_SENSORS_AMC6821 is not set
    # CONFIG_SENSORS_INA209 is not set
    # CONFIG_SENSORS_INA2XX is not set
    # CONFIG_SENSORS_THMC50 is not set
    # CONFIG_SENSORS_TMP102 is not set
    # CONFIG_SENSORS_TMP401 is not set
    # CONFIG_SENSORS_TMP421 is not set
    # CONFIG_SENSORS_VEXPRESS is not set
    # CONFIG_SENSORS_VIA686A is not set
    # CONFIG_SENSORS_VT1211 is not set
    # CONFIG_SENSORS_VT8231 is not set
    # CONFIG_SENSORS_W83781D is not set
    # CONFIG_SENSORS_W83791D is not set
    # CONFIG_SENSORS_W83792D is not set
    # CONFIG_SENSORS_W83793 is not set
    # CONFIG_SENSORS_W83795 is not set
    # CONFIG_SENSORS_W83L785TS is not set
    # CONFIG_SENSORS_W83L786NG is not set
    # CONFIG_SENSORS_W83627HF is not set
    # CONFIG_SENSORS_W83627EHF is not set
    CONFIG_SENSORS_XADCPS=y
    # CONFIG_THERMAL is not set
    CONFIG_WATCHDOG=y
    CONFIG_WATCHDOG_CORE=y
    # CONFIG_WATCHDOG_NOWAYOUT is not set
    # Watchdog Device Drivers
    # CONFIG_SOFT_WATCHDOG is not set
    # CONFIG_ARM_SP805_WATCHDOG is not set
    # CONFIG_DW_WATCHDOG is not set
    CONFIG_ZYNQ_WATCHDOG=y
    # CONFIG_MAX63XX_WATCHDOG is not set
    # CONFIG_ALIM7101_WDT is not set
    # CONFIG_I6300ESB_WDT is not set
    CONFIG_XILINX_WATCHDOG=y
    # CONFIG_MEN_A21_WDT is not set
    # PCI-based Watchdog Cards
    # CONFIG_PCIPCWATCHDOG is not set
    # CONFIG_WDTPCI is not set
    # USB-based Watchdog Cards
    # CONFIG_USBPCWATCHDOG is not set
    CONFIG_SSB_POSSIBLE=y
    # Sonics Silicon Backplane
    # CONFIG_SSB is not set
    CONFIG_BCMA_POSSIBLE=y
    # Broadcom specific AMBA
    # CONFIG_BCMA is not set
    # Multifunction device drivers
    # CONFIG_MFD_CORE is not set
    # CONFIG_MFD_AS3711 is not set
    # CONFIG_PMIC_ADP5520 is not set
    # CONFIG_MFD_AAT2870_CORE is not set
    # CONFIG_MFD_CROS_EC is not set
    # CONFIG_MFD_ASIC3 is not set
    # CONFIG_PMIC_DA903X is not set
    # CONFIG_MFD_DA9052_SPI is not set
    # CONFIG_MFD_DA9052_I2C is not set
    # CONFIG_MFD_DA9055 is not set
    # CONFIG_MFD_DA9063 is not set
    # CONFIG_MFD_MC13XXX_SPI is not set
    # CONFIG_MFD_MC13XXX_I2C is not set
    # CONFIG_HTC_EGPIO is not set
    # CONFIG_HTC_PASIC3 is not set
    # CONFIG_HTC_I2CPLD is not set
    # CONFIG_LPC_ICH is not set
    # CONFIG_LPC_SCH is not set
    # CONFIG_MFD_JANZ_CMODIO is not set
    # CONFIG_MFD_KEMPLD is not set
    # CONFIG_MFD_88PM800 is not set
    # CONFIG_MFD_88PM805 is not set
    # CONFIG_MFD_88PM860X is not set
    # CONFIG_MFD_MAX77686 is not set
    # CONFIG_MFD_MAX77693 is not set
    # CONFIG_MFD_MAX8907 is not set
    # CONFIG_MFD_MAX8925 is not set
    # CONFIG_MFD_MAX8997 is not set
    # CONFIG_MFD_MAX8998 is not set
    # CONFIG_EZX_PCAP is not set
    # CONFIG_MFD_VIPERBOARD is not set
    # CONFIG_MFD_RETU is not set
    # CONFIG_MFD_PCF50633 is not set
    # CONFIG_MFD_RDC321X is not set
    # CONFIG_MFD_RTSX_PCI is not set
    # CONFIG_MFD_RC5T583 is not set
    # CONFIG_MFD_SEC_CORE is not set
    # CONFIG_MFD_SI476X_CORE is not set
    # CONFIG_MFD_SM501 is not set
    # CONFIG_MFD_SMSC is not set
    # CONFIG_ABX500_CORE is not set
    # CONFIG_MFD_STMPE is not set
    # CONFIG_MFD_SYSCON is not set
    # CONFIG_MFD_TI_AM335X_TSCADC is not set
    # CONFIG_MFD_LP8788 is not set
    # CONFIG_MFD_PALMAS is not set
    # CONFIG_TPS6105X is not set
    # CONFIG_TPS65010 is not set
    # CONFIG_TPS6507X is not set
    # CONFIG_MFD_TPS65090 is not set
    # CONFIG_MFD_TPS65217 is not set
    # CONFIG_MFD_TPS6586X is not set
    # CONFIG_MFD_TPS65910 is not set
    # CONFIG_MFD_TPS65912 is not set
    # CONFIG_MFD_TPS65912_I2C is not set
    # CONFIG_MFD_TPS65912_SPI is not set
    # CONFIG_MFD_TPS80031 is not set
    # CONFIG_TWL4030_CORE is not set
    # CONFIG_TWL6040_CORE is not set
    # CONFIG_MFD_WL1273_CORE is not set
    # CONFIG_MFD_LM3533 is not set
    # CONFIG_MFD_TIMBERDALE is not set
    # CONFIG_MFD_TC3589X is not set
    # CONFIG_MFD_TMIO is not set
    # CONFIG_MFD_T7L66XB is not set
    # CONFIG_MFD_TC6387XB is not set
    # CONFIG_MFD_TC6393XB is not set
    # CONFIG_MFD_VX855 is not set
    # CONFIG_MFD_ARIZONA_I2C is not set
    # CONFIG_MFD_ARIZONA_SPI is not set
    # CONFIG_MFD_WM8400 is not set
    # CONFIG_MFD_WM831X_I2C is not set
    # CONFIG_MFD_WM831X_SPI is not set
    # CONFIG_MFD_WM8350_I2C is not set
    # CONFIG_MFD_WM8994 is not set
    CONFIG_VEXPRESS_CONFIG=y
    # CONFIG_REGULATOR is not set
    CONFIG_MEDIA_SUPPORT=y
    # Multimedia core support
    # CONFIG_MEDIA_CAMERA_SUPPORT is not set
    # CONFIG_MEDIA_ANALOG_TV_SUPPORT is not set
    # CONFIG_MEDIA_DIGITAL_TV_SUPPORT is not set
    # CONFIG_MEDIA_RADIO_SUPPORT is not set
    # CONFIG_MEDIA_RC_SUPPORT is not set
    # CONFIG_VIDEO_ADV_DEBUG is not set
    # CONFIG_VIDEO_FIXED_MINOR_RANGES is not set
    # CONFIG_TTPCI_EEPROM is not set
    # Media drivers
    # CONFIG_MEDIA_USB_SUPPORT is not set
    # CONFIG_MEDIA_PCI_SUPPORT is not set
