Software Application Development Ethernet Cable Plug On After boot
  • Subscribers 364 subscribers
  • Views 1101 views
I'm running the lwIP Echo Server application example.
It work fine for me.
However if the ethernet cable is not connected during boot the application fails (due to PHY to complete autonegotiation - speed setup) .
How can I have my code keep running in the real world?
Ami
  • joseph1960
    0 joseph1960 over 9 years ago
    I tested if my setup has the same issue. All works fine, no matter if I plug in the Ethernet cable during boot or not. Could you provide more details, please?
    Sincerly
    Joseph
    0 e14 Contributor over 9 years ago in reply to joseph1960
    You are right. The issue is not the boot but the startup setup.
    Here is my console output:
    -----lwIP TCP echo server ------
    TCP packets sent to port 6001 will be echoed back
    Start PHY autonegotiation
    Waiting for PHY to complete autonegotiation.
    Auto negotiation error
    Phy setup error
    Assert due to phy setup failure
    By now i solved the issue by adding a loop in the init_emacps function in case link_speed == XST_FAILURE.
