Ultrazed Hardware Design Debian/Linaro on Ultrazed, X11 does not start
  • Subscribers 360 subscribers
  • Views 659 views
vcouvert
vcouvert over 8 years ago
When trying to migrate from my Petalinux rootfs to a Debian (downloaded from Linaro), X11 no more starts on my UltraZed. Any ideas?
Here is the Xorg.0.log
[ 16.617] (II) Loader magic: 0x55710a2d70
   [ 16.617] (II) Module ABI versions:
   [ 16.617] X.Org ANSI C Emulation: 0.4
   [ 16.617] X.Org Video Driver: 19.0
   [ 16.617] X.Org XInput driver : 21.0
   [ 16.617] X.Org Server Extension : 9.0
   [ 16.621] (EE) systemd-logind: failed to get session: PID 4522 does not belon
   g to any known session
   [ 16.624] (II) xfree86: Adding drm device (/dev/dri/card0)
   [ 16.625] (II) no primary bus or device found
   [ 16.625] falling back to /sys/devices/platform/amba/amba:xilinx_drm/drm/c
   ard0
   [ 16.625] (II) "glx" will be loaded by default.
   [ 16.625] (II) LoadModule: "glx"
   [ 16.625] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
   [ 16.631] (II) Module glx: vendor="X.Org Foundation"
   [ 16.631] compiled for 1.17.3, module version = 1.0.0
   [ 16.631] ABI class: X.Org Server Extension, version 9.0
   [ 16.631] (==) AIGLX enabled
   [ 16.631] (II) LoadModule: "armsoc"
   [ 16.631] (II) Loading /usr/lib/xorg/modules/drivers/armsoc_drv.so
   [ 16.632] (II) Module armsoc: vendor="X.Org Foundation"
   [ 16.632] compiled for 1.17.3, module version = 1.4.0
   [ 16.632] Module class: X.Org Video Driver
   [ 16.632] ABI class: X.Org Video Driver, version 19.0
   [ 16.632] (II) ARMSOC: Driver for ARM Mali compatible chipsets
   [ 16.632] (++) using VT number 7
[ 16.632] (WW) Falling back to old probe method for armsoc
   [ 16.632] (II) No BusID or DriverName specified - opening /dev/dri/card0
   [ 16.632] (II) Got BusID
   [ 16.632] (II) Opened DRM
   [ 16.633] (II) DeviceName is [/dev/dri/card0]
   [ 16.633] (II) bus_id is []
   [ 16.633] (II) DriverName is [xilinx_drm]
   [ 16.633] (II) version is [1.0.0]
   [ 16.633] (II) Screen:0, CRTC:-1
   [ 16.633] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
   [ 16.633] (II) ARMSOC(0): Creating default Display subsection in Screen secti
   on
   "Default Screen Section" for depth/fbbpp 24/32
   [ 16.633] (==) ARMSOC(0): Depth 24, (==) framebuffer bpp 32
   [ 16.633] (==) ARMSOC(0): RGB weight 888
   [ 16.633] (==) ARMSOC(0): Using gamma correction (1.0, 1.0, 1.0)
   [ 16.633] (==) ARMSOC(0): Default visual is TrueColor
   [ 16.633] (II) No BusID or DriverName specified - opening /dev/dri/card0
   [ 16.633] (II) Got BusID
   [ 16.633] (II) Opened DRM
   [ 16.634] (II) UnloadModule: "armsoc"
   [ 16.634] (EE) Screen(s) found, but none have a usable configuration.
   [ 16.634] (EE)
   Fatal server error:
   [ 16.634] (EE) no screens found(EE)
   [ 16.634] (EE)
   Please consult the The X.Org Foundation support
   at http://wiki.x.org
   for help.
   [ 16.634] (EE) Please also check the log file at "/var/log/Xorg.0.log" for ad
   ditional information.
   [ 16.634] (EE)
   [ 16.654] (EE) Server terminated with error (1). Closing log file.
Thanks for your help.
  • zedhed
    0 zedhed over 8 years ago
    Hi vcouvert,
    What changes when you migrate from your Petalinux rootfs to a Debian build?
    Do you change your HW platform (from Vivado) or your device tree (from PetaLinux) at all?
    Best Regards,
    -Kevin
  • vcouvert
    0 vcouvert over 8 years ago in reply to zedhed
    Hi zedhed,
    Thanks for your answer.
    I did not change anything in the HW platform and I just removed the PCI support in the kernel (as explained here: http://www.wiki.xilinx.com/Zynq+UltraScale%EF%BC%8B+MPSoC+Ubuntu+part+2+-+Building+and+Running+the+Ubuntu+Desktop+From+Sources).
    I also tried with the roofs from the image given on this Wiki page (Ubuntu_Desktop_Release_2017_1.zip) and I see the mouse cursor displayed on my screen for a few seconds (I can even move it using the mouse) a nd then it disappear...
    Vincent