    # Supported MMC/SDIO adapters
    # CONFIG_CYPRESS_FIRMWARE is not set
    # Media ancillary drivers (tuners, sensors, i2c, frontends)
    # Customise DVB Frontends
    # CONFIG_DVB_TUNER_DIB0070 is not set
    # CONFIG_DVB_TUNER_DIB0090 is not set
    # Tools to develop new frontends
    # CONFIG_DVB_DUMMY_FE is not set
    # Graphics support
    CONFIG_VGA_ARB=y
    CONFIG_VGA_ARB_MAX_GPUS=16
    # CONFIG_DRM is not set
    # CONFIG_TEGRA_HOST1X is not set
    # CONFIG_VGASTATE is not set
    # CONFIG_VIDEO_OUTPUT_CONTROL is not set
    CONFIG_FB=y
    # CONFIG_FIRMWARE_EDID is not set
    # CONFIG_FB_DDC is not set
    # CONFIG_FB_BOOT_VESA_SUPPORT is not set
    CONFIG_FB_CFB_FILLRECT=y
    CONFIG_FB_CFB_COPYAREA=y
    CONFIG_FB_CFB_IMAGEBLIT=y
    # CONFIG_FB_CFB_REV_PIXELS_IN_BYTE is not set
    # CONFIG_FB_SYS_FILLRECT is not set
    # CONFIG_FB_SYS_COPYAREA is not set
    # CONFIG_FB_SYS_IMAGEBLIT is not set
    # CONFIG_FB_FOREIGN_ENDIAN is not set
    # CONFIG_FB_SYS_FOPS is not set
    # CONFIG_FB_SVGALIB is not set
    # CONFIG_FB_MACMODES is not set
    # CONFIG_FB_BACKLIGHT is not set
    # CONFIG_FB_MODE_HELPERS is not set
    # CONFIG_FB_TILEBLITTING is not set
    # Frame buffer hardware drivers
    # CONFIG_FB_CIRRUS is not set
    # CONFIG_FB_PM2 is not set
    # CONFIG_FB_ARMCLCD is not set
    # CONFIG_FB_CYBER2000 is not set
    # CONFIG_FB_ASILIANT is not set
    # CONFIG_FB_IMSTT is not set
    # CONFIG_FB_UVESA is not set
    # CONFIG_FB_S1D13XXX is not set
    # CONFIG_FB_NVIDIA is not set
    # CONFIG_FB_RIVA is not set
    # CONFIG_FB_I740 is not set
    # CONFIG_FB_MATROX is not set
    # CONFIG_FB_RADEON is not set
    # CONFIG_FB_ATY128 is not set
    # CONFIG_FB_ATY is not set
    # CONFIG_FB_S3 is not set
    # CONFIG_FB_SAVAGE is not set
    # CONFIG_FB_SIS is not set
    # CONFIG_FB_NEOMAGIC is not set
    # CONFIG_FB_KYRO is not set
    # CONFIG_FB_3DFX is not set
    # CONFIG_FB_VOODOO1 is not set
    # CONFIG_FB_VT8623 is not set
    # CONFIG_FB_TRIDENT is not set
    # CONFIG_FB_ARK is not set
    # CONFIG_FB_PM3 is not set
    # CONFIG_FB_CARMINE is not set
    # CONFIG_FB_SMSCUFX is not set
    # CONFIG_FB_UDL is not set
    # CONFIG_FB_XILINX is not set
    # CONFIG_FB_GOLDFISH is not set
    # CONFIG_FB_VIRTUAL is not set
    # CONFIG_FB_METRONOME is not set
    # CONFIG_FB_MB862XX is not set
    # CONFIG_FB_BROADSHEET is not set
    # CONFIG_FB_AUO_K190X is not set
    # CONFIG_FB_SIMPLE is not set
    CONFIG_FB_XYLON=y
    # CONFIG_FB_XYLON_PLATFORM is not set
    CONFIG_FB_XYLON_OF=y
    # CONFIG_FB_XYLON_PIXCLK is not set
    # CONFIG_FB_XYLON_MISC is not set
    # CONFIG_EXYNOS_VIDEO is not set
    # CONFIG_BACKLIGHT_LCD_SUPPORT is not set
    # Console display driver support
    CONFIG_DUMMY_CONSOLE=y
    CONFIG_FRAMEBUFFER_CONSOLE=y
    # CONFIG_FRAMEBUFFER_CONSOLE_DETECT_PRIMARY is not set
    # CONFIG_FRAMEBUFFER_CONSOLE_ROTATION is not set
    # CONFIG_LOGO is not set
    # CONFIG_FB_SSD1307 is not set
    # CONFIG_SOUND is not set
    # HID support
    CONFIG_HID=y
    # CONFIG_HID_BATTERY_STRENGTH is not set
    # CONFIG_HIDRAW is not set
    # CONFIG_UHID is not set
    CONFIG_HID_GENERIC=y
    # Special HID drivers
    # CONFIG_HID_A4TECH is not set
    # CONFIG_HID_ACRUX is not set
    # CONFIG_HID_APPLE is not set
    # CONFIG_HID_APPLEIR is not set
    # CONFIG_HID_AUREAL is not set
    # CONFIG_HID_BELKIN is not set
    # CONFIG_HID_CHERRY is not set
    # CONFIG_HID_CHICONY is not set
    # CONFIG_HID_CYPRESS is not set
    # CONFIG_HID_DRAGONRISE is not set
    # CONFIG_HID_EMS_FF is not set
    # CONFIG_HID_ELECOM is not set
    # CONFIG_HID_ELO is not set
    # CONFIG_HID_EZKEY is not set
    # CONFIG_HID_HOLTEK is not set
    # CONFIG_HID_HUION is not set
    # CONFIG_HID_KEYTOUCH is not set
    # CONFIG_HID_KYE is not set
    # CONFIG_HID_UCLOGIC is not set
    # CONFIG_HID_WALTOP is not set
    # CONFIG_HID_GYRATION is not set
    # CONFIG_HID_ICADE is not set
    # CONFIG_HID_TWINHAN is not set
    # CONFIG_HID_KENSINGTON is not set
    # CONFIG_HID_LCPOWER is not set
    # CONFIG_HID_LENOVO_TPKBD is not set
    # CONFIG_HID_LOGITECH is not set
    # CONFIG_HID_MAGICMOUSE is not set
    CONFIG_HID_MICROSOFT=y
    # CONFIG_HID_MONTEREY is not set
    # CONFIG_HID_MULTITOUCH is not set
    # CONFIG_HID_NTRIG is not set
    # CONFIG_HID_ORTEK is not set
    # CONFIG_HID_PANTHERLORD is not set
    # CONFIG_HID_PETALYNX is not set
    # CONFIG_HID_PICOLCD is not set
    # CONFIG_HID_PRIMAX is not set
    # CONFIG_HID_ROCCAT is not set
    # CONFIG_HID_SAITEK is not set
    # CONFIG_HID_SAMSUNG is not set
    # CONFIG_HID_SPEEDLINK is not set
    # CONFIG_HID_STEELSERIES is not set
    # CONFIG_HID_SUNPLUS is not set
    # CONFIG_HID_GREENASIA is not set
    # CONFIG_HID_SMARTJOYPLUS is not set
    # CONFIG_HID_TIVO is not set
    # CONFIG_HID_TOPSEED is not set
    # CONFIG_HID_THRUSTMASTER is not set
