Software Application Development Zedboard ethernet communication
  • Subscribers 364 subscribers
  • Views 547 views
Hello I am currently trying to figure out how to make a java program that will communicate with the ethernet port on my zedboard.The goal is to be able to read and write any data sent from one end to the other using a GUI.Does anyone know how I can approach this? any documentation? Code examples?
  • zedhed
    0 zedhed over 11 years ago
    Hi ACHERRY,
    I think what you are looking for is to write a Java application on a PC to communicate with ZedBoard, is that correct?
    Are you planning to run Linux on your ZedBoard?
    If you are planning to run Linux on your ZedBoard, but need some place to start, I suggest starting with the OSL Linux build from Xilinx:
    http://www.wiki.xilinx.com/Zynq+2015.1+Release
    When using an advanced OS like Linux on ZedBoard, network programming is just like on any other Linux platform so you can start from scratch or take an existing example and adapt it to your needs.
    IBM has a lot of tutorials on how to get started with network programming under Linux:
    http://www.ibm.com/developerworks/linux/tutorials/l-sock/
    -Kevin
    0 e14 Contributor over 11 years ago in reply to zedhed
    Im sorry kevin i shouldve been a bit more clear.I already have a zedboard running ubuntu 12.04.I installed jre and jdk on it as well.I am trying to code a java gui application to put on the zedboard.This program will communicate from the zedboard to a PC...(read or write data) by the ethernet port
  • zedhed
    Hi ACHERRY,
    Sorry for the misunderstanding, it sounds like you are coding in Java on both ends then correct?
    In that case, then you should be able to simply look for Java networking examples to build the type of application you want.
    There are books that cover this topic or you can look through some of the tutorials on Oracle to get an idea of where to start with Socket programming:
    https://docs.oracle.com/javase/tutorial/networking/sockets/
    -Kevin
