Software Application Development PL Software Reset
  • Subscribers 363 subscribers
  • Views 2167 views
PL Software Reset
Hi all,
I have noticed that every time I run my application from SDK, the PL part is still with the state from the previous run. Is there anyway that I can force a programmatic software reset from my app code?
I checked on the Zynq technical reference manual, and I found that a System Software Reset is achieved by asserting "PSS_RST_CTRL[SOFT_RST]" but it isn't very clear how to do this (at least for me). I would expect an API in the BSP in order  to do this.
Just in case, as per automatic configuration, I have a Processor System Reset IP as part of my PL design.
Any help would be greatly appreciated,
Victor.
    You can generate a System Software Reset by writing a '1' to the PSS_RST_CTRL register as detailed in Appendix B of the Zynq Technical Reference Manual. However, as also described in section 26.3 (Reset Effects) of the TRM, that will reset the PL (Programmable Logic) section and require that you re-program the PL.
    If you require a method to initialize your PL under application software control, without reloading the bit file, you will need to explicitly design that function into your programmable logic design.
    -Gary