    # CONFIG_HID_XINMO is not set
    # CONFIG_HID_ZEROPLUS is not set
    # CONFIG_HID_ZYDACRON is not set
    # CONFIG_HID_SENSOR_HUB is not set
    # USB HID support
    CONFIG_USB_HID=y
    # CONFIG_HID_PID is not set
    # CONFIG_USB_HIDDEV is not set
    # I2C HID support
    # CONFIG_I2C_HID is not set
    CONFIG_USB_OHCI_LITTLE_ENDIAN=y
    CONFIG_USB_SUPPORT=y
    CONFIG_USB_COMMON=y
    CONFIG_USB_ARCH_HAS_HCD=y
    CONFIG_USB=y
    # CONFIG_USB_DEBUG is not set
    # CONFIG_USB_ANNOUNCE_NEW_DEVICES is not set
    # Miscellaneous USB options
    CONFIG_USB_DEFAULT_PERSIST=y
    # CONFIG_USB_DYNAMIC_MINORS is not set
    CONFIG_USB_OTG=y
    # CONFIG_USB_OTG_WHITELIST is not set
    # CONFIG_USB_OTG_BLACKLIST_HUB is not set
    # CONFIG_USB_MON is not set
    # CONFIG_USB_WUSB_CBAF is not set
    # USB Host Controller Drivers
    # CONFIG_USB_C67X00_HCD is not set
    # CONFIG_USB_XHCI_HCD is not set
    CONFIG_USB_EHCI_HCD=y
    CONFIG_USB_EHCI_ROOT_HUB_TT=y
    # CONFIG_USB_EHCI_TT_NEWSCHED is not set
    CONFIG_USB_EHCI_PCI=y
    CONFIG_USB_XUSBPS_DR_OF=y
    CONFIG_USB_EHCI_XUSBPS=y
    # CONFIG_USB_EHCI_HCD_PLATFORM is not set
    # CONFIG_USB_OXU210HP_HCD is not set
    # CONFIG_USB_ISP116X_HCD is not set
    # CONFIG_USB_ISP1760_HCD is not set
    # CONFIG_USB_ISP1362_HCD is not set
    # CONFIG_USB_FUSBH200_HCD is not set
    # CONFIG_USB_FOTG210_HCD is not set
    # CONFIG_USB_OHCI_HCD is not set
    # CONFIG_USB_UHCI_HCD is not set
    # CONFIG_USB_SL811_HCD is not set
    # CONFIG_USB_R8A66597_HCD is not set
    # CONFIG_USB_HCD_TEST_MODE is not set
    # CONFIG_USB_MUSB_HDRC is not set
    # CONFIG_USB_RENESAS_USBHS is not set
    # USB Device Class drivers
    # CONFIG_USB_ACM is not set
    # CONFIG_USB_PRINTER is not set
    # CONFIG_USB_WDM is not set
    # CONFIG_USB_TMC is not set
    # NOTE: USB_STORAGE depends on SCSI but BLK_DEV_SD may
    # also be needed; see USB_STORAGE Help for more info
    CONFIG_USB_STORAGE=y
    # CONFIG_USB_STORAGE_DEBUG is not set
    # CONFIG_USB_STORAGE_REALTEK is not set
    # CONFIG_USB_STORAGE_DATAFAB is not set
    # CONFIG_USB_STORAGE_FREECOM is not set
    # CONFIG_USB_STORAGE_ISD200 is not set
    # CONFIG_USB_STORAGE_USBAT is not set
    # CONFIG_USB_STORAGE_SDDR09 is not set
    # CONFIG_USB_STORAGE_SDDR55 is not set
    # CONFIG_USB_STORAGE_JUMPSHOT is not set
    # CONFIG_USB_STORAGE_ALAUDA is not set
    # CONFIG_USB_STORAGE_ONETOUCH is not set
    # CONFIG_USB_STORAGE_KARMA is not set
    # CONFIG_USB_STORAGE_CYPRESS_ATACB is not set
    # CONFIG_USB_STORAGE_ENE_UB6250 is not set
    # USB Imaging devices
    # CONFIG_USB_MDC800 is not set
    # CONFIG_USB_MICROTEK is not set
    # CONFIG_USB_DWC3 is not set
    # CONFIG_USB_CHIPIDEA is not set
    # USB port drivers
    # CONFIG_USB_SERIAL is not set
    # USB Miscellaneous drivers
    # CONFIG_USB_EMI62 is not set
    # CONFIG_USB_EMI26 is not set
    # CONFIG_USB_ADUTUX is not set
    # CONFIG_USB_SEVSEG is not set
    # CONFIG_USB_RIO500 is not set
    # CONFIG_USB_LEGOTOWER is not set
    # CONFIG_USB_LCD is not set
    # CONFIG_USB_LED is not set
    # CONFIG_USB_CYPRESS_CY7C63 is not set
    # CONFIG_USB_CYTHERM is not set
    # CONFIG_USB_IDMOUSE is not set
    # CONFIG_USB_FTDI_ELAN is not set
    # CONFIG_USB_APPLEDISPLAY is not set
    # CONFIG_USB_SISUSBVGA is not set
    # CONFIG_USB_LD is not set
    # CONFIG_USB_TRANCEVIBRATOR is not set
    # CONFIG_USB_IOWARRIOR is not set
    # CONFIG_USB_TEST is not set
    # CONFIG_USB_EHSET_TEST_FIXTURE is not set
    # CONFIG_USB_ISIGHTFW is not set
    # CONFIG_USB_YUREX is not set
    # CONFIG_USB_EZUSB_FX2 is not set
    # CONFIG_USB_HSIC_USB3503 is not set
    # USB Physical Layer drivers
    CONFIG_USB_PHY=y
    # CONFIG_NOP_USB_XCEIV is not set
    # CONFIG_AM335X_PHY_USB is not set
    # CONFIG_SAMSUNG_USB2PHY is not set
    # CONFIG_SAMSUNG_USB3PHY is not set
    # CONFIG_USB_GPIO_VBUS is not set
    # CONFIG_USB_ISP1301 is not set
    # CONFIG_USB_RCAR_PHY is not set
    CONFIG_USB_ULPI=y
    CONFIG_USB_ULPI_VIEWPORT=y
    # CONFIG_USB_ZYNQ_PHY is not set
    CONFIG_USB_GADGET=y
    # CONFIG_USB_GADGET_DEBUG is not set
    # CONFIG_USB_GADGET_DEBUG_FILES is not set
    # CONFIG_USB_GADGET_DEBUG_FS is not set
    CONFIG_USB_GADGET_VBUS_DRAW=2
    CONFIG_USB_GADGET_STORAGE_NUM_BUFFERS=2
    # USB Peripheral Controller
    CONFIG_USB_GADGET_XUSBPS=y
    CONFIG_XUSBPS_ERRATA_DT654401=y
    CONFIG_USB_XUSBPS=y
    # CONFIG_USB_FUSB300 is not set
    # CONFIG_USB_FOTG210_UDC is not set
    # CONFIG_USB_R8A66597 is not set
    CONFIG_USB_GADGET_XILINX=y
    # CONFIG_USB_PXA27X is not set
    # CONFIG_USB_MV_UDC is not set
    # CONFIG_USB_MV_U3D is not set
    # CONFIG_USB_M66592 is not set
    # CONFIG_USB_AMD5536UDC is not set
    # CONFIG_USB_NET2272 is not set
    # CONFIG_USB_NET2280 is not set
    # CONFIG_USB_GOKU is not set
    # CONFIG_USB_EG20T is not set
    # CONFIG_USB_DUMMY_HCD is not set
