Using Xilinx Tools Forum microzed 7020 board files
  • Subscribers 363 subscribers
  • Views 360 views
Hello!
I'm trying to use microzed board with xc7z020, but there is no board definition in vivado 2014.4 to this type of board, there is only for microzed with xc7z010 on board. I've searched forums and found this theme: http://zedboard.org/content/vivado-board-files-7z020-version-microzed. But the board definition files referenced in this theme are non avalible for download because of broken link. Also that files are for vivado 2014.1 - this is an old version of vivado, and I do not use it. Could you please provide microzed 7020 board definition files for vivado 2014.4 or at least for vivado 2014.2? Also is it avaliable to connect those files to vivado build-in board definitions like microzed 7010 for user not to worry how to use microzed each time new release of vivado comes?
    The link in the post you reference seems to be broken but there is a zip file on the MicroZed documentation page (http://microzed.org/support/documentation/1519)  MicroZed Board Definition Install for Vivado 2014.2that includes files for both the 7010 and the 7020 MicroZed. I have not yet tested them with Vivado 2014.4 but they may work for that version as well. Just follow the instruction in the zip file for installing into Vivado.
    -Gary
    0 Former Member over 11 years ago in reply to Former Member
    Thanks for the response!
    I will try to test those files in vivado 2014.4 and will give a reply here about the result.
