Ultrazed Hardware Design UltraZed-EV and Petalinux-2019.2
  • Replies 7 replies
  • Subscribers 361 subscribers
  • Views 1142 views
  • ultrazed
khangdnl
khangdnl over 6 years ago
Hi experts,
I'd like to know where I can find the BSP for UltraZed-EV for using with Petalinux-2019.2, please?
Thanks in advance,
Khang
  • clem57
    clem57 over 6 years ago
    First entry show give you download instructions after google
  • khangdnl
    khangdnl over 6 years ago in reply to clem57
    Hi clem57,
    Doing as you suggested, I could find the latest BSP of UltraZed-EV board which is 2019.1 : http://zedboard.org/support/design/25481/161
    Also, another discussion thread led me to the following repo : https://github.com/Avnet/petalinux
    There's apparently scripts for building the BSP within that repo but there's not official TAG for uz7ev/2019.2 yet.
    Your opinion?
  • clem57
    clem57 over 6 years ago in reply to khangdnl
    In general, the scripts should work even if not specific to the release. But if the release changes something, they may fail. I suggest to create an issue on the GitHub for Avnet to either resolve or confirm using older scripts if you wish to may sure.
    Clem
  • drozwood90
    drozwood90 over 6 years ago in reply to clem57
    HI there,
    I can tell you that we are working on the 2019.2 BSP.  We have some hiccups and are working through them now.  I would expect that the BSP is released at the end of this month or earlier.
    All packaged files would be released to the product page UltraZed-EV under reference designs
    If you want the source / build scripts, you are right that they are loaded up on Github, and as you inferred, there will be a tag.
    I can also say that the scripting does work across the versions - generally speaking.  However, we are also integrating Vitis support and this is hanging us up.  If you are not planning to use Vitis, I do believe that as clem57 suggested, the scripting will work, but i cannot be certain as we were integrating the Vitis support and did not note anything for just a version switch.
    --Dan
  • spocky
    spocky over 6 years ago in reply to drozwood90
    Hi Dan, is there any update on when the 2019.2 BSP will be available? I am getting started working with an Ultrazed for a project with somewhat fast turn around and the updated BSP would be helpful, as we are using Vitis and the 2019.2 tools. Thanks.
  • drozwood90
    drozwood90 over 6 years ago in reply to spocky
    My hope is this week.  I wanted to release today, but we found an issue and are working on it.  Sorry for the delay.
    --Dan
  • drozwood90
    drozwood90 over 6 years ago in reply to drozwood90
    Hi all,
    Another quick update.  The files are being uploaded as I type this.  I would expect everything to be released in the next day or two (depending on back end "Stuff").
    We have a 2019.2 BSP, Vitis AI enabled Platform, and an example Pre-Built Vitis Application for:
    UltraZed-EV
    UltraZed-EG PCIeCC
    UltraZed-EG IOCC
    Ultra96V2
    I'll try to do a consolidated post like I did for the 2019.1 release, but feel free to monitor / follow the product pages!
    --Dan
