Software Application Development Accelerating openCV with zynq on Zedboard (Xilinx appnote 1167)
  • Replies 7 replies
  • Subscribers 363 subscribers
  • Views 930 views
I am trying to run newly realeased xapp1167(http://www.xilinx.com/support/documentation/application_notes/xapp1167.pdf) for accelerating openCV with zynq on Zedboard. That app is originally for zc702 board. At first I tried to run this application as it is explained but did not work on Zedboard (expected).
In  order to run this on zed board, I created a new boot.bin file (by make boot as in app note) using the FSBL  and U-Boot binary for Zedboard from xilinx wiki release (http://www.wiki.xilinx.com/Zynq+14.5+-+2013.1+Release). Also replaced the devicetree.dtb file in the sd_image  with the one for ZedBoard from above release. Now I am able to boot the processors. but when i try to run the application i get following error
zynq> ./run.sh
Error : cann't open framebuffer device /dev/fb0
The application needs to interact with hdmi port but I suspect it is somehow not detected. Can anyone suggest me what needs to be done in order to get the hdmi port working or simply get rid of this error.
thanks
umair
  • albertabeef
    0 albertabeef over 13 years ago
    Umair,
    The XAPP1167 application note is built on top of the XAPP890 reference design.
    This reference design has been ported to ZedBoard, and will soon be posted on ZedBoard.org ...
    Please wait for this version and start from there ...
    Mario.
    0 e14 Contributor over 13 years ago in reply to albertabeef
    Are there any updates regarding this app note for zedboard.
    umair
  • albertabeef
    Umair,
    The ZedBoard port of XAPP890 is now available.
    http://www.zedboard.org/projects
       XAPP890 Base TRD ZedBoard Port
    Mario.
    I have tried to run the XAPP1167 on Zedboard for weeks, but it still didn't work. Is there any updates for this TRD to run on the Zedboard? Or where can I find related setting options information?
    I have the same problem with you,have you solved it yet?
    Please give me some suggestions,Thank you!
    We had a lot issues setting up and run  XAPP1167 as well.   However, we did get it working by exporting the Vivado HLS code as a ISE compatible IP, than start from XAPP890 and replace the Sobel filter IP with Fast IP (all connection stays the same). Right now we can run the design and see boxes being drawn around each feature points.  You can give that a try.
    -Kevin
    Did you start from the XAPP890 original or from the one already for ZedBoard?
    Now i'm trying to use the XAPP890 for ZedBoard, but one core is blocked and need a special license that i cannot buy. Can you help me, please?
    Thank you!
