Using Xilinx Tools Forum XPS problem
  • Subscribers 350 subscribers
  • Views 296 views
XPS problem
I start working with Zedboard. I am trying demos from ZedBoard: Zynq-7000 AP SoC Concepts, Tools and Techniques. I succesfly finished step 3 from page 13, but XPS inform me that project is empty and open BSB wizard. From this point process is totally diferent from demo. I press OK and "Board and system Wizard" diaplays. But zedboard is not listed.
I do not know to continue.
Where is problem?
Seccond litle problem is than XPS does not has licence and stop working with any error. This problem I partiali solved by http://www.zedboard.com/comment/582#comment-582.
    0 Former Member over 13 years ago
    after canceling wizard it is possible add Processing System from Processor IP core.
    Vatu,
    Are you using the 14.2 version of the tools?
    This how-to might be useful for you:
    http://zynqgeek.blogspot.com/2012/08/zedboard-create-planahead-project-with.html
    and then part two:
    http://zynqgeek.blogspot.com/2012/09/creating-custom-peripheral.html
    As for the licensing issue, I believe the general consensus is that you need to install the full version of the tools, and not the webpack.
    Let us know if this helps.
