Using Xilinx Tools Forum ld.exe: cannot find -lxil
  • Subscribers 371 subscribers
  • Views 2371 views
Hello everyone,
I am trying to build a simple FSBL application. When I try to build the project, the console output says:
arm-xilinx-eabi-gcc -Wl,-T -Wl,../src/lscript.ld -L../../zynq_fsbl_0_bsp/ps7_cortexa9_0/lib -o "zynq_fsbl_0.elf"  ./src/ddr_init.o ./src/ff.o ./src/fsbl_handoff.o ./src/fsbl_hooks.o ./src/image_mover.o ./src/main.o ./src/mmc.o ./src/nand.o ./src/nor.o ./src/pcap.o ./src/ps7_init.o ./src/qspi.o ./src/rsa.o ./src/sd.o   -Wl,--start-group,-lxil,-lgcc,-lc,--end-group
c:/xilinx/sdk/2013.1/gnu/arm/nt/bin/../lib/gcc/arm-xilinx-eabi/4.7.2/../../../../arm-xilinx-eabi/bin/ld.exe: cannot find -lxil
c:/xilinx/sdk/2013.1/gnu/arm/nt/bin/../lib/gcc/arm-xilinx-eabi/4.7.2/../../../../arm-xilinx-eabi/bin/ld.exe: cannot find -lc
collect2.exe: error: ld returned 1 exit status
I have googled a lot, but have not found a solution for my problem which other users also seem to have. My machine is a x86-64 Windows 8. I hope someony can help resolving the problem.
Sven
    I have seen this problem from time to time and have been able to solve it by right clicking the project and selecting change referenced BSP and pressing ok without changing anything.
    When loading someone else's project (especially one made from a different version of ISE, doing a build clean worked for me to fix this error.
    You may notice while the build is happening it builds the libxil.a at some point (maybe while making the board support package?), and then it can be found by the compiler later.
  • rickehrkle
    0 rickehrkle over 11 years ago
    I tried the above and none of them solved the problem. It worked after creating a new Application Project and copying the files into it.
