Ultra96 Hardware Design my ultra96 v2 board initialization failed
  • Subscribers 366 subscribers
  • Views 2105 views
andyourself
andyourself over 4 years ago
my ultra96 v2 board initialization failed at sd card boot mode, the INIT led always on.
  • jafoste4
    jafoste4 over 4 years ago +1
    Hello, What image are you using? Try reflashing your SD Card with a new image. Thanks, Josh
  • jafoste4
    0 jafoste4 over 4 years ago
    Josh
  • bhfletcher
    0 bhfletcher over 4 years ago in reply to jafoste4
    That's very good advice jafoste4 ! We've seen a lot of cases were SD Cards spontaneously fail, especially the standard retail ones that you might buy at your local stores. That's why we recommend the industrial-grade Delkin Utility cards.
    It would also be very informative to put the board in JTAG mode and make sure you can still communicate with Vivado Hardware Manager to the SoC, try downloading a bitstream and application using Vitis.
    Bryan
  • andyourself
    0 andyourself over 4 years ago in reply to bhfletcher
    Thanks for your advice, but I should specify the situation that my last SD card accidentally cracked in the board, so it's unlikely a image situation, and i'm wondering how could i distinguish that if it's because my new card doesn't support or the SD card part of the board is also damaged. Anyway, I'm grateful for your advice of the JTAG mode, but my application needs to use the  Jupyter Notebook and the python framework.
  • andyourself
    0 andyourself over 4 years ago in reply to jafoste4
