Ultra96 Hardware Design Disabling Bluetooth/WIFI
  • Subscribers 365 subscribers
  • Views 710 views
  • ultra96
joevl
joevl over 6 years ago
We need to physically disable the Bluetooth/WIFI capability on the Ultra96 due to security requirements.
Options we are considering:
  1. Cutting pin 19 (chip enable) on the ATWILC3000 module and tying it to ground
  2. Completely removing the ATWILC3000 module
Has anyone tried this before?
  • clem57
    0 clem57 over 6 years ago
    joevl  No I have not tried this. But following this:
    When VDDIO is OFF and CHIP_EN is low, the chip is powered off with no leakage.
    Just jumper the pin 19 to ground and cut power to VDDIO. This will also disable the SD card as well. Is that OK?
  • clem57
    0 clem57 over 6 years ago in reply to clem57
    More details:
    joevl
    When power is not supplied to the device (DC/DC converter output and VDDIO are OFF, at ground
    potential), voltage cannot be applied to the ATWILC3000-MR110CA module pins because each pin
    contains an ESD diode from the pin to supply. This diode turns on when voltage higher than one diode-
    drop is supplied to the pin.
    If voltage must be applied to the signal pads when the chip is in a low-power state, the VDDIO supply
    must be ON, so the Power_Down state must be used. Similarly, to prevent the pin-to-ground diode from
    turning ON, do not apply voltage that is more than one diode-drop below the ground to any pin.
  • narrucmot
    0 narrucmot over 6 years ago
    If your estimated us high enough (e.g. more than 100 units) you may want to consider contacting your local Avnet account manager or FAE and inquire about having the board customized for your needs (removing the ATWILC3000 WiFi/BLE module).  You may also send an email to customize@avnet.com.
