Software Application Development reconfigure pl through petalinux fpga manager
  • Subscribers 363 subscribers
  • Views 1674 views
moeoussayran
moeoussayran over 8 years ago
hello,
ia ma using vivado 2017.3 and zcu102. i want to reconfigure the pl using the petalinux 4.9 throuth the fpga manager. but when i am using the command : "  echo 0 > /sys/class/fpga_manager/fpga0/flags", i get : " No such directory" . it means it is not installet the fpga manger ? i check the drivers and everything is ok?  any recommandtion to enable th fpga_manager?
thank you
  • mbrown
    0 mbrown over 8 years ago
    Normally I see this done by building the kernel with the Xilinx Device Configuration driver. On the target you should see 'xdevcfg' in the /dev/ folder.
    Then to write a bitstream to the PL, issue
    zynq# cat bitstream.bit > /dev/xdevcfg
    /Matt
  • moeoussayran
    0 moeoussayran over 8 years ago in reply to mbrown
    yea, but i am using zynqMPsoc. which i could not use the xdevcfg. i have to use fpga manager driver instead of xdevcfg.
  • mbrown
    0 mbrown over 8 years ago in reply to moeoussayran
    Whoops. Missed your target device. Indeed my recommendation was for Zynq-7000.
    /Matt
