Ultrazed Hardware Design UltraZED-EV + IO Carrier Card VCU in 4KP60
  • Subscribers 359 subscribers
  • Views 1136 views
  • 4kp60
  • ultrazed-ev
  • io carrier
simontam1234
simontam1234 over 6 years ago
     I read the post (UltraZED-EV + IO Carrier Card VCU Design Example (v2018.3)) by Jason Moss about his test on the ZynqUS+ VCU. It seems the highest resolution he tested was 1080P30. I wonder if he was able to test at 4KP60. I am not so much interested whether the VCU design can handle this resolution because I already know it can. I like to get a validation the HDMI video signals can reliably go back and forth through the carrier and the SOM connectors at this data rate.
Simon
  • drozwood90
    0 drozwood90 over 6 years ago
    Hi there,
    I can certainly ask and see what the highest resolution was tested.  Thank you for your interest!
    --Dan
  • drozwood90
    Hi there,
    Here is the response I was able to get:
    "The DisplayPort on the current UltraZed-EV Carrier Card is Single-Lane only and supports up to 1920x1200 resolution, so with this design, we could not get a resolution higher than 1920x1080.  "
    He then added:
    "The HDMI-TX design on the ZCU106 does support 4k2k60 so I would expect it would work "
    --Dan
  • simontam1234
    0 simontam1234 over 6 years ago in reply to drozwood90
    Thanks for the info!
    Simon
  • drozwood90
    0 drozwood90 over 6 years ago in reply to simontam1234
    Hi Simon,
    I heard back from the board designers, they tested with success using 4KUHDP60.  I believe that was the requirement for that design.  However, as was mentioned, based on the circuit and system capabilities, there seems to be no reason a 4K2K60 design would not work.  Couple that with the reply about the design and I think I caught your entire answer.
    Sorry it took a few extra days!
    --Dan