    CONFIG_USB_LIBCOMPOSITE=m
    CONFIG_USB_F_SS_LB=m
    # CONFIG_USB_CONFIGFS is not set
    CONFIG_USB_ZERO=m
    # CONFIG_USB_ZERO_HNPTEST is not set
    # CONFIG_USB_ETH is not set
    # CONFIG_USB_G_NCM is not set
    # CONFIG_USB_GADGETFS is not set
    # CONFIG_USB_FUNCTIONFS is not set
    # CONFIG_USB_MASS_STORAGE is not set
    # CONFIG_USB_G_SERIAL is not set
    # CONFIG_USB_G_PRINTER is not set
    # CONFIG_USB_CDC_COMPOSITE is not set
    # CONFIG_USB_G_ACM_MS is not set
    # CONFIG_USB_G_MULTI is not set
    # CONFIG_USB_G_HID is not set
    # CONFIG_USB_G_DBGP is not set
    # CONFIG_UWB is not set
    CONFIG_MMC=y
    # CONFIG_MMC_DEBUG is not set
    # CONFIG_MMC_UNSAFE_RESUME is not set
    # CONFIG_MMC_CLKGATE is not set
    # MMC/SD/SDIO Card Drivers
    CONFIG_MMC_BLOCK=y
    CONFIG_MMC_BLOCK_MINORS=8
    CONFIG_MMC_BLOCK_BOUNCE=y
    # CONFIG_SDIO_UART is not set
    # CONFIG_MMC_TEST is not set
    # MMC/SD/SDIO Host Controller Drivers
    # CONFIG_MMC_ARMMMCI is not set
    CONFIG_MMC_SDHCI=y
    # CONFIG_MMC_SDHCI_PCI is not set
    CONFIG_MMC_SDHCI_PLTFM=y
    CONFIG_MMC_SDHCI_OF_ARASAN=y
    # CONFIG_MMC_SDHCI_PXAV3 is not set
    # CONFIG_MMC_SDHCI_PXAV2 is not set
    # CONFIG_MMC_TIFM_SD is not set
    # CONFIG_MMC_CB710 is not set
    # CONFIG_MMC_VIA_SDMMC is not set
    # CONFIG_MMC_DW is not set
    # CONFIG_MMC_VUB300 is not set
    # CONFIG_MMC_USHC is not set
    # CONFIG_MEMSTICK is not set
    # CONFIG_NEW_LEDS is not set
    # CONFIG_ACCESSIBILITY is not set
    # CONFIG_INFINIBAND is not set
    CONFIG_EDAC=y
    CONFIG_EDAC_LEGACY_SYSFS=y
    # CONFIG_EDAC_DEBUG is not set
    CONFIG_EDAC_MM_EDAC=y
    CONFIG_EDAC_ZYNQ=y
    CONFIG_RTC_LIB=y
    CONFIG_RTC_CLASS=y
    CONFIG_RTC_HCTOSYS=y
    CONFIG_RTC_SYSTOHC=y
    CONFIG_RTC_HCTOSYS_DEVICE="rtc0"
    # CONFIG_RTC_DEBUG is not set
    # RTC interfaces
    CONFIG_RTC_INTF_SYSFS=y
    CONFIG_RTC_INTF_PROC=y
    CONFIG_RTC_INTF_DEV=y
    # CONFIG_RTC_INTF_DEV_UIE_EMUL is not set
    # CONFIG_RTC_DRV_TEST is not set
    # I2C RTC drivers
    # CONFIG_RTC_DRV_DS1307 is not set
    # CONFIG_RTC_DRV_DS1374 is not set
    # CONFIG_RTC_DRV_DS1672 is not set
    # CONFIG_RTC_DRV_DS3232 is not set
    # CONFIG_RTC_DRV_MAX6900 is not set
    # CONFIG_RTC_DRV_RS5C372 is not set
    # CONFIG_RTC_DRV_ISL1208 is not set
    # CONFIG_RTC_DRV_ISL12022 is not set
    # CONFIG_RTC_DRV_X1205 is not set
    # CONFIG_RTC_DRV_PCF2127 is not set
    # CONFIG_RTC_DRV_PCF8523 is not set
    CONFIG_RTC_DRV_PCF8563=y
    # CONFIG_RTC_DRV_PCF8583 is not set
    # CONFIG_RTC_DRV_M41T80 is not set
    # CONFIG_RTC_DRV_BQ32K is not set
    # CONFIG_RTC_DRV_S35390A is not set
    # CONFIG_RTC_DRV_FM3130 is not set
    # CONFIG_RTC_DRV_RX8581 is not set
    # CONFIG_RTC_DRV_RX8025 is not set
    # CONFIG_RTC_DRV_EM3027 is not set
    # CONFIG_RTC_DRV_RV3029C2 is not set
    # SPI RTC drivers
    # CONFIG_RTC_DRV_M41T93 is not set
    # CONFIG_RTC_DRV_M41T94 is not set
    # CONFIG_RTC_DRV_DS1305 is not set
    # CONFIG_RTC_DRV_DS1390 is not set
    # CONFIG_RTC_DRV_MAX6902 is not set
    # CONFIG_RTC_DRV_R9701 is not set
    # CONFIG_RTC_DRV_RS5C348 is not set
    # CONFIG_RTC_DRV_DS3234 is not set
    # CONFIG_RTC_DRV_PCF2123 is not set
    # CONFIG_RTC_DRV_RX4581 is not set
    # Platform RTC drivers
    # CONFIG_RTC_DRV_CMOS is not set
    # CONFIG_RTC_DRV_DS1286 is not set
    # CONFIG_RTC_DRV_DS1511 is not set
    # CONFIG_RTC_DRV_DS1553 is not set
    # CONFIG_RTC_DRV_DS1742 is not set
    # CONFIG_RTC_DRV_STK17TA8 is not set
    # CONFIG_RTC_DRV_M48T86 is not set
    # CONFIG_RTC_DRV_M48T35 is not set
    # CONFIG_RTC_DRV_M48T59 is not set
    # CONFIG_RTC_DRV_MSM6242 is not set
    # CONFIG_RTC_DRV_BQ4802 is not set
    # CONFIG_RTC_DRV_RP5C01 is not set
    # CONFIG_RTC_DRV_V3020 is not set
    # CONFIG_RTC_DRV_DS2404 is not set
    # on-CPU RTC drivers
    # CONFIG_RTC_DRV_PL030 is not set
    # CONFIG_RTC_DRV_PL031 is not set
    # CONFIG_RTC_DRV_SNVS is not set
    # CONFIG_RTC_DRV_MOXART is not set
    # HID Sensor RTC drivers
    # CONFIG_RTC_DRV_HID_SENSOR_TIME is not set
    CONFIG_DMADEVICES=y
    # CONFIG_DMADEVICES_DEBUG is not set
    # DMA Devices
    CONFIG_XILINX_DMA_ENGINES=y
    CONFIG_XILINX_AXIDMA=y
    # CONFIG_XILINX_DMATEST is not set
    CONFIG_XILINX_AXIVDMA=y
    # CONFIG_XILINX_VDMATEST is not set
    CONFIG_XILINX_AXICDMA=y
    # CONFIG_XILINX_CDMATEST is not set
    # CONFIG_AMBA_PL08X is not set
    # CONFIG_DW_DMAC_CORE is not set
    # CONFIG_DW_DMAC is not set
    # CONFIG_DW_DMAC_PCI is not set
    # CONFIG_TIMB_DMA is not set
    CONFIG_PL330_DMA=y
    CONFIG_DMA_ENGINE=y
    CONFIG_DMA_OF=y
    # DMA Clients
    # CONFIG_NET_DMA is not set
    # CONFIG_ASYNC_TX_DMA is not set
    # CONFIG_DMATEST is not set
    # CONFIG_AUXDISPLAY is not set
    CONFIG_UIO=y
    # CONFIG_UIO_CIF is not set
    CONFIG_UIO_PDRV_GENIRQ=y
    # CONFIG_UIO_DMEM_GENIRQ is not set
