Software Application Development [Solved] linaro-ubuntu:how to make u-boot use mmcblk0p2as rootfs,but not ramdisk?
  • Subscribers 363 subscribers
  • Views 800 views
I have doing linaro-ubuntu-desktop for several days,
last week I was doing as a pdf says(from http://www.zedboard.org/design) ubuntu_desktop,but failed,the error message is
/***********************code
Error: unrecognized/unsupported machine ID (r1 = 0x1fb71dd0).
Available machine support:
ID (hex)        NAME
00000d32        Xilinx Zynq Platform
*****************code*/
I think it's maybe because the solution's out of date.
yesterday and today, I'm doing as analog adv7511 demo.
its website is http://wiki.analog.com/resources/tools-software/linux-drivers/platforms/zynq
the u-boot.elf is built as   http://www.wiki.xilinx.com/U-boot
and the xilinx u-boot is configured to use ramdisk rootfs.
so the boot.bin requires uImage devicetree.dtb and uramdisk.tar.gz
I want to use mmcblk0p2 (the SDcard ext4 partition)
Here's my problem:
1.if there's no uramdisk in the fat32 partition,the boot.bin will cancel. and then the linux won't continue to boot
2.if I do copy a uramdisk.tar.gz into the fat32 partition, it will boot OK,but won't use mmcblkp2 as rootfs.  so it's just a simple linux, without linaro ubuntu.
what should I do to make the linaro-ubuntu-desktop boot?
    Get the base image: http://www.zedboard.org/node/241
    In there you find the devicetree_ramdisk.dts with the bootargs line. Modify it and compile the dts to dtb.
    The root cause of unrecognized/unsupported machine ID is the macro "CONFIG_MACH_TYPE" should be enabled in uboot.
    maybe you are right
    but I have solved it in another way
    in linux kernel config
    set
    CONFIG_XILINX_FIXED_DEVTREE_ADDR=y
    I know it can be changed at dts, and at u-boot configuration
    I just don't know if it's enough.
    I'll try it sometime
    I used to be stuck on this problem.
    The current Xilinx u-boot and kernel expect to boot with bootm, not go.
    bootm has three arguments: <kernel-addr> <ramdisk-addr> <devicetree-addr>.
    To boot to the rootfs on the SD card, you want to run:
    "bootm kernel - devicetree"
    which tells bootm and the kernel there IS no ramdisk.
    You can override u-boot autoboot and type this command yourself, or you can modify the u-boot source code to change what commands it issues to autoboot.
    Also your devicetree should have a bootargs string which defines rootfs as /dev/mmcblk0p2.
    Please see http://fpgacpu.wordpress.com/2013/05/24/yet-another-guide-to-running-linaro-ubuntu-desktop-on-xilinx-zynq-on-the-zedboard/ for a more thorough explanation and tutorial.
