    • Avnet Boards Community
Using Xilinx Tools Forum using Xilinx SDK to build device-tree
  • Subscribers 335 subscribers
  • Views 374 views
hello,everyone:
i want to use SDK to build device-tree for Zedboard
after i get device-tree using:
bash> git clone git://git.xilinx.com/device-tree.git
i followed the steps on this page,but it didn't work
http://wiki.xilinx.com/device-tree-generator
i added path to bsp folder to Local Repositories and click 'Rescan Repositories',but nothing changed,was that normal?
then i check other pages,some say that i should copy 'bsp' floder to my EDK workspace,i tried and copied the the ..projectproject.srcssources_1edk
but still didn't work.
    i solved the problem the path i set was wrong. i should set the path of the folder containing the bsp folder
    0 Former Member over 12 years ago in reply to Former Member
    jameschennerd,
    Thanks so much for posting back your solution.  I'm glad you are back up and running.  If you are working on a project that you are able to share, be sure to post it in the projects section of the website for others to enjoy and learn from!
    http://zedboard.org/projects
    Thanks!
    you're welcome.
    i hope this could help
