Software Application Development Debugging bare metal apps
  • Subscribers 363 subscribers
  • Views 279 views
I am currently trying to port a private embedded OS to the ZedBoard, I got the UART working, but I am afraid it is not enough for a proper debugging solution.
Has any one succeeded already to debug applications on the ZB using OpenOCD and GDB?
Can any one point out a sort of tutorial for this process?
    You need to get JTAG working and then debug using XMD on SDK.
    The solution is :
    1 - Install the ftdi libs as pointed in the OpenOCD documentation
    2 - Fetch and compile OpenOCD with FTDI support
    3 - Fetch the ZedBoard config patch, along with the digilent smt interface
    Then you are ready to go, you just need to execute OpenOCD on one terminal, and arm-*-gdb on the other
