Using Xilinx Tools Forum Cannot Change Zedboard CPU frequency
  • Subscribers 369 subscribers
  • Views 254 views
applefat
applefat over 11 years ago
Hi All, the default CPU Frequency for my Zedboard is 667Mhz. I'd like to change it to 50Mhz (the minimum), for instance, for a project I've already generated from XPS.
In XPS, I click on the little green clocking box on the system map to bring up the clocking clock wizard. When the wizard dialog comes up, I change the CPU PLL frequency to 50Mhz, click the validate button (validates fine), and click OK.
I export my hardware design again, and after it finishes, the Xilinx SDK (which is already open) picks up the change by showing a warning (regarding the system files changing), to which I click OK.
I rebuild the whole project, reprogram the FPGA, and send over my program.
I'm testing whether it works using a sleep(10) function call with a printf before and after so I know when it completes. But the CPU does not sleep for 10 seconds--it's more like 1 second or less. So it seems like the CPU frequency was not actually changed--how do I do this???
I checked the  macro definition of the CPU frequency in the board support files--the one which sleep should be using. It says 50000000 as I would expect. So somehow the BSP files are updated, but NOT the actual CPU init code???
