Software Application Development PetaLinux 2016.3 Compressed BSP, z7010
  • Subscribers 364 subscribers
  • Views 647 views
Hi
I'm searching for the:
PetaLinux 2016.3 Compressed BSP, z7010.
I'm using Linux 16.04 LTS Linux with Vivado 2016.3 and Petalinux 2016.3 and i'm working on a microzed board 7z010 rev F. If there is no such BSP is one of the older ones compatible with the new Petalinux version?
  • jafoste4
    0 jafoste4 over 9 years ago
    Hello Zwygd,
    As of right now we only have up to Petalinux 2016.2 BSP released for MicroZed, and we are only offering support for the even releases of Petalinux meaning 2016.4, 2017.2, 2017.4 releases. This means we have no plans to create a 2016.3 Petalinux BSP for the MicroZed.
    It is also suggested that you do not Mix and Match older Petalinux BSPs with other Petalinux releases.
    If you want to use Petalinux 2016.3, then you will need to create your own MicroZed 2016.3 BSP. I am going to refer you to this post which goes over the steps that are needed to generate your own BSP. http://zedboard.org/content/petalinux-20152-bsp-microzed
    --Josh
  • 100zaheer
    0 100zaheer over 9 years ago in reply to jafoste4
    Hey Josh,
    Where can i find Petalinux 2016.4, 2017.2, 2017.4 BSP for MicroZed board?
    Zaheer R M
  • jafoste4
    Hello Zaheer,
    As of now we only have the 2016.2 BSO available for MicroZed, however you always have the option to create the BSP yourself. Please see this link http://zedboard.org/content/petalinux-20152-bsp-microzed
    --Josh