    # CONFIG_UIO_AEC is not set
    # CONFIG_UIO_SERCOS3 is not set
    # CONFIG_UIO_PCI_GENERIC is not set
    # CONFIG_UIO_NETX is not set
    # CONFIG_UIO_MF624 is not set
    CONFIG_UIO_XILINX_APM=y
    # CONFIG_VIRT_DRIVERS is not set
    CONFIG_VIRTIO=m
    # Virtio drivers
    # CONFIG_VIRTIO_PCI is not set
    # CONFIG_VIRTIO_BALLOON is not set
    # CONFIG_VIRTIO_MMIO is not set
    # Microsoft Hyper-V guest support
    # CONFIG_STAGING is not set
    CONFIG_CLKDEV_LOOKUP=y
    CONFIG_HAVE_CLK_PREPARE=y
    CONFIG_COMMON_CLK=y
    # Common Clock Framework
    CONFIG_COMMON_CLK_DEBUG=y
    CONFIG_COMMON_CLK_VERSATILE=y
    # CONFIG_COMMON_CLK_SI5351 is not set
    CONFIG_COMMON_CLK_SI570=y
    # CONFIG_COMMON_CLK_AXI_CLKGEN is not set
    # Hardware Spinlock drivers
    CONFIG_CLKSRC_OF=y
    CONFIG_CLKSRC_MMIO=y
    CONFIG_CADENCE_TTC_TIMER=y
    # CONFIG_MAILBOX is not set
    CONFIG_IOMMU_SUPPORT=y
    CONFIG_OF_IOMMU=y
    # Remoteproc drivers
    CONFIG_REMOTEPROC=m
    # CONFIG_STE_MODEM_RPROC is not set
    CONFIG_ZYNQ_REMOTEPROC=m
    CONFIG_MB_REMOTEPROC=m
    # Rpmsg drivers
    CONFIG_RPMSG=m
    # CONFIG_RPMSG_SERVER_SAMPLE is not set
    # CONFIG_RPMSG_OMX is not set
    # CONFIG_RPMSG_FREERTOS_STAT is not set
    # CONFIG_PM_DEVFREQ is not set
    # CONFIG_EXTCON is not set
    CONFIG_MEMORY=y
    CONFIG_ZYNQ_SMC=y
    # CONFIG_IIO is not set
    # CONFIG_VME_BUS is not set
    # CONFIG_PWM is not set
    CONFIG_IRQCHIP=y
    CONFIG_ARM_GIC=y
    # CONFIG_IPACK_BUS is not set
    # CONFIG_RESET_CONTROLLER is not set
    # CONFIG_FMC is not set
    # File systems
    CONFIG_DCACHE_WORD_ACCESS=y
    CONFIG_EXT2_FS=y
    # CONFIG_EXT2_FS_XATTR is not set
    # CONFIG_EXT2_FS_XIP is not set
    CONFIG_EXT3_FS=y
    # CONFIG_EXT3_DEFAULTS_TO_ORDERED is not set
    CONFIG_EXT3_FS_XATTR=y
    # CONFIG_EXT3_FS_POSIX_ACL is not set
    # CONFIG_EXT3_FS_SECURITY is not set
    CONFIG_EXT4_FS=y
    # CONFIG_EXT4_FS_POSIX_ACL is not set
    # CONFIG_EXT4_FS_SECURITY is not set
    # CONFIG_EXT4_DEBUG is not set
    CONFIG_JBD=y
    # CONFIG_JBD_DEBUG is not set
    CONFIG_JBD2=y
    # CONFIG_JBD2_DEBUG is not set
    CONFIG_FS_MBCACHE=y
    # CONFIG_REISERFS_FS is not set
    # CONFIG_JFS_FS is not set
    # CONFIG_XFS_FS is not set
    # CONFIG_GFS2_FS is not set
    # CONFIG_OCFS2_FS is not set
    # CONFIG_BTRFS_FS is not set
    # CONFIG_NILFS2_FS is not set
    # CONFIG_FS_POSIX_ACL is not set
    CONFIG_FILE_LOCKING=y
    CONFIG_FSNOTIFY=y
    # CONFIG_DNOTIFY is not set
    CONFIG_INOTIFY_USER=y
    # CONFIG_FANOTIFY is not set
    # CONFIG_QUOTA is not set
    # CONFIG_QUOTACTL is not set
    # CONFIG_AUTOFS4_FS is not set
    # CONFIG_FUSE_FS is not set
    # Caches
    # CONFIG_FSCACHE is not set
    # CD-ROM/DVD Filesystems
    # CONFIG_ISO9660_FS is not set
    # CONFIG_UDF_FS is not set
    # DOS/FAT/NT Filesystems
    CONFIG_FAT_FS=y
    CONFIG_MSDOS_FS=y
    CONFIG_VFAT_FS=y
    CONFIG_FAT_DEFAULT_CODEPAGE=437
    CONFIG_FAT_DEFAULT_IOCHARSET="iso8859-1"
    # CONFIG_NTFS_FS is not set
    # Pseudo filesystems
    CONFIG_PROC_FS=y
    CONFIG_PROC_SYSCTL=y
    CONFIG_PROC_PAGE_MONITOR=y
    CONFIG_SYSFS=y
    CONFIG_TMPFS=y
    # CONFIG_TMPFS_POSIX_ACL is not set
    # CONFIG_TMPFS_XATTR is not set
    # CONFIG_HUGETLB_PAGE is not set
    CONFIG_CONFIGFS_FS=m
    CONFIG_MISC_FILESYSTEMS=y
    # CONFIG_ADFS_FS is not set
    # CONFIG_AFFS_FS is not set
    # CONFIG_HFS_FS is not set
    # CONFIG_HFSPLUS_FS is not set
    # CONFIG_BEFS_FS is not set
    # CONFIG_BFS_FS is not set
    # CONFIG_EFS_FS is not set
    CONFIG_JFFS2_FS=y
    CONFIG_JFFS2_FS_DEBUG=0
    CONFIG_JFFS2_FS_WRITEBUFFER=y
    # CONFIG_JFFS2_FS_WBUF_VERIFY is not set
    CONFIG_JFFS2_SUMMARY=y
    # CONFIG_JFFS2_FS_XATTR is not set
    # CONFIG_JFFS2_COMPRESSION_OPTIONS is not set
    CONFIG_JFFS2_ZLIB=y
    # CONFIG_JFFS2_LZO is not set
    CONFIG_JFFS2_RTIME=y
    # CONFIG_JFFS2_RUBIN is not set
    # CONFIG_LOGFS is not set
    # CONFIG_CRAMFS is not set
    # CONFIG_SQUASHFS is not set
    # CONFIG_VXFS_FS is not set
    # CONFIG_MINIX_FS is not set
    # CONFIG_OMFS_FS is not set
    # CONFIG_HPFS_FS is not set
    # CONFIG_QNX4FS_FS is not set
    # CONFIG_QNX6FS_FS is not set
    # CONFIG_ROMFS_FS is not set
    # CONFIG_PSTORE is not set
    # CONFIG_SYSV_FS is not set
    # CONFIG_UFS_FS is not set
    # CONFIG_F2FS_FS is not set
    CONFIG_NETWORK_FILESYSTEMS=y
    CONFIG_NFS_FS=y
    CONFIG_NFS_V2=y
    CONFIG_NFS_V3=y
    # CONFIG_NFS_V3_ACL is not set
    # CONFIG_NFS_V4 is not set
    # CONFIG_NFS_SWAP is not set
    CONFIG_ROOT_NFS=y
    # CONFIG_NFSD is not set
    CONFIG_LOCKD=y
    CONFIG_LOCKD_V4=y
    CONFIG_NFS_COMMON=y
    CONFIG_SUNRPC=y
    # CONFIG_SUNRPC_DEBUG is not set
    # CONFIG_CEPH_FS is not set
    # CONFIG_CIFS is not set
    # CONFIG_NCP_FS is not set
    # CONFIG_CODA_FS is not set
    # CONFIG_AFS_FS is not set
    CONFIG_NLS=y
    CONFIG_NLS_DEFAULT="iso8859-1"
