Software Application Development Petalinux Application with Graphic User Interface
  • Subscribers 364 subscribers
  • Views 2662 views
Hi everyone,
I have made a full working Linux (Petalinux) embedded project with partial reconfiguration technique on ZedBoard. I have written a bash script in which the user can choose when and which of reconfigurable modules have to be reconfigured. I would made the same thing but with a Graphic User Interface. How can I do that? Should I change the PL and add a VGA or HDMI ip's? Is there something already ready for petalinux, also with drivers? Can I do something just with the UART and bash(I was thinking about ncurses library or something like that..)? What kind of program to make a GUI?....I never did that before.
Any help will be useful! Thanks
Regards
  • zedhed
    0 zedhed over 10 years ago
    Hi ngiolet91,
    Have you taken a look at the Xilinx Base TRD?
    http://www.wiki.xilinx.com/Zynq+Base+TRD+2015.4
    It is targeted to the ZC702 board which has very similar peripherals (same HDMI output chip) as ZedBoard.
    It uses Qt graphics libraries to draw the GUI to the display and Xylon logiCVC-ML evaluation IP for the HDMI interface.
    -Kevin
    0 e14 Contributor over 10 years ago in reply to zedhed
    Hi zedhed,
    Thank you for your reply. I have seen the page but is not very clear for me...I mean, what about on how to build my custom GUI? It explains just how to run the demo..where is the ip and the workflow? Anyway I will try to read it again. Do you know other tutorials?
    What about if I did a "GUI" through the terminal? Is it possible to create something very simple? (I was thinking about ncurses library or something like that)..
  • zedhed
    0 zedhed over 10 years ago in reply to e14 Contributor
    Hi ngiolet91,
    You can leverage the Qt libraries in the Xilinx TRD to create your own GUI.
    You can find many Qt tutorial videos which will walk you through the basics.
    Here is the information needed to get you up to the point where you can build Qt applications for Zynq:
    http://www.wiki.xilinx.com/Zynq+Qt+and+Qwt+Base+Libraries-Build+Instructions
    -Kevin
  • zedhed
    Hi ngiolet91,
    Yes, you should be able to cross compile ncurses to run on ZedBoard.
    Here is a nice tutorial someone did for Raspberry Pi which may be interesting to you.
    https://www.raspberrypi.org/forums/viewtopic.php?f=67&t=8185
    -Kevin
    Thank you Kevin for your help!
