Software Application Development The signal does not drive any load pins in the design.).
  • Subscribers 363 subscribers
  • Views 930 views
GOOD DAY ..
I work with zedboard using palnahead 14.2  ,I received the following :
(WARNING:PhysDesignRules:367 - The signal <RX_TRANS_IBUF> is incomplete. The signal does not drive any load pins in the design.).
Where the (RX_TRANS) is the input to my system
if there is any suggestion could help me,
thanks in advance
Jassim
    If you have not used a signal, synthesis will trim it (remove it).  The warning means you failed to connect something.  Look to see if you have miss-spelled the name, or changed the name in some way.  For example, the signal at the pin, goes to a IBUF primitive, and has a different name at the output.
