Using Xilinx Tools Forum 32 bit address allocation of BRAM problem in Viivado
  • Subscribers 369 subscribers
  • Views 544 views
I am working on FPGA of zedboard. I am trying to access BRAM memory (read and write) by using 32 bit address 0x78600000. I earlier tried reading and writing BRAM using 16 bit address, the code works fine. But the issue comes when I use 32 bit address for BRAM. The pg078-axi-bram-ctrl.pdf datasheet says that I can access 32 bit address for BRAM. But when I try to access it, I am getting range of memory as [-1:0] instead of [2^32 -1 :0].
Can anyone please help me out in this issue.
  • bhfletcher
    0 bhfletcher over 10 years ago
    Since your question is so specific to the Xilinx IP, you may have better luck asking the same question on the Xilinx forum.
    https://forums.xilinx.com/t5/Zynq-All-Programmable-SoC/bd-p/zaps
    Bryan