    CONFIG_NLS_CODEPAGE_437=y
    # CONFIG_NLS_CODEPAGE_737 is not set
    # CONFIG_NLS_CODEPAGE_775 is not set
    # CONFIG_NLS_CODEPAGE_850 is not set
    # CONFIG_NLS_CODEPAGE_852 is not set
    # CONFIG_NLS_CODEPAGE_855 is not set
    # CONFIG_NLS_CODEPAGE_857 is not set
    # CONFIG_NLS_CODEPAGE_860 is not set
    # CONFIG_NLS_CODEPAGE_861 is not set
    # CONFIG_NLS_CODEPAGE_862 is not set
    # CONFIG_NLS_CODEPAGE_863 is not set
    # CONFIG_NLS_CODEPAGE_864 is not set
    # CONFIG_NLS_CODEPAGE_865 is not set
    # CONFIG_NLS_CODEPAGE_866 is not set
    # CONFIG_NLS_CODEPAGE_869 is not set
    # CONFIG_NLS_CODEPAGE_936 is not set
    # CONFIG_NLS_CODEPAGE_950 is not set
    # CONFIG_NLS_CODEPAGE_932 is not set
    # CONFIG_NLS_CODEPAGE_949 is not set
    # CONFIG_NLS_CODEPAGE_874 is not set
    # CONFIG_NLS_ISO8859_8 is not set
    # CONFIG_NLS_CODEPAGE_1250 is not set
    # CONFIG_NLS_CODEPAGE_1251 is not set
    CONFIG_NLS_ASCII=y
    CONFIG_NLS_ISO8859_1=y
    # CONFIG_NLS_ISO8859_2 is not set
    # CONFIG_NLS_ISO8859_3 is not set
    # CONFIG_NLS_ISO8859_4 is not set
    # CONFIG_NLS_ISO8859_5 is not set
    # CONFIG_NLS_ISO8859_6 is not set
    # CONFIG_NLS_ISO8859_7 is not set
    # CONFIG_NLS_ISO8859_9 is not set
    # CONFIG_NLS_ISO8859_13 is not set
    # CONFIG_NLS_ISO8859_14 is not set
    # CONFIG_NLS_ISO8859_15 is not set
    # CONFIG_NLS_KOI8_R is not set
    # CONFIG_NLS_KOI8_U is not set
    # CONFIG_NLS_MAC_ROMAN is not set
    # CONFIG_NLS_MAC_CELTIC is not set
    # CONFIG_NLS_MAC_CENTEURO is not set
    # CONFIG_NLS_MAC_CROATIAN is not set
    # CONFIG_NLS_MAC_CYRILLIC is not set
    # CONFIG_NLS_MAC_GAELIC is not set
    # CONFIG_NLS_MAC_GREEK is not set
    # CONFIG_NLS_MAC_ICELAND is not set
    # CONFIG_NLS_MAC_INUIT is not set
    # CONFIG_NLS_MAC_ROMANIAN is not set
    # CONFIG_NLS_MAC_TURKISH is not set
    # CONFIG_NLS_UTF8 is not set
    # CONFIG_DLM is not set
    # Kernel hacking
    # printk and dmesg options
    # CONFIG_PRINTK_TIME is not set
    CONFIG_DEFAULT_MESSAGE_LOGLEVEL=4
    # CONFIG_BOOT_PRINTK_DELAY is not set
    CONFIG_DYNAMIC_DEBUG=y
    # Compile-time checks and compiler options
    # CONFIG_DEBUG_INFO is not set
    # CONFIG_ENABLE_WARN_DEPRECATED is not set
    # CONFIG_ENABLE_MUST_CHECK is not set
    CONFIG_FRAME_WARN=1024
    # CONFIG_STRIP_ASM_SYMS is not set
    # CONFIG_READABLE_ASM is not set
    # CONFIG_UNUSED_SYMBOLS is not set
    CONFIG_DEBUG_FS=y
    # CONFIG_HEADERS_CHECK is not set
    # CONFIG_DEBUG_SECTION_MISMATCH is not set
    # CONFIG_DEBUG_FORCE_WEAK_PER_CPU is not set
    # CONFIG_MAGIC_SYSRQ is not set
    CONFIG_DEBUG_KERNEL=y
    # Memory Debugging
    # CONFIG_DEBUG_PAGEALLOC is not set
    # CONFIG_DEBUG_OBJECTS is not set
    # CONFIG_DEBUG_SLAB is not set
    CONFIG_HAVE_DEBUG_KMEMLEAK=y
    # CONFIG_DEBUG_KMEMLEAK is not set
    # CONFIG_DEBUG_STACK_USAGE is not set
    # CONFIG_DEBUG_VM is not set
    # CONFIG_DEBUG_MEMORY_INIT is not set
    # CONFIG_DEBUG_PER_CPU_MAPS is not set
    # CONFIG_DEBUG_HIGHMEM is not set
    # CONFIG_DEBUG_SHIRQ is not set
    # Debug Lockups and Hangs
    # CONFIG_LOCKUP_DETECTOR is not set
    # CONFIG_DETECT_HUNG_TASK is not set
    # CONFIG_PANIC_ON_OOPS is not set
    CONFIG_PANIC_ON_OOPS_VALUE=0
    # CONFIG_SCHED_DEBUG is not set
    # CONFIG_SCHEDSTATS is not set
    CONFIG_TIMER_STATS=y
    # CONFIG_DEBUG_PREEMPT is not set
    # Lock Debugging (spinlocks, mutexes, etc...)
    # CONFIG_DEBUG_RT_MUTEXES is not set
    # CONFIG_RT_MUTEX_TESTER is not set
    # CONFIG_DEBUG_SPINLOCK is not set
    # CONFIG_DEBUG_MUTEXES is not set
    # CONFIG_DEBUG_WW_MUTEX_SLOWPATH is not set
    # CONFIG_DEBUG_LOCK_ALLOC is not set
    # CONFIG_PROVE_LOCKING is not set
    # CONFIG_LOCK_STAT is not set
    # CONFIG_DEBUG_ATOMIC_SLEEP is not set
    # CONFIG_DEBUG_LOCKING_API_SELFTESTS is not set
    # CONFIG_DEBUG_KOBJECT is not set
    # CONFIG_DEBUG_BUGVERBOSE is not set
    # CONFIG_DEBUG_WRITECOUNT is not set
    # CONFIG_DEBUG_LIST is not set
    # CONFIG_DEBUG_SG is not set
    # CONFIG_DEBUG_NOTIFIERS is not set
    # CONFIG_DEBUG_CREDENTIALS is not set
    # RCU Debugging
    # CONFIG_PROVE_RCU_DELAY is not set
    # CONFIG_SPARSE_RCU_POINTER is not set
    # CONFIG_RCU_TORTURE_TEST is not set
