Software Application Development creat ip in vivado
  • Subscribers 364 subscribers
  • Views 609 views
creat ip in vivado
hi
i want to creat counter ip in vivado and connect it to ps,
can you help me and introduce me a usefull tutorial?
  • zedhed
    0 zedhed over 11 years ago
    Hi Bahare,
    Creating custom IP and connecting to the PS is something that is covered in Lab 7 of our "Developing Zynqu00AE-7000 All Programmable SoC Hardware SpeedWay Training" found here:
    I would recommend going through that SpeedWay training to familiarize yourself with the workflow.
    http://zedboard.org/course/developing-zynq%C2%AE-7000-all-programmable-soc-hardware-vivado-20133-and-201441
    Once you are familiar with the workflow it should enable you to create your own custom counter IP using your counter HDL design.
    -Kevin
    0 e14 Contributor over 11 years ago in reply to zedhed
    thank's alot Kevin :)
    hi
    i  looked into lab 7 but and
    i created a counter ip and i use vhdl language, how i can connect my output ip counter to output my master ip in VHDL code ?? for example in  below tutorial
    http://www.fpgadeveloper.com/2014/08/creating-a-custom-ip-block-in-vivado.html
    after add component and add port map , u201Creg_data_out <= slv_reg1;u201D replace with u201Creg_data_out <= multiplier_out;" in u201Cmy_multiplier_v1_0_S00_AXI_instu201D file , i want to know what shoud change in u201Cmy_counter_v1_0_M00_AXI_VHDLu201D file after add component above 'begin' and add port map in 'user add logic' ?
