Ultra96 Hardware Design No DP video from Ultra96V2
  • Subscribers 365 subscribers
  • Views 1055 views
  • ultra96-v2
  • video
miner_tom
miner_tom over 7 years ago
I have an Ultra96 V2. I have tried with two different SD card images. One is the original factory setup and the other is pynq. In neither case can I get any kind of output from the mini DP.
I am using the cable that was recommended in the bundle that I purchased from Avnet.
The monitor is capable of displaying 1920x1080 or 1280x720.
I am logged into the board via the micro usb port. While I have a keyboard and mouse attached to the larger USB ports.
The board has internet access, etc but there is no output on from the display port.
Thank You
Tom
  • narrucmot
    narrucmot over 7 years ago +2 verified
    Can you be specific about what cable you are using? Is it one of the cables listed here?: http://zedboard.org/sites/default/files/documentations/Ultra96_Accessories_180502.pdf Mini-DisplayPort to HDMI…
  • miner_tom
    miner_tom over 7 years ago in reply to narrucmot +1
    Tom, I was not using any of the cables listed. Evidently an active cable was recommended. I was using a passive mini DP to hdmi by "CableCreation". I just ordered the jAbleconn MDPHD4KAA. Hopefully this…
  • narrucmot
    0 narrucmot over 7 years ago
    Mini-DisplayPort to HDMI Adapter
    Ableconn MDPHD4KAA (Ableconn Technologies )
    Mini-DisplayPort to Standard DisplayPort Cable
    Monoprice 13373 (https://www.monoprice.com/Product?p_id=13373 )
    You may also find some useful help on these threads:
    https://www.element14.com/community/message/276852/l/ultra96-v2-mini-dp-to-hdmi-adapter#276852
    Ultra96 Accessories
    --Tom
  • miner_tom
    0 miner_tom over 7 years ago in reply to narrucmot
    Tom,
    Hopefully this will work.
    Thank You
    Tom
