Using Xilinx Tools Forum Upgrade Microzed Base IOCC to Vivado 2014.4
  • Subscribers 370 subscribers
  • Views 215 views
after opening "Microzed Base IOCC" project in Vivado 2014.4 and validating it, following warnings produced:
[BD 41-1348] Reset pin /axi_gpio_0/s_axi_aresetn (associated clock /axi_gpio_0/s_axi_aclk) is connected to asynchronous reset source /processing_system7_0/FCLK_RESET0_N.
This may prevent design from meeting timing. Please add Processor System Reset module to create a reset that is synchronous to the associated clock source /processing_system7_0/FCLK_CLK0.
After ignoring them, synthesis succeeded and timing constraints are met.
Should I follow that warnings and add Processor System Reset? Is there guide how to setup it properly?
    Well,
    I've found an answer in a step-by-step tutorial located at http://www.fpgadeveloper.com/2014/08/creating-a-custom-ip-block-in-vivado.html
