Ultra96 Hardware Design Hello, i want to use my board ultra96v2 with a wifi dongle to have internet, since my board wifi module does not work. Is there a suggested one? do I need a driver? thanks in advance.
  • Replies 8 replies
  • Subscribers 364 subscribers
  • Views 507 views
cristian2099
cristian2099 over 1 year ago
    shabaz over 1 year ago +1
    This is more of a general Linux thing. Check what drivers are installed, and purchase a WiFi adapter that is compatible with that, to improve your chances of success. Otherwise, expect a more uphill struggle…
    0 shabaz over 1 year ago
    This is more of a general Linux thing. Check what drivers are installed, and purchase a WiFi adapter that is compatible with that, to improve your chances of success. Otherwise, expect a more uphill struggle. Try something like the following (if it doesn't work, you may need to Google around to find out how to determine which drivers are installed).
    find /lib/modules/$(uname -r)/kernel/drivers/net/wireless/
  • iksevas
    0 iksevas over 1 year ago
    How did you verify that your WIFI on-board the U96V2 didn't work? This article may help you: Tips for Integrating WiFi on the Ultra96-V2 - element14 Community
  • cristian2099
    0 cristian2099 over 1 year ago in reply to iksevas
    Hello, my board is affected by the issue described in  https://www.avnet.com/wcm/connect/314f69d3-c745-44ed-a3ce-cd0c40b6088e/Errata+24001+U96+WiFi.pdf?MOD=AJPERES&ContentCache=NONE&CACHE=NONE&CACHEID=ROOTWORKSPACE-314f69d3-c745-44ed-a3ce-cd0c40b6088e-o-xcAr2. Avnet support confirmed this a few days ago. Anyway, I require Wi-Fi functionality to use my boards, so I’m looking for possible solutions.
  • cristian2099
    0 cristian2099 over 1 year ago in reply to shabaz
    Thanks! I will try
  • iksevas
    0 iksevas over 1 year ago in reply to cristian2099
    I see. Thanks for the clarification. I would also agree with @shabaz then regarding finding something that you could plug in that contains a simple know good driver in the OS your are targeting. Another option if you have access would be to potentially get the OSC swapped out to get your board functional.
  • cristian2099
    0 cristian2099 over 1 year ago in reply to cristian2099
    Hello in the drivers/net there is only vxlan.ko and xen-netback.ko, so I see that there are not net drivers in my OS. I wonder why if i just downloaded the one in the getting started of ultra96v2
  • cristian2099
    yes I tried but i don't have drivers on my OS, i dont understand why if i downloaded the one from the getting started ultra96v2. The other option of the OSC i will try but in the meantime i want to use the boards
  • lightcollector
    0 lightcollector over 1 year ago
    Hi, I don't know if it would suit your needs but it would likely be a lot less work to purchase an Ethernet to wifi device?  They are relatively inexpensive and can be found for purchase at many places.  It would also possibly provide a better wifi signal and IP throughput and be further away from the U96 so if you use USB 3.x it won't interere as badly.  If the U96 Ethernet is setup to accept an IP address from a DHCP server there would be no modifications to the U96 firmware or dongle drivers to mess with; just plug and play.
    Kind regards