    CONFIG_RCU_CPU_STALL_TIMEOUT=60
    # CONFIG_RCU_CPU_STALL_VERBOSE is not set
    # CONFIG_RCU_CPU_STALL_INFO is not set
    # CONFIG_RCU_TRACE is not set
    # CONFIG_DEBUG_BLOCK_EXT_DEVT is not set
    # CONFIG_NOTIFIER_ERROR_INJECTION is not set
    # CONFIG_FAULT_INJECTION is not set
    CONFIG_HAVE_FUNCTION_TRACER=y
    CONFIG_HAVE_FUNCTION_GRAPH_TRACER=y
    CONFIG_HAVE_DYNAMIC_FTRACE=y
    CONFIG_HAVE_FTRACE_MCOUNT_RECORD=y
    CONFIG_HAVE_SYSCALL_TRACEPOINTS=y
    CONFIG_HAVE_C_RECORDMCOUNT=y
    CONFIG_TRACING_SUPPORT=y
    # CONFIG_FTRACE is not set
    # Runtime Testing
    # CONFIG_LKDTM is not set
    # CONFIG_TEST_LIST_SORT is not set
    # CONFIG_BACKTRACE_SELF_TEST is not set
    # CONFIG_RBTREE_TEST is not set
    # CONFIG_INTERVAL_TREE_TEST is not set
    # CONFIG_ATOMIC64_SELFTEST is not set
    # CONFIG_TEST_STRING_HELPERS is not set
    # CONFIG_TEST_KSTRTOX is not set
    # CONFIG_DMA_API_DEBUG is not set
    # CONFIG_SAMPLES is not set
    CONFIG_HAVE_ARCH_KGDB=y
    # CONFIG_KGDB is not set
    # CONFIG_STRICT_DEVMEM is not set
    CONFIG_ARM_UNWIND=y
    # CONFIG_DEBUG_USER is not set
    CONFIG_DEBUG_LL=y
    # CONFIG_DEBUG_ZYNQ_UART0 is not set
    CONFIG_DEBUG_ZYNQ_UART1=y
    # CONFIG_DEBUG_VEXPRESS_UART0_DETECT is not set
    # CONFIG_DEBUG_VEXPRESS_UART0_CA9 is not set
    # CONFIG_DEBUG_VEXPRESS_UART0_RS1 is not set
    # CONFIG_DEBUG_ICEDCC is not set
    # CONFIG_DEBUG_SEMIHOSTING is not set
    # CONFIG_DEBUG_LL_UART_8250 is not set
    # CONFIG_DEBUG_LL_UART_PL01X is not set
    CONFIG_DEBUG_LL_INCLUDE="debug/zynq.S"
    # CONFIG_DEBUG_UART_PL01X is not set
    # CONFIG_DEBUG_UART_8250 is not set
    CONFIG_DEBUG_UNCOMPRESS=y
    CONFIG_UNCOMPRESS_INCLUDE="debug/uncompress.h"
    CONFIG_EARLY_PRINTK=y
    # CONFIG_OC_ETM is not set
    # CONFIG_PID_IN_CONTEXTIDR is not set
    # Security options
    # CONFIG_KEYS is not set
    # CONFIG_SECURITY_DMESG_RESTRICT is not set
    # CONFIG_SECURITY is not set
    # CONFIG_SECURITYFS is not set
    CONFIG_DEFAULT_SECURITY_DAC=y
    CONFIG_DEFAULT_SECURITY=""
    CONFIG_CRYPTO=y
    # Crypto core or helper
    # CONFIG_CRYPTO_FIPS is not set
    CONFIG_CRYPTO_ALGAPI=y
    CONFIG_CRYPTO_ALGAPI2=y
    CONFIG_CRYPTO_HASH=y
    CONFIG_CRYPTO_HASH2=y
    CONFIG_CRYPTO_RNG=m
    CONFIG_CRYPTO_RNG2=m
    # CONFIG_CRYPTO_MANAGER is not set
    # CONFIG_CRYPTO_MANAGER2 is not set
    # CONFIG_CRYPTO_USER is not set
    # CONFIG_CRYPTO_GF128MUL is not set
    # CONFIG_CRYPTO_NULL is not set
    # CONFIG_CRYPTO_PCRYPT is not set
    # CONFIG_CRYPTO_CRYPTD is not set
    # CONFIG_CRYPTO_AUTHENC is not set
    # CONFIG_CRYPTO_TEST is not set
    # Authenticated Encryption with Associated Data
    # CONFIG_CRYPTO_CCM is not set
    # CONFIG_CRYPTO_GCM is not set
    # CONFIG_CRYPTO_SEQIV is not set
    # Block modes
    # CONFIG_CRYPTO_CBC is not set
    # CONFIG_CRYPTO_CTR is not set
    # CONFIG_CRYPTO_CTS is not set
    # CONFIG_CRYPTO_ECB is not set
    # CONFIG_CRYPTO_LRW is not set
    # CONFIG_CRYPTO_PCBC is not set
    # CONFIG_CRYPTO_XTS is not set
    # Hash modes
    # CONFIG_CRYPTO_CMAC is not set
    # CONFIG_CRYPTO_HMAC is not set
    # CONFIG_CRYPTO_XCBC is not set
    # CONFIG_CRYPTO_VMAC is not set
    # Digest
    CONFIG_CRYPTO_CRC32C=y
    # CONFIG_CRYPTO_CRC32 is not set
    # CONFIG_CRYPTO_CRCT10DIF is not set
    # CONFIG_CRYPTO_GHASH is not set
    # CONFIG_CRYPTO_MD4 is not set
    # CONFIG_CRYPTO_MD5 is not set
    # CONFIG_CRYPTO_MICHAEL_MIC is not set
    # CONFIG_CRYPTO_RMD128 is not set
    # CONFIG_CRYPTO_RMD160 is not set
    # CONFIG_CRYPTO_RMD256 is not set
    # CONFIG_CRYPTO_RMD320 is not set
    # CONFIG_CRYPTO_SHA1 is not set
    # CONFIG_CRYPTO_SHA1_ARM is not set
    # CONFIG_CRYPTO_SHA256 is not set
    # CONFIG_CRYPTO_SHA512 is not set
    # CONFIG_CRYPTO_TGR192 is not set
    # CONFIG_CRYPTO_WP512 is not set
    # Ciphers
    CONFIG_CRYPTO_AES=y
    # CONFIG_CRYPTO_AES_ARM is not set
    # CONFIG_CRYPTO_ANUBIS is not set
    # CONFIG_CRYPTO_ARC4 is not set
    # CONFIG_CRYPTO_BLOWFISH is not set
    # CONFIG_CRYPTO_CAMELLIA is not set
    # CONFIG_CRYPTO_CAST5 is not set
    # CONFIG_CRYPTO_CAST6 is not set
    # CONFIG_CRYPTO_DES is not set
    # CONFIG_CRYPTO_FCRYPT is not set
