Ultrazed Hardware Design UltraZed SOM Board Stacking Height
  • Answers 2 answers
  • Subscribers 360 subscribers
  • Views 1130 views
techwalla12
techwalla12 over 8 years ago
Does anyone know where I can find the specification for the board stacking height between the UltraZed SOM and the Carrier Card (IOCC or PCIe)?
I can't see anything in the SOM User Guide V1, Designers Guide V1.1 or the mechanical PDF.
Also, is what is the internal diameter of the 4 mounting holes provided on the SOM. Can't find the info anywhere.
  • jafoste4
    0 jafoste4 over 8 years ago
    hello techwalla,
    Could you specify what your looking for? Are you looking for the total stack height along? If so do you want the information with the provided heat sink? Or are you looking for the distance between the two PCBs (distance between SOM and Carrier Card when it is installed? I will check on the mounting hole diameter size.
    Josh
  • jafoste4
    The mounting hole diameters on the UltraZed SOM are 125 +/- 10 mils.
    --Josh
  • wwqiao
    0 wwqiao over 6 years ago in reply to jafoste4
    Hi, Joshua:
    Thanks for the mounting hole size.
    What is the stacking height from UltraZED SOM to the CC? We need to find the stand-offs for stacking.
    Thanks.
    -WWQ
  • drozwood90
    0 drozwood90 over 6 years ago in reply to wwqiao
    You can find all mechanical information on the Product page under the Technical Documents tab
    UltraZed-EG
    --Dan
