    • Avnet Boards Community
Using Xilinx Tools Forum Timimg constraints failing
  • Subscribers 336 subscribers
  • Views 461 views
Hi everyone,
I recently recreated the Analog Devices reference design for the HDMI-Transmitter in a PlanAhead project and it currently works with a pixel clock of 148.5MHz (1080p) with my own code I've written in the SDK.
But yesterday I saw that the synthesis tools complain about a timing constraint that wasn't met during synthesis. It's clk_fpga_1 which is, like in the sample project project, set to 200MHz. It's the main clock for the VDMA-AXI-Interconnect and the VDMA core itself. The tools state, that the maximum frequency for this signal is at 100.01MHz. Why does my design even work?
So, I changed the clock in the XPS to 100MHz, just to see what happens. As it turns out, the tools still complain that the timing is not met at 200MHz. Why? I just set it to 100MHz. Even if I remove all intermediate files, a synthesis run creates, from the project, I get the same message. Funnily enough, the design still works.
If I grep for the constraints, I find that the file 'simple_linux.srcs/sources_1/edk/system/implementation/processing_system7_0_wrapper/processing_system7_0_wrapper.ucf' in the project contains the correct timing constraint, but the generated UCF-Files in the design ('simple_linux.runs/impl_1_2/system_stub.ucf' for example) then contain the wrong 200MHz constraint.
Is this a bug in the tools?
    Andy1988,
    I'll pass this along to the Xilinx factory to see what they think about it.
    Thanks for taking the time to write this up.  I'll post back my findings when I hear back from Xilinx.
    0 Former Member over 12 years ago in reply to Former Member
    If it helps, I can zip my whole project for you. It's nothing secretive there, just a hobby ;)
  • rgetz
    0 rgetz over 12 years ago
    Just like it says at (the place the design is maintained):
    http://wiki.analog.com/resources/fpga/xilinx/kc705/adv7511#more_information
    "Ask questions about the FPGA reference design"
    http://ez.analog.com/community/fpga
    Our developers are busy, well -- developing - so we tend to answer things on the ADI forums first. (this CAPTCHA every time you want to post something is too painful).
    -Robin
    Analog Devices
    Contacted the factory - they would like just this.  You can put it on xfer.avnet.com if you would like and PM me the link - or post it here.  The file will only be on the site for a few days before being deleted.
    Once you post it I will pass it along.  They are waiting for my response.