    # CONFIG_CRYPTO_KHAZAD is not set
    # CONFIG_CRYPTO_SALSA20 is not set
    # CONFIG_CRYPTO_SEED is not set
    # CONFIG_CRYPTO_SERPENT is not set
    # CONFIG_CRYPTO_TEA is not set
    # CONFIG_CRYPTO_TWOFISH is not set
    # Compression
    # CONFIG_CRYPTO_DEFLATE is not set
    # CONFIG_CRYPTO_ZLIB is not set
    # CONFIG_CRYPTO_LZO is not set
    # CONFIG_CRYPTO_LZ4 is not set
    # CONFIG_CRYPTO_LZ4HC is not set
    # Random Number Generation
    CONFIG_CRYPTO_ANSI_CPRNG=m
    # CONFIG_CRYPTO_USER_API_HASH is not set
    # CONFIG_CRYPTO_USER_API_SKCIPHER is not set
    CONFIG_CRYPTO_HW=y
    # CONFIG_CRYPTO_DEV_HIFN_795X is not set
    # CONFIG_BINARY_PRINTF is not set
    # Library routines
    CONFIG_BITREVERSE=y
    CONFIG_GENERIC_STRNCPY_FROM_USER=y
    CONFIG_GENERIC_STRNLEN_USER=y
    CONFIG_GENERIC_NET_UTILS=y
    CONFIG_GENERIC_PCI_IOMAP=y
    CONFIG_GENERIC_IO=y
    # CONFIG_CRC_CCITT is not set
    CONFIG_CRC16=y
    # CONFIG_CRC_T10DIF is not set
    # CONFIG_CRC_ITU_T is not set
    CONFIG_CRC32=y
    # CONFIG_CRC32_SELFTEST is not set
    CONFIG_CRC32_SLICEBY8=y
    # CONFIG_CRC32_SLICEBY4 is not set
    # CONFIG_CRC32_SARWATE is not set
    # CONFIG_CRC32_BIT is not set
    # CONFIG_CRC7 is not set
    # CONFIG_LIBCRC32C is not set
    # CONFIG_CRC8 is not set
    CONFIG_ZLIB_INFLATE=y
    CONFIG_ZLIB_DEFLATE=y
    CONFIG_LZO_COMPRESS=y
    CONFIG_LZO_DECOMPRESS=y
    # CONFIG_XZ_DEC is not set
    # CONFIG_XZ_DEC_BCJ is not set
    CONFIG_DECOMPRESS_GZIP=y
    CONFIG_GENERIC_ALLOCATOR=y
    CONFIG_HAS_IOMEM=y
    CONFIG_HAS_DMA=y
    CONFIG_CPU_RMAP=y
    CONFIG_DQL=y
    CONFIG_NLATTR=y
    CONFIG_ARCH_HAS_ATOMIC64_DEC_IF_POSITIVE=y
    # CONFIG_AVERAGE is not set
    # CONFIG_CORDIC is not set
    # CONFIG_DDR is not set
    CONFIG_FONT_SUPPORT=y
    CONFIG_FONTS=y
    CONFIG_FONT_8x8=y
    CONFIG_FONT_8x16=y
    # CONFIG_FONT_6x11 is not set
    # CONFIG_FONT_7x14 is not set
    # CONFIG_FONT_PEARL_8x8 is not set
    # CONFIG_FONT_ACORN_8x8 is not set
    # CONFIG_FONT_MINI_4x6 is not set
    # CONFIG_FONT_SUN8x16 is not set
    # CONFIG_FONT_SUN12x22 is not set
    # CONFIG_FONT_10x18 is not set
    CONFIG_VIRTUALIZATION=y
  • zedhed
    0 zedhed over 12 years ago
    Hi cuboard,
    Is this related to what is going on in these Xilinx forum posts?
    http://forums.xilinx.com/t5/Embedded-Linux/Microzed-i2c/m-p/395783
    http://forums.xilinx.com/t5/Embedded-Linux/Howto-compile-Zynq-Linux-with-I2C-driver/m-p/376793#M7209
    Looks like they might be using a devicetree entry like this rather than the one you are using:
    ps7-i2c@e0004000 {
                            compatible = "xlnx,ps7-i2c-1.00.a";
                            reg = <0xE0004000 0x1000>;
                            interrupts = <0 25 4>;
                            interrupt-parent = <0x2>;
                            bus-id = <0>;
    tttclock-names = "i2c9_aper";
    tttclocks = <0x3 39>;
                            input-clk = <111111111>;
                            i2c-clk = <100000>;t
                            #address-cells = <1>;
                            xlnx,i2c-clk-freq-hz = <0x69f6bcb>;
    ttt#size-cells = <0>;
    Have you tried an entry like this instead?
    -Kevin
  • jamestkennedy
    0 jamestkennedy over 12 years ago
    I have an I2C EEPROM fixture attached to Pmod JE accessed thru MIO (IC20 10,11, int 57, or IC21 12, 13 int 80). I can read and write from core0 using a bare metal app with the Xilinx driver code with interrupts.
    However when I set up the device tree and .config and rebuild the Linux kernel (from Speedway course V14.2), everything appears fine with the i2c-xilinx-ps driver getting attached. but using open, ioctl(slave EEPROM addr), writes (and reads) fail. With printk trace, I can see the registers programmed in the correct manner (as in Xilinx drivers), but the transfer complete interrupt never occurs and the status register remains zero.
    Has anyone encountered this problem and solved it or can anyone offer a suggestion where I may be awry.
    thanks in advance.
    My app is an AMP with Linux in core0 and bare metal in core1. I just found that, even in core1 bare metal, the Xilinx routines also fail, so it is somehow related to Linux running in core0.
    James
