Using Xilinx Tools Forum Critical Warnings Generating Bitstream Planahead 14.4
  • Subscribers 365 subscribers
  • Views 524 views
I get 3 critical warnings when I Generate Bitstream in Planahead 14.4 for the Zedboard. Is this to be expected? I am simply trying to work my way through the 'Hello World' Tutorial and I seem to get some issues that I don't think should be happening. From what I can tell these errors may be the source of many of the problems later on down the track.
[Constraints 18-5] Cannot loc instance 'processing_system7_0_PS_PORB_IBUF' at site B5, Site location is not valid ["C:/workspace/zed_first/zed_first.srcs/sources_1/edk/proc_module/implementation/proc_module_processing_system7_0_wrapper.ncf":157]
[Constraints 18-5] Cannot loc instance 'processing_system7_0_PS_SRSTB_IBUF' at site C9, Site location is not valid ["C:/workspace/zed_first/zed_first.srcs/sources_1/edk/proc_module/implementation/proc_module_processing_system7_0_wrapper.ncf":158]
[Constraints 18-5] Cannot loc instance 'processing_system7_0_PS_CLK_IBUF' at site F7, Site location is not valid ["C:/workspace/zed_first/zed_first.srcs/sources_1/edk/proc_module/implementation/proc_module_processing_system7_0_wrapper.ncf":159]
    I had the same thing happen. I'm pretty sure that this is expected and this warning didn't prevent the tutorial from working.
    I had the same error, but in my case the implementation fails. It gives me a message saying "implementation failed"
    Same here in 14.2.
    Delete the synth folder in your project and do it again.
    I deleted the entire "synthesis" directory under project>srcs>module>synthese
    Did not work. Still getting errors.
    Having the same issue with 14.5.  Bitgen fails with the following
    This design contains pins which have locations (LOC) that are not user-assigned or I/O Standards (IOSTANDARD) that are not user-assigned.
