Ultra96 Hardware Design Where can I find the default arch.json file for Ultra96-V2?
  • Answers 2 answers
  • Subscribers 365 subscribers
  • Views 2904 views
  • ultra96-v2
  • designflow
  • ultra96
  • inference
  • arch.json
rubenlesmes
rubenlesmes over 5 years ago
Is there anywhere I could find an arch.json file for the Ultra96-V2 platform?
I am running into some issues when doing inference with the platform and I need to find out If I'm using the correct one.
I have not gonne into flow design to get a custom one, just wondering If there was a default one.
Thanks in advance.
  • narrucmot
    narrucmot over 5 years ago +1 suggested
    Hi Ruben, I don't know what a 'arch.json' file is, but I infer from the context that it is something needed for AI/ML applications. A little googling led me to these links: https://forums.xilinx.com/t5…
  • bhfletcher
    bhfletcher over 5 years ago in reply to rubenlesmes +1 suggested
    Have you already looked at the image included with https://www.hackster.io/AlbertaBeef/vitis-ai-1-3-flow-for-avnet-vitis-platforms-cd0c51 Bryan
  • narrucmot
    0 narrucmot over 5 years ago
    Hi Ruben,
    https://forums.xilinx.com/t5/AI-and-Vitis-AI/How-to-generate-Custom-DPU-architecture-json-file-for-Vitis-AI/td-p/1170917
    https://www.xilinx.com/html_docs/vitis_ai/1_3/dpu_config.html
    I hope this helps.
    --Tom
  • rubenlesmes
    0 rubenlesmes over 5 years ago in reply to narrucmot
    It is indeed something needed for AI/ML applications but I was looking for a default arch.json file instead of having to generate a custom dpu architecture file which is something not within my scope of research.
  • bhfletcher
    0 bhfletcher over 5 years ago in reply to rubenlesmes
    Bryan
  • albertabeef
    0 albertabeef over 5 years ago
    Ruben,
    In order to use the DPU (Xilinx's edge AI engine), you need to have a hardware design (bitstream) that contains this IP core.
    We have a prebuilt design and SD card image for Vitis-AI 1.3 targeting Ultra96-V2 on hackster.io:
      http://avnet.me/vitis-ai-1.3-project
    The arch.json can be found in the boot partiion of the SD card image.
    For reference, here is the contents of the arch.json for the Vitis-AI 1.3 Ultra96-V2 pre-built.design, which contains a B2304 (lor RAM usage) DPU.
    {"target":"DPUCZDX8G_ISA0_B2304_MAX_BG2"}
    Mario.
