Ultra96 Hardware Design PetaLinux 2018.2 BSP
  • Replies 20 replies
  • Answers 2 answers
  • Subscribers 372 subscribers
  • Views 4158 views
bhfletcher
bhfletcher over 8 years ago
Xilinx has posted a PetaLinux 2018.2 BSP for the Ultra96 board here:
https://www.xilinx.com/member/forms/download/xef.html?filename=xilinx-ultra96-reva-v2018.2-final.bsp
  • jafoste4
    jafoste4 over 7 years ago in reply to bardo2 +3 suggested
    Hi all, We just finished completing the 2018.3 BSP targeting Ulta96-V2. This BSP has the working WIFI support built in among other things. To avoid any additional time lag please use this link to access…
  • lightcollector
    lightcollector over 7 years ago +1 suggested
    Hi, There is a PYNQ release ready for U96 V2. In the official github is a basic 2018.3 PetaLinux bsp. PYNQ uses Ubuntu for the rootfs and the bsp for the pynq build only contains the kernel and device…
  • cb_cross
    0 cb_cross over 7 years ago
    Is this BSP compatible with the Ultra96 V2?
  • jafoste4
    0 jafoste4 over 7 years ago in reply to cb_cross
    Hi Christopher,
    The Ultra96 V1 and V2 will require different BSPs. So no, it is not compatible. This is due mainly because of the DDR memory change and the Wifi module change.
    -Josh
  • cb_cross
    0 cb_cross over 7 years ago in reply to jafoste4
    Thanks for the quick reply.
    Is there a Ultra96-V2 BSP available anywhere?
  • jafoste4
    Hi Chrisopher,
    Not at this time, we are currently in the process of putting it together.
    I would expect it to be ready sometime in the next 3 weeks.
    -Josh
  • skiphs
    0 skiphs over 7 years ago in reply to jafoste4
    Has there been any progress in this regard? I can't seem to find a link to a Ultra96-V2 BSP.
  • bhfletcher
    0 bhfletcher over 7 years ago
    The officially supported Avnet BSPs for Ultra96-V1 are posted here:
    | Zedboard --> PetaLinux Board Support Packages
    We have both 2018.2 and 2018.3 BSPs currently posted.
    Bryan
  • bhfletcher
    0 bhfletcher over 7 years ago in reply to skiphs
    We are working on a 2018.3 BSP for Ultra96-V2. Hoping to have an update later this week.
    Bryan
  • lightcollector
    0 lightcollector over 7 years ago
    Hi,  There is a PYNQ release ready for U96 V2.  In the official github is a basic 2018.3 PetaLinux bsp.  PYNQ uses Ubuntu for the rootfs and the bsp for the pynq build only contains the kernel and device drivers and no packages in the PetaLinux rootfs.
    See: https://github.com/Avnet/Ultra96-PYNQ
    Pre-built SD image links for U96 V1 and V2 can be found through the release page:  https://github.com/Avnet/Ultra96-PYNQ/releases
    Best regards
  • biglotusturtle
    0 biglotusturtle over 7 years ago in reply to bhfletcher
    Any update on the BSP for Ultra96 V2?
  • jafoste4
    0 jafoste4 over 7 years ago in reply to biglotusturtle
    We are currently in testing with the 2018.2 BSP release. I will respond back when I know more.
    Josh
